  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
    @Hoffan, I verified the inclusion button functionality in the dev branch during the weekend (at least on AtMega but it should work fine on ESP as well).
    Just make sure to enable the feature and set a valid ESP-pin. All is documented in sketch.
    • HoffanH
      HoffanH
      Hoffan
      @hek
      Okey So i must enable it in the sketch even if i only use the start button in the GUI in Vera
        @Hoffan
        Not the "button" feature (unless you use it), but the "inclusion mode" feature must be enabled.
        • HoffanH
          HoffanH
          Hoffan
          I don't know if i understan you right here, @Hek
          if i like to use the start button in vera should it look like this
          // Enable inclusion mode
          define MY_INCLUSION_MODE_FEATURE
          define MY_INCLUSION_MODE_DURATION 60
          #define MY_INCLUSION_MODE_BUTTON_PIN 3
            You only need these two:
            • HoffanH
              HoffanH
              Hoffan
              Yes That i understand, But Nothing is still happening in the GUI men i press start
                Anything in the gateway log?
                • HoffanH
                  HoffanH
                  Hoffan
                    Hmm. ok so message reaches gateway. Good start. It should reply back to Vera. with a
                    0;0;3;0;5;1
                    Unfortunately there is no debug log for this in the code. So I can't see if the message is sent to your controller. So either you'll have to look in the Vera log or add a
                    Serial.println(_ethernetMessage);
                    Here: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportEthernet.cpp#L170
                    To see that the message is actually sent back to vera.
                    • HoffanH
                      HoffanH
                      Hoffan
                      You mean that i should change that line #170 år just put in the serial string
                        Add the string debug print.
