  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.4k Views 3 Watching
    @snow
    Could you try replacing this in MySensors/core/MyGatewayTransportEthernet.cpp
    bool _readFromClient(uint8_t i) {
    	while (clients[i].connected() && clients[i].available()) {
    		char inChar = clients[i].read();
    		if (inputString[i].idx < MY_GATEWAY_MAX_RECEIVE_LENGTH - 1) {
    			// if newline then command is complete
    			if (inChar == '\n') {
    				// a command was issued by the client
    				// we will now try to send it to the actuator
    				// echo the string to the serial port
    				debug(PSTR("Client %d: %s\n"), i, inputString[i].string);
    				// add string terminator and clear the string:
    				inputString[i].string[inputString[i].idx] = 0;
    				inputString[i].idx = 0;
    				bool ret = protocolParse(_ethernetMsg, inputString[i].string);
    				if (ret) {
    					return ret;
    				// add it to the inputString:
    				inputString[i].string[inputString[i].idx++] = inChar;
    			debug(PSTR("Client %d: Message too long\n"), i);
    			// Finished with this client's message. Next loop() we'll see if there's more to read.
    	return false;
    And let me know how it behaves.
    • GizMoCuzG
      GizMoCuzG
      GizMoCuz
      I think that will solve the issue... @snow, waiting patiently for your reply ;)
      • snowS
        snowS
        snow
        It's much better now. I can control dimmer from the domoticz. :)
        0;0;3;0;9;Client 0 connected
        0;0;3;0;9;Client 0: 0;0;3;0;2;Get Version
        0;0;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
        0;0;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        0;0;3;0;9;Client 0: 2;255;3;0;6;M Version
        2;255;3;0;6;M
        0;0;3;0;9;send: 0-0-2-2 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
        0;0;3;0;9;read: 2-2-0 s=1,c=0,t=4,pt=0,l=0,sg=0:
        0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=21,sg=0:DimmableLED /w bu
        0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=1,l=1,sg=0:100
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=1,l=1,sg=0,st=ok:100
        0;0;3;0;9;Client 0: 2;1;1;1;3;93M
        2;1;1;1;3;93
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:93
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:93
        0;0;3;0;9;Client 0: 2;1;1;1;3;86
        2;1;1;1;3;86
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:86
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:86
        0;0;3;0;9;Client 0: 2;1;1;1;3;79
        2;1;1;1;3;79
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:79
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:79
        0;0;3;0;9;Client 0: 2;1;1;1;3;71
        2;1;1;1;3;71
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:71
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:71
        0;0;3;0;9;Client 0: 2;1;1;1;3;64
        2;1;1;1;3;64
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:64
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:64
        0;0;3;0;9;Client 0: 2;1;1;1;3;57
        2;1;1;1;3;57
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:57
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:57
        0;0;3;0;9;Client 0: 2;1;1;1;3;50
        2;1;1;1;3;50
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:50
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:50
        0;0;3;0;9;Client 0: 2;1;1;1;3;43
        2;1;1;1;3;43
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:43
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:43
        0;0;3;0;9;Client 0: 2;1;1;1;3;36
        2;1;1;1;3;36
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:36
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:36
        2;1;1;1;3;36
        0;0;3;0;9;Client 0: 2;1;1;1;3;29
        2;1;1;1;3;29
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:29
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:29
        0;0;3;0;9;Client 0: 2;1;1;1;3;21
        2;1;1;1;3;21
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:21
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:21
        0;0;3;0;9;Client 0: 2;1;1;1;3;14
        2;1;1;1;3;14
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=2,sg=0,st=ok:14
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=2,sg=0:14
        0;0;3;0;9;Client 0: 2;1;1;1;3;74
        2;1;1;1;3;7
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=0,l=1,sg=0,st=ok:7
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=0,l=1,sg=0:7
        0;0;3;0;9;Client 0: 2;1;1;1;2;0
        2;1;1;1;2;0
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
        0;0;3;0;9;read: 2-2-0 s=1,c=1,t=3,pt=2,l=2,sg=0:0
        0;0;3;0;9;send: 0-0-2-2 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
          Great, I'll push this fix ASAP.
          • HoffanH
            HoffanH
            Hoffan
            @Hoffan said:
            anyone that knows if include button working now? With vera as controller
            • HoffanH
              HoffanH
              Hoffan
              I can answer that question by my self.. Its still not working
                @Hoffan, I verified the inclusion button functionality in the dev branch during the weekend (at least on AtMega but it should work fine on ESP as well).
                Just make sure to enable the feature and set a valid ESP-pin. All is documented in sketch.
                • HoffanH
                  HoffanH
                  Hoffan
                  @hek
                  Okey So i must enable it in the sketch even if i only use the start button in the GUI in Vera
                    @Hoffan
                    Not the "button" feature (unless you use it), but the "inclusion mode" feature must be enabled.
                    • HoffanH
                      HoffanH
                      Hoffan
                      I don't know if i understan you right here, @Hek
                      if i like to use the start button in vera should it look like this
                      // Enable inclusion mode
                      define MY_INCLUSION_MODE_FEATURE
                      define MY_INCLUSION_MODE_DURATION 60
                      #define MY_INCLUSION_MODE_BUTTON_PIN 3
                        You only need these two:
                        • HoffanH
                          HoffanH
                          Hoffan
                          Yes That i understand, But Nothing is still happening in the GUI men i press start
                            Anything in the gateway log?
                            • HoffanH
                              HoffanH
                              Hoffan
                                Hmm. ok so message reaches gateway. Good start. It should reply back to Vera. with a
                                0;0;3;0;5;1
                                Unfortunately there is no debug log for this in the code. So I can't see if the message is sent to your controller. So either you'll have to look in the Vera log or add a
                                Serial.println(_ethernetMessage);
                                Here: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportEthernet.cpp#L170
                                To see that the message is actually sent back to vera.
                                • HoffanH
                                  HoffanH
                                  Hoffan
                                  You mean that i should change that line #170 år just put in the serial string
                                    Add the string debug print.
