  2. Bug Reports
  3. ESP8266 WiFi gateway issue
49 Posts 6 Posters 28.6k Views 3 Watching
  • HoffanH
    HoffanH
    Hoffan
    @Hoffan said:
    anyone that knows if include button working now? With vera as controller
    • HoffanH
      HoffanH
      Hoffan
      I can answer that question by my self.. Its still not working
        @Hoffan, I verified the inclusion button functionality in the dev branch during the weekend (at least on AtMega but it should work fine on ESP as well).
        Just make sure to enable the feature and set a valid ESP-pin. All is documented in sketch.
        • HoffanH
          HoffanH
          Hoffan
          @hek
          Okey So i must enable it in the sketch even if i only use the start button in the GUI in Vera
            @Hoffan
            Not the "button" feature (unless you use it), but the "inclusion mode" feature must be enabled.
            • HoffanH
              HoffanH
              Hoffan
              I don't know if i understan you right here, @Hek
              if i like to use the start button in vera should it look like this
              // Enable inclusion mode
              define MY_INCLUSION_MODE_FEATURE
              define MY_INCLUSION_MODE_DURATION 60
              #define MY_INCLUSION_MODE_BUTTON_PIN 3
                You only need these two:
                • HoffanH
                  HoffanH
                  Hoffan
                  Yes That i understand, But Nothing is still happening in the GUI men i press start
                    Anything in the gateway log?
                    • HoffanH
                      HoffanH
                      Hoffan
                        Hmm. ok so message reaches gateway. Good start. It should reply back to Vera. with a
                        0;0;3;0;5;1
                        Unfortunately there is no debug log for this in the code. So I can't see if the message is sent to your controller. So either you'll have to look in the Vera log or add a
                        Serial.println(_ethernetMessage);
                        Here: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportEthernet.cpp#L170
                        To see that the message is actually sent back to vera.
                        • HoffanH
                          HoffanH
                          Hoffan
                          You mean that i should change that line #170 år just put in the serial string
                            Add the string debug print.
                            12.5k
