  3. Home Assistant
  4. Home Assistant - How to recognize MySensors nodes
home assistant
64 Posts 7 Posters 54.8k Views 3 Watching
  • D
    drock1985
    @martinhjelmare
    And how would I install your branch of home-assistant then so that I can use it?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      #33
      You can test it by cloning my fork of home-assistant (https://github.com/MartinHjelmare/home-assistant), then checkout my branch "mysensors-component-switch". Then install it with pip. See my console log below. BIG DISCLAIMER: This is work in progress and under development. You are cloning my branch, which is based off the home assistant dev branch, which is not a stable release.
      martin@martin-htpc:~$ mkvirtualenv -p python3 testhomeass
      Running virtualenv with interpreter /usr/bin/python3
      Using base prefix '/usr'
      New python executable in testhomeass/bin/python3
      Also creating executable in testhomeass/bin/python
      Installing setuptools, pip, wheel...done.
      virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/predeactivate
      virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postdeactivate
      virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/preactivate
      virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/postactivate
      virtualenvwrapper.user_scripts creating /home/martin/.virtualenvs/testhomeass/bin/get_env_details
      (testhomeass)martin@martin-htpc:~$ cd Dev/
      (testhomeass)martin@martin-htpc:~/Dev$ mkdir testhomeass
      (testhomeass)martin@martin-htpc:~/Dev$ cd testhomeass/
      (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ git clone git@github.com:MartinHjelmare/home-assistant.git
      Klonar till "home-assistant"...
      remote: Counting objects: 28876, done.
      remote: Total 28876 (delta 0), reused 0 (delta 0), pack-reused 28876
      Tar emot objekt: 100% (28876/28876), 25.45 MiB | 1.59 MiB/s, done.
      Analyserar delta: 100% (19679/19679), done.
      Kontrollerar anslutning... klart.
      (testhomeass)martin@martin-htpc:~/Dev/testhomeass$ cd home-assistant/
      (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git status
      På grenen dev
      Din gren är à jour med "origin/dev".
      inget att checka in, arbetskatalogen ren
      (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ git checkout mysensors-component-switch
      Grenen mysensors-component-switch ställdes in att spåra fjärrgrenen mysensors-component-switch från origin.
      Växlade till en ny gren "mysensors-component-switch"
      (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ pip install .
      Processing /home/martin/Dev/testhomeass/home-assistant
      Collecting requests<3,>=2 (from homeassistant==0.9.0.dev0)
        Using cached requests-2.8.1-py2.py3-none-any.whl
      Collecting pyyaml<4,>=3.11 (from homeassistant==0.9.0.dev0)
      Collecting pytz>=2015.4 (from homeassistant==0.9.0.dev0)
        Using cached pytz-2015.7-py2.py3-none-any.whl
      Requirement already satisfied (use --upgrade to upgrade): pip>=7.0.0 in /home/martin/.virtualenvs/testhomeass/lib/python3.4/site-packages (from homeassistant==0.9.0.dev0)
      Collecting vincenty==0.1.3 (from homeassistant==0.9.0.dev0)
      Building wheels for collected packages: homeassistant
        Running setup.py bdist_wheel for homeassistant
        Stored in directory: /home/martin/.cache/pip/wheels/0d/98/ff/ecb5c632258e50fbc91b535762865e4a132eb966f5c28f00d7
      Successfully built homeassistant
      Installing collected packages: requests, pyyaml, pytz, vincenty, homeassistant
      Successfully installed homeassistant-0.9.0.dev0 pytz-2015.7 pyyaml-3.11 requests-2.8.1 vincenty-0.1.3
      (testhomeass)martin@martin-htpc:~/Dev/testhomeass/home-assistant$ hass
      Config directory: /home/martin/.homeassistant
      WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
      INFO:homeassistant.bootstrap:Home Assistant core initialized
      INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
      INFO:homeassistant.loader:Loaded history from homeassistant.components.history
      INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
      INFO:homeassistant.loader:Loaded http from homeassistant.components.http
      INFO:homeassistant.loader:Loaded notify from homeassistant.components.notify
      INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
      INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
      INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
      INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
      INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
      INFO:homeassistant.loader:Loaded api from homeassistant.components.api
      INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger
      INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
      INFO:homeassistant.loader:Loaded automation from homeassistant.components.automation
      INFO:homeassistant.loader:Loaded group from homeassistant.components.group
      INFO:homeassistant.components.introduction:
              Hello, and welcome to Home Assistant!
              We'll hope that we can make all your dreams come true.
              Here are some resources to get started:
               - Configuring Home Assistant:
                 https://home-assistant.io/getting-started/configuration/
               - Available components:
                 https://home-assistant.io/components/
               - Troubleshooting your configuration:
                 https://home-assistant.io/getting-started/troubleshooting-configuration/
               - Getting help:
                 https://home-assistant.io/help/
              This message is generated by the introduction component. You can
              disable it in configuration.yaml.
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logger>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
      INFO:homeassistant.loader:Loaded notify.telegram from homeassistant.components.notify.telegram
      INFO:homeassistant.util.package:Attempting install of python-telegram-bot==2.8.7
      INFO:homeassistant.components.notify.telegram:Telegram bot is '***censored***'.
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=telegram, domain=notify>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=notify>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
      INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
      INFO:homeassistant.util.package:Attempting install of https://github.com/MartinHjelmare/pymysensors/archive/fifo_queue.zip#pymysensors==0.3
      INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
      INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=group>
      INFO:homeassistant.loader:Loaded automation.state from homeassistant.components.automation.state
      INFO:homeassistant.components.automation:Initialized rule Rule 1 - Door bell pressed
      INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=automation>
      INFO:homeassistant.core:Starting Home Assistant (16 threads)
      INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
      INFO:homeassistant.components.mysensors:update persistence: node 1
      INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=, update_type=persistence, node_id=1>
      INFO:homeassistant.components.mysensors:adding new devices: [<Entity Sensebender Micro Bell 1.1: >, <Entity Sensebender Micro Bell 1.2: >, <Entity Sensebender Micro Bell 1.199: >]
      INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
      INFO:homeassistant.core:Timer:starting
      INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: port=/dev/ttyUSB0, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, update_type=persistence, node_id=1>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, new_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
      INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.1: value_type 0, value = 21.0
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, new_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_11, old_state=<state sensor.sensebender_micro_bell_11=; battery_level=0, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; battery_level=100, unit_of_measurement=°C, child_id=1, node_id=1, friendly_name=Sensebender Micro Bell 1.1 @ 01:26:30 13-12-2015>>
      INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.2: value_type 1, value = 34
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_12, old_state=<state sensor.sensebender_micro_bell_12=; battery_level=0, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; battery_level=100, unit_of_measurement=%, child_id=2, node_id=1, friendly_name=Sensebender Micro Bell 1.2 @ 01:26:30 13-12-2015>>
      INFO:homeassistant.components.sensor.mysensors:Sensebender Micro Bell 1.199: value_type 38, value = 3160
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, new_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.sensebender_micro_bell_1199, old_state=<state sensor.sensebender_micro_bell_1199=; battery_level=0, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=3160; battery_level=100, unit_of_measurement=V, child_id=199, node_id=1, friendly_name=Sensebender Micro Bell 1.199 @ 01:26:30 13-12-2015>>
      INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
      INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
      WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
      ^CINFO:homeassistant.core:Stopping
      INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
      INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
      INFO:mysensors.mysensors:Stopping thread
      INFO:homeassistant.components.recorder:Closing database
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
               - Getting help:
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=notify, service=telegram>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
      INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
      INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=, port=/dev/ttyUSB0, node_id=1>
      INFO:homeassistant.core:Bus:Handling <Event MYSENSORS_NODE_UPDATE[L]: update_type=persistence, devices=1=1=0=<Entity Sensebender Micro Bell 1.1: >, 2=1=<Entity Sensebender Micro Bell 1.2: >, 3=, 199=38=<Entity Sensebender Micro Bell 1.199: >, port=/dev/ttyUSB0, node_id=1>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_11=; child_id=1, unit_of_measurement=°C, battery_level=0, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_11=21.0; child_id=1, unit_of_measurement=°C, battery_level=100, friendly_name=Sensebender Micro Bell 1.1, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_11>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_12=; child_id=2, unit_of_measurement=%, battery_level=0, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_12=34; child_id=2, unit_of_measurement=%, battery_level=100, friendly_name=Sensebender Micro Bell 1.2, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_12>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
      INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sensor.sensebender_micro_bell_1199=3160; child_id=199, unit_of_measurement=V, battery_level=100, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, new_state=<state sensor.sensebender_micro_bell_1199=; child_id=199, unit_of_measurement=V, battery_level=0, friendly_name=Sensebender Micro Bell 1.199, node_id=1 @ 01:26:49 13-12-2015>, entity_id=sensor.sensebender_micro_bell_1199>
      INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
      You can see that I get a warning about bad byte, after first start. I solve this by restarting hass.
      Your home assistant config for mysensors should now be structured like this:
      mysensors:
        port:
          - '/dev/ttyUSB0'
        #  - '/dev/ttyACM0'
        debug: true
        persistence: true
        persistence_file:
          - '/home/martin/.homeassistant/mysensors.json'
        #  - '/home/martin/.homeassistant/mysensors2.json'
        version: '1.5'
      sensor:
        platform: mysensors
      switch:
        platform: mysensors
      • D drock1985
        Hi @martinhjelmare
        I decided to try this on a simplier sketch that I have, but still no luck. I added this line gw.send(lightMsgW.set("1")); to the end of void setup(). The sensor shows up at the top of the States screen in HA, but doesn't let me actually control it, and it doesn't show up in Switches or Lights.
        Here is the sketch that I am using.
         * Version 1.0 - 6-December-2015, Derrick Rockwell
         *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
         *can usually be found in most dollar stores/hardware stores and are
         *battery powered. This sketch uses digital pins 3 and 4 to power two
         *a string of lights each. Ex, one can control white lights the other
         *could control multi-colour lights.
        #define SN "HolidayLEDDeskLights"
        #define SV "1.0"
        #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
        #define WLED_PIN 5      // Pin White-Coloured LED's will attached to
        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
        #define CHILD_ID0 3
        #define CHILD_ID1 5
        static int currentLevelM = 0;  // Current dim level...
        static int currentLevelW = 0;  // Current dim level...
        MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
        MyMessage lightMsgM(MLED_PIN, V_LIGHT);
        MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
        MyMessage lightMsgW(WLED_PIN, V_LIGHT);
         * Dimmable LED initialization method
          Serial.println( SN );
          Serial.println( SV );
          gw.begin( incomingMessage );
          // Register the LED Dimmable Light with the gateway
          gw.present( MLED_PIN, S_DIMMER );
          gw.present( WLED_PIN, S_DIMMER );
          gw.sendSketchInfo(SN, SV);
          // Pull the gateway's current dim level - restore light level upon sendor node power-up
          gw.request( MLED_PIN, V_DIMMER );
          gw.request( WLED_PIN, V_DIMMER );
         *  Dimmable LED main processing loop
        //For Multi Coloured Lights
        if (message.type == V_LIGHT || message.type == V_DIMMER) {
              // if (message.sensor <= 2)
                  //0: All Dimmers
                  //1: LED 1
                  //2: LED 2
                  if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                    fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                    gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                    gw.send(dimmerMsgM.set(requestedLevel) );
                  if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                    fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                    gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                    gw.send(dimmerMsgW.set(requestedLevel) );
         *  This method provides a graceful fade up/down effect
         // For Multi Coloured Lights
        void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
          int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
          while ( (*currentLevel) != toLevel ) {
            (*currentLevel) += delta;
            analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
            delay( FADE_DELAY );
        H
        H
        humblehacker
        @drock1985
        It looks like we're trying to do similar things with HA and MYS... I've been working on a rotary encoder switch for colored lights (eg Limitlessled/HUE etc...) and had been trying to program it through MQTT. However, I just now noticed the LEDDIMMERwithROTARYENCODER sketch in the MySensors examples so I thought I might try using MYS instead of MQTT. Of course that leads right back to the lack of support for MYS Switches in HASS... Perhaps there's a solution for both of our problems if we use an MQTT Gateway instead? I've worked with MQTT and NodeRED before and it was pretty straight forward, but then again I've been having a much harder time understanding the way its implemented in HASS... So I might need to work with it some more before I can be of any help testing the MQTT MYS Gateway with HA...
        • H humblehacker
          @drock1985
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @humblehacker
          Hi!
          I also want to try the MQTT gateway together with HA. MQTT support is well supported in HA, and looking at the MQTT protocol in mysensors dev branch it looks promising. I have just got some ethernet modules and more nanos, so as soon as I find some time, I'll get started. We can post our progress somewhere here whoever gets it going first.
          • D
            drock1985
            wrote on last edited by drock1985
            #36
            @humblehacker @martinhjelmare
            Sounds like an interesting idea to me. I have never used a MQTT gateway before, so i'm going in a little blind. I think I have the server so far (mosquitto) running on the same RPI as my HA install; so now looking into the next step.
            One thing though, would this replace my current serial gateway, or be an addition to it?
            My Projects
            2 Door Chime Sensor
            • D
              drock1985
              I've been trying to get MQTT working using the Dev branch here (http://forum.mysensors.org/topic/2352/guide-setting-up-and-testing-mqtt-client-gateway/) and have my configuration.yaml file looking like this for my W5100MQTT broker:
              #MySensors MQTT Test
              mqtt 1:
                broker: 192.168.86.198
                port: 1883
              #  client_id: home-assistant-1
                keepalive: 60
              #  username: USERNAME
              #  password: PASSWORD
              The Serial output from Arduino shows that I connected successfully
              0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
              0;0;3;0;9;Radio init successful.
              IP: 192.168.86.112
              0;0;3;0;9;MQTT connected
              0;0;3;0;9;Init complete, id=0, parent=0, distance=0
              But, Home-Assistant isn't registering the broker, and I have this error in the Dev section:
              15-12-15 15:32:17 homeassistant.components.mqtt: Missing required configuration items in mqtt: broker
              15-12-15 15:32:17 homeassistant.bootstrap: component mqtt failed to initialize
              Does anyone have any ideas? @humblehacker @martinhjelmare @hek ?
              My Projects
              2 Door Chime Sensor
              martinhjelmareM H 2 Replies Last reply
                Sorry, havent tried HomeAssistant myself.
                • D
                  drock1985
                  Thanks @hek , had to ask :)
                  Would it be possible to get a Home-Assistant dedicated sub-forum please?
                  My Projects
                  2 Door Chime Sensor
                  • D drock1985
                    mqtt 1:
                      port: 1883
                      keepalive: 60
                    IP: 192.168.86.112
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @drock1985
                    What do you set MY_IP_GATEWAY_ADDRESS to on the arduino side?
                      You got it.
                      http://forum.mysensors.org/category/28/home-assistant
                      • D
                        drock1985
                        #42
                        Thanks @hek very appreciated.
                        EDIT: Sort of ran into an issue with the Dev MQTTW5100Gateway sketch.... Thought the output I was getting above was good, but in reality the Arduino IDE wasn't giving an error. I decided to run the gateway in my RPI and view the data through SSH via screen. It initializes and shows the same data as the Arduino IDE, but then seconds later it dies and gives an error about screen terminating. Happens every time.
                        Going to try the ESP8266MQTTGateway: I'm got a hunch.
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          mqtt 1:
                            port: 1883
                            keepalive: 60
                          IP: 192.168.86.112
                          H
                          H
                          humblehacker
                          wrote on last edited by humblehacker
                          #43
                          mqtt 1:
                            port: 1883
                            keepalive: 60
                          Does the IP address you defined in the config.yaml point to your Mosquitto Broker or the Arduino-Ethernet Shield? If it points to the Arduino afaik the point of the MQTTCLIENT Gateway is that it can be run as a client if you've already got a Mosquitto broker. Otherwise you would either need to remove mosquitto or forward it to a different port than the default 1883. If this was the case then HASS would be looking for a broker where none exists which is why it is missing configuration items...
                          D 1 Reply Last reply
                          • H
                            H
                            humblehacker
                            For the time being, I'm thinking of taking a different approach with my toggle switch... I'm thinking of simply defining the button output as a binary sensor which can then toggle between two predefined scenes. At least in my case, input only needs to go in one direction so there's no need to receive any data from the controller....
                            • H humblehacker
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @humblehacker
                              FYI, my fifo_queue pull request has been merged with dev branch at pymysensors, so I'm hoping to be able to implement switch support for the mysensors component in homeassistant very soon.
                              H 1 Reply Last reply
                                @humblehacker
                                H
                                H
                                humblehacker
                                @martinhjelmare said:
                                @humblehacker
                                Thats great news! That should be a huge help with my plans for building an RGB Lighting controller based on the rotary_led_dimmer sketch! If I can ever figure out how to implement a simple toggle switch first...
                                • H humblehacker
                                  mqtt 1:
                                    port: 1883
                                    keepalive: 60
                                  drock1985
                                  @humblehacker said:
                                  k
                                  mqtt 1:
                                    port: 1883
                                    keepalive: 60
                                  @humblehacker
                                  The configuration.yaml file I have pointed back to the local IP address, since Mosquitto and Home-Assistant are running on the same Pi.
                                  So, you are saying that it should really be pointed back to the MQTT Gateway then? Still confusing to me.
                                  My Projects
                                  2 Door Chime Sensor
                                  • H
                                    H
                                    humblehacker
                                    Never mind then... As long as your using Mosquitto as your broker and the MQTT CLIENT Gateway (from the development branch) rather than the default MQTT Gateway sketch from- http://www.mysensors.org/build/mqtt_gateway then none of my earlier comments should apply... Basically I was saying that the default MYSensors MQTT Gateway is set up to function as a broker and would therefore conflict with any Mosquitto server running on the same port. The MQTT CLIENT Gateway (emphasis on CLIENT) from the development branch isnt set up as a broker so it shouldnt conflict with a Mosquitto installation.
                                    • martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      It's still important to be wary about which ip address you assign where, so I think it was a good point.
                                      • D
                                        drock1985
                                        Well, I have Mosquitto and the Dev ClientMQTTESP gateway working, and is communicating fine. Now just trying to figure out the proper entry to add an item as.
                                        My Projects
                                        2 Door Chime Sensor
                                        • D
                                          drock1985
                                          Ok, just got it all setup and working great now. Time to see how relays will work......
                                          My Projects
                                          2 Door Chime Sensor
