  3. Compiling Problems
Compiling Problems
15 Posts 9 Posters 13.0k Views 4 Watching
  • L
    L
    Luppie
    I'm having the same problem.
    Started with MySensors yesterday and tried to install the esp8266 WiFi Gateway.
    Did a clean install of the Arduino IDE 1.6.6 and followed all steps described here
    The result is the same as the topicstarter.
    • tbowmoT
      tbowmoT
      tbowmo
      The problems are related to arduino 1.6.6, and currently only dev is able to compile on it (as far as I know).
      • L
        L
        Luppie
        I can confirm that. Just removed 1.6.6 and revert to 1.6.5 and now it is working instantly.
        Thank you for the hint.
        Maybe it's an option to edit the esp8266_gateway page and remove the + from Arduino 1.6.5+ and add a remark that it's not (yet) working on 1.6.6
        • A
          atomicpapa
          Thanks!! That solved it!!
          • N
            N
            NBM
            That worked. Thank you.
              FYI: Updated master branch (1.5.1) to compile on Arduino IDE 1.6.6 a couple of days ago.
                shabba
                wrote on last edited by shabba
                Is there a link to the 1.5.1 ? And is it considered a stable release? Also might be worth making it the default download for stable so new people don't get scared away.
                • korttomaK
                  korttomaK
                  korttoma
                  The "Download Libraries" button on this page -> http://www.mysensors.org/about/arduino will give you the 1.5.1 version.
                  • Tomas
                  • A
                    ansh
                    I need help! Does not work WiFi Gateway using ESP8266.
                    WARNING: Category '' in library OneWire is not valid. Setting to 'Uncategorized'
                    upload-87fb2d34-a887-4c42-bdcc-1ede9c6b8f51
                      That's just warnings the new IDE is spitting out. Nothing to worry about.
                      • A
                        ansh
                        wrote on last edited by ansh
                        Thank you! Ok.
                        But after flashing WiFi Gateway ESP8266 not pinged .. When I unplug the USB cord from your computer and connect an external source of 5V, then it worked ...
                        • B
                          B
                          bgriffith87
                          This thread helped me as well when I installed Arduino IDE 1.6.7. I still had an old version of the MySensors library kicking around in my Sketch Book (if it isn't broke, don't fix it). I just want to keep this thread alive for awhile. :)
