  3. Compiling Problems
Compiling Problems
15 Posts 9 Posters 13.0k Views 4 Watching
  • N
    N
    NBM
    Hey
    I get this problem when i'm compiling. No matter what i do. I have tried to delete det libery and indset the new libery.
    Can any one help me?
    Arduino: 1.6.6 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:150:9: error: prototype for 'uint8_t SPIFlash::readByte(uint32_t)' does not match any in class 'SPIFlash'
    uint8_t SPIFlash::readByte(uint32_t addr) {
    In file included from /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:35:0:
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:79:11: error: candidate is: uint8_t SPIFlash::readByte(long int)
    uint8_t readByte(long addr);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:161:6: error: prototype for 'void SPIFlash::readBytes(uint32_t, void*, uint16_t)' does not match any in class 'SPIFlash'
    void SPIFlash::readBytes(uint32_t addr, void* buf, uint16_t len) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:80:8: error: candidate is: void SPIFlash::readBytes(long int, void*, word)
    void readBytes(long addr, void* buf, word len);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:220:6: error: prototype for 'void SPIFlash::writeByte(uint32_t, uint8_t)' does not match any in class 'SPIFlash'
    void SPIFlash::writeByte(uint32_t addr, uint8_t byt) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:81:8: error: candidate is: void SPIFlash::writeByte(long int, uint8_t)
    void writeByte(long addr, uint8_t byt);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:234:6: error: prototype for 'void SPIFlash::writeBytes(uint32_t, const void*, uint16_t)' does not match any in class 'SPIFlash'
    void SPIFlash::writeBytes(uint32_t addr, const void* buf, uint16_t len) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:82:8: error: candidate is: void SPIFlash::writeBytes(long int, const void*, uint16_t)
    void writeBytes(long addr, const void* buf, uint16_t len);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:269:6: error: prototype for 'void SPIFlash::blockErase4K(uint32_t)' does not match any in class 'SPIFlash'
    void SPIFlash::blockErase4K(uint32_t addr) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:85:8: error: candidate is: void SPIFlash::blockErase4K(long int)
    void blockErase4K(long address);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:278:6: error: prototype for 'void SPIFlash::blockErase32K(uint32_t)' does not match any in class 'SPIFlash'
    void SPIFlash::blockErase32K(uint32_t addr) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:86:8: error: candidate is: void SPIFlash::blockErase32K(long int)
    void blockErase32K(long address);
    exit status 1
    Fejl i kompilering.
    • A
      atomicpapa
      I am also having a very similar problem trying to compile the code or the serial gateway onto a nano. I am running Arduino IDE 1.6.6.on Ubuntu 15.04. Error log as follows:
      Arduino: 1.6.6 (Linux), Board: "Arduino Nano, ATmega328"
      /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:150:9: error: prototype for 'uint8_t SPIFlash::readByte(uint32_t)' does not match any in class 'SPIFlash'
      In file included from /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:35:0:
      /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:79:11: error: candidate is: uint8_t SPIFlash::readByte(long int)
      /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:161:6: error: prototype for 'void SPIFlash::readBytes(uint32_t, void*, uint16_t)' does not match any in class 'SPIFlash'
      /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:80:8: error: candidate is: void SPIFlash::readBytes(long int, void*, word)
      /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:220:6: error: prototype for 'void SPIFlash::writeByte(uint32_t, uint8_t)' does not match any in class 'SPIFlash'
      /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:81:8: error: candidate is: void SPIFlash::writeByte(long int, uint8_t)
      /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:234:6: error: prototype for 'void SPIFlash::writeBytes(uint32_t, const void*, uint16_t)' does not match any in class 'SPIFlash'
      /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:82:8: error: candidate is: void SPIFlash::writeBytes(long int, const void*, uint16_t)
      /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:269:6: error: prototype for 'void SPIFlash::blockErase4K(uint32_t)' does not match any in class 'SPIFlash'
      /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:85:8: error: candidate is: void SPIFlash::blockErase4K(long int)
      /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:278:6: error: prototype for 'void SPIFlash::blockErase32K(uint32_t)' does not match any in class 'SPIFlash'
      /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:86:8: error: candidate is: void SPIFlash::blockErase32K(long int)
      exit status 1
      Error compiling.
      • A
        atomicpapa
        Update: I should have mentioned in previous post that I have also attempted to remove and reinstall recipes. Also removed and reinstalled the arduino IDE. I also install IDE 1.0.6 which does result in different errors:
        Arduino: 1.0.6 (Linux), Board: "Arduino Nano w/ ATmega328"
        In file included from SerialGateway.ino:53:
        GatewayUtil.h:40: error: ‘MyParserSerial’ does not name a type
        GatewayUtil.h:44: error: ‘MAX_PAYLOAD’ was not declared in this scope
        GatewayUtil.h:67: error: expected ‘,’ or ‘...’ before ‘&’ token
        GatewayUtil.h:67: error: ISO C++ forbids declaration of ‘MyMessage’ with no type
        GatewayUtil.h: In function ‘void incomingMessage(int)’:
        GatewayUtil.h:74: error: ‘message’ was not declared in this scope
        GatewayUtil.h:74: error: ‘mGetCommand’ was not declared in this scope
        GatewayUtil.h:74: error: ‘mGetAck’ was not declared in this scope
        GatewayUtil.h:74: error: ‘convBuf’ was not declared in this scope
        GatewayUtil.h: At global scope:
        GatewayUtil.h:98: error: variable or field ‘parseAndSend’ declared void
        GatewayUtil.h:98: error: ‘MySensor’ was not declared in this scope
        GatewayUtil.h:98: error: ‘gw’ was not declared in this scope
        GatewayUtil.h:98: error: expected primary-expression before ‘char’
        • L
          L
          Luppie
          I'm having the same problem.
          Started with MySensors yesterday and tried to install the esp8266 WiFi Gateway.
          Did a clean install of the Arduino IDE 1.6.6 and followed all steps described here
          The result is the same as the topicstarter.
          • tbowmoT
            tbowmoT
            tbowmo
            The problems are related to arduino 1.6.6, and currently only dev is able to compile on it (as far as I know).
            • L
              L
              Luppie
              I can confirm that. Just removed 1.6.6 and revert to 1.6.5 and now it is working instantly.
              Thank you for the hint.
              Maybe it's an option to edit the esp8266_gateway page and remove the + from Arduino 1.6.5+ and add a remark that it's not (yet) working on 1.6.6
              • A
                atomicpapa
                Thanks!! That solved it!!
                • N
                  N
                  NBM
                  That worked. Thank you.
                    FYI: Updated master branch (1.5.1) to compile on Arduino IDE 1.6.6 a couple of days ago.
                      shabba
                      wrote on last edited by shabba
                      Is there a link to the 1.5.1 ? And is it considered a stable release? Also might be worth making it the default download for stable so new people don't get scared away.
                      • korttomaK
                        korttomaK
                        korttoma
                        The "Download Libraries" button on this page -> http://www.mysensors.org/about/arduino will give you the 1.5.1 version.
                        • Tomas
                        • A
                          ansh
                          I need help! Does not work WiFi Gateway using ESP8266.
                          WARNING: Category '' in library OneWire is not valid. Setting to 'Uncategorized'
                          upload-87fb2d34-a887-4c42-bdcc-1ede9c6b8f51
                            That's just warnings the new IDE is spitting out. Nothing to worry about.
                            • A
                              ansh
                              wrote on last edited by ansh
                              Thank you! Ok.
                              But after flashing WiFi Gateway ESP8266 not pinged .. When I unplug the USB cord from your computer and connect an external source of 5V, then it worked ...
                              • B
                                B
                                bgriffith87
                                This thread helped me as well when I installed Arduino IDE 1.6.7. I still had an old version of the MySensors library kicking around in my Sketch Book (if it isn't broke, don't fix it). I just want to keep this thread alive for awhile. :)
