  3. Weather station
Weather station
12 Posts 3 Posters 6.0k Views 2 Watching
  • N
    N
    NBM
    Hi
    Im trying to make an node with BMP085, DHT22 and LM393. Barometer, Temp/hum and light.
    Can anyone help me to make the sketch work?
    Do the barometer have to be connected to A4 and A5?
    //Vejrstation - Temp, Fugt, Lux, Baro - V 1.0
    #include <Adafruit_BMP085.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define LIGHT_SENSOR_ANALOG_PIN 1
    #define BARO_CHILD 2
    #define TEMP_CHILD 3
    //Temp
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
    int lastLightLevel;
    //Batteri
    //Baro
    const float ALTITUDE = 34.691; // <-- adapt this value to your own location's altitude.
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
    	STABLE = 0,			// "Stable Weather Pattern"
    	SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
    	CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
    	UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
    	THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
    	UNKNOWN = 5			// "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
       gw.begin(incomingMessage, 9, true));
       gw.sendSketchInfo("Weather Station", "1.0");
    	gw.present(BARO_CHILD, S_BARO);
    	gw.present(TEMP_CHILD, S_TEMP);
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
       gw.sleep(SLEEP_TIME);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
    float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
    	float temperature = bmp.readTemperature();
    	if (!metric)
    		// Convert to fahrenheit
    		temperature = temperature * 9.0 / 5.0 + 32.0;
    	int forecast = sample(pressure);
    	Serial.print("Temperature = ");
    	Serial.print(temperature);
    	Serial.println(metric ? " *C" : " *F");
    	Serial.print("Pressure = ");
    	Serial.print(pressure);
    	Serial.println(" hPa");
    	Serial.print("Forecast = ");
    		gw.send(tempMsg.set(temperature, 1));
    	if (pressure != lastPressure)
    		gw.send(pressureMsg.set(pressure, 0));
    		lastPressure = pressure;
    	if (forecast != lastForecast)
    		gw.send(forecastMsg.set(weather[forecast]));
    		lastForecast = forecast;
    float getLastPressureSamplesAverage()
    	float lastPressureSamplesAverage = 0;
    	for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
    		lastPressureSamplesAverage += lastPressureSamples[i];
    	lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
    	return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
    	// Calculate the average of the last n minutes.
    	int index = minuteCount % LAST_SAMPLES_COUNT;
    	lastPressureSamples[index] = pressure;
    	minuteCount++;
    	if (minuteCount > 185)
    		minuteCount = 6;
    	if (minuteCount == 5)
    		pressureAvg = getLastPressureSamplesAverage();
    	else if (minuteCount == 35)
    		float lastPressureAvg = getLastPressureSamplesAverage();
    		float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
    			dP_dt = change * 2; // note this is for t = 0.5hour
    			dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
    	else if (minuteCount == 65)
    			dP_dt = change; //note this is for t = 1 hour
    			dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
    	else if (minuteCount == 95)
    			dP_dt = change / 1.5; // note this is for t = 1.5 hour
    			dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
    	else if (minuteCount == 125)
    		pressureAvg2 = lastPressureAvg; // store for later use.
    			dP_dt = change / 2; // note this is for t = 2 hour
    			dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
    	else if (minuteCount == 155)
    			dP_dt = change / 2.5; // note this is for t = 2.5 hour
    			dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
    	else if (minuteCount == 185)
    			dP_dt = change / 3; // note this is for t = 3 hour
    			dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
    		pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    	int forecast = UNKNOWN;
    		forecast = UNKNOWN;
    	else if (dP_dt < (-0.25))
    		forecast = THUNDERSTORM;
    	else if (dP_dt > 0.25)
    		forecast = UNSTABLE;
    		forecast = CLOUDY;
    		forecast = SUNNY;
    	else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
    		forecast = STABLE;
    		forecast = UNKNOWN;
    	// uncomment when debugging
    	//Serial.print(F("Forecast at minute "));
    	//Serial.print(minuteCount);
    	//Serial.print(F(" dP/dt = "));
    	//Serial.print(dP_dt);
    	//Serial.print(F("kPa/h --> "));
    	return forecast;
    I get this error:
    Arduino: 1.6.5 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
    Vejrstation_v1.2:31: error: redefinition of 'float lastTemp'
    Vejrstation_v1.2:24: error: 'float lastTemp' previously declared here
    Vejrstation_v1.2:49: error: redefinition of 'boolean metric'
    Vejrstation_v1.2:26: error: 'boolean metric' previously defined here
    Vejrstation_v1.2.ino: In function 'void setup()':
    Vejrstation_v1.2:89: error: 'incomingMessage' was not declared in this scope
    Vejrstation_v1.2:89: error: expected ';' before ')' token
    Vejrstation_v1.2.ino: In function 'void loop()':
    Vejrstation_v1.2:175: error: redeclaration of 'float temperature'
    Vejrstation_v1.2:142: error: 'float temperature' previously declared here
    • HeinzH
      HeinzH
      Heinz
      Wiring is shown here
      http://www.mysensors.org/build/pressure
      The child ids of BARO and LIGHT are both 2 in your sketch.
      N 1 Reply Last reply
      • HeinzH
        HeinzH
        Heinz
        The BMP085 and the DHT have both a temperature: lastTemp of both sketches collide!
        Have a look at this sketch which is a merge of a BMP085 and a DHT
        https://github.com/windkh/mysensors/blob/master/WeatherStationSensor/WeatherStationSensor.ino
        • HeinzH Heinz
          N
          N
          NBM
          @Heinz I know. But is it possible to use A2 and A3?
          HeinzH 1 Reply Last reply
          • N NBM
            HeinzH
            HeinzH
            Heinz
            I don't know.
            • HeinzH
              HeinzH
              Heinz
              wrote on last edited by Heinz
              A function is missing in your case:
              void incomingMessage(const MyMessage &message){}
              N D 2 Replies Last reply
              • HeinzH Heinz
                N
                N
                NBM
                @Heinz Thank you.
                I have made this sketch without errors.
                // DHT-Sensor
                // BMP085 Sensor
                #include <Adafruit_BMP085_U.h>
                #include <Adafruit_Sensor.h>
                const bool sendAlways = true;
                const float SEALEVEL = 688; // Westendorf
                const float SEALEVEL_PRESSURE = 1013.25;
                #define CHILD_ID_HUM 2
                #define CHILD_ID_TEMP 3
                #define CHILD_ID_LIGHT 1
                DHT dht;
                float lastTemp;
                float lastHum;
                #define BARO_CHILD 0
                #define TEMP_CHILD 1
                unsigned long SLEEP_TIME1 = 30000; // 1 minute required for forecast algorithm
                unsigned long SLEEP_TIME2 = 30000; // 1 minute required for forecast algorithm
                unsigned long SLEEP_TIME3 = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
                Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(1);    // Digital Pressure Sensor
                int lastLightLevel;
                DP/Dt explanation
                0 = "Stable Weather Pattern"
                1 = "Slowly rising Good Weather", "Clear/Sunny "
                2 = "Slowly falling L-Pressure ", "Cloudy/Rain "
                3 = "Quickly rising H-Press",     "Not Stable"
                4 = "Quickly falling L-Press",    "Thunderstorm"
                5 = "Unknown (More Time needed)
                const char *weatherStrings[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                enum FORECAST
                  STABLE = 0,     // Stable weather
                  SUNNY = 1,      // Slowly rising HP stable good weather
                  CLOUDY = 2,     // Slowly falling Low Pressure System, stable rainy weather
                  UNSTABLE = 3,   // Quickly rising HP, not stable weather
                  THUNDERSTORM = 4, // Quickly falling LP, Thunderstorm, not stable
                  UNKNOWN = 5     // Unknown, more time needed
                const char *situationStrings[] = { "very low", "low", "normal", "high", "very high" };
                enum WEATHER_SITUATION
                  VERY_LOW_PRESSURE = 0,    // Tiefdruck p>-7.5hPa
                  LOW_PRESSURE = 1,     // Tiefdruck p>-2.5hPa
                  NORMAL_PRESSURE = 2,    // Normal  p <+/-02.5hPa
                  HIGH_PRESSURE = 3,      // Hochdruck p>2.5hPa
                  VERY_HIGH_PRESSURE = 4,   // Hochdruck p>7.5hPa
                float lastPressureTemp = -1;
                int lastSituation = NORMAL_PRESSURE;
                float pressureAvg;
                float pressureAvg2;
                float dP_dt;
                MyMessage situationMsg(BARO_CHILD, V_VAR1);
                MyMessage forecastMsg2(BARO_CHILD, V_VAR2);
                void displaySensorDetails(void)
                  sensor_t sensor;
                  bmp.getSensor(&sensor);
                  Serial.println(F("------------------------------------"));
                  Serial.print(F("Sensor:       ")); Serial.println(sensor.name);
                  Serial.print(F("Driver Ver:   ")); Serial.println(sensor.version);
                  Serial.print(F("Unique ID:    ")); Serial.println(sensor.sensor_id);
                  Serial.print(F("Max Value:    ")); Serial.print(sensor.max_value); Serial.println(F(" hPa"));
                  Serial.print(F("Min Value:    ")); Serial.print(sensor.min_value); Serial.println(F(" hPa"));
                  Serial.print(F("Resolution:   ")); Serial.print(sensor.resolution); Serial.println(F(" hPa"));
                  Serial.println(F(""));
                  delay(500);
                void initPressureSensor()
                  if (!bmp.begin())
                    Serial.println(F("Could not find a valid BMP085 sensor, check wiring!"));
                    while (1) {}
                  displaySensorDetails();
                void initHumiditySensor()
                  gw.begin();
                  gw.sendSketchInfo("Weather Station Sensor", "2.1");
                  initPressureSensor();
                  initHumiditySensor();
                int getWeatherSituation(float pressure)
                  int situation = NORMAL_PRESSURE;
                  float delta = pressure - SEALEVEL_PRESSURE;
                  if (delta > 7.5)
                    situation = VERY_HIGH_PRESSURE;
                  else if (delta > 2.5)
                    situation = HIGH_PRESSURE;
                  else if (delta < -7.5)
                    situation = VERY_LOW_PRESSURE;
                  else if (delta < -2.5)
                    situation = LOW_PRESSURE;
                  return situation;
                bool updatePressureSensor()
                  bool changed = false;
                  sensors_event_t event;
                  bmp.getEvent(&event);
                  if (event.pressure)
                    float absolutePressure = event.pressure;
                    Serial.print(F("abs Pressure = "));
                    Serial.print(absolutePressure);
                    //float altitude = bmp.pressureToAltitude(SEALEVEL_PRESSURE, pressure);
                    //Serial.print(F("Altitude = "));
                    //Serial.print(altitude);
                    //Serial.println(F(" m"));
                    //sealevel pressure p0 from absolute pressure.
                    float pressure = bmp.seaLevelForAltitude(SEALEVEL, absolutePressure);
                    float pressureTemperature;
                    bmp.getTemperature(&pressureTemperature);
                    if (!metric)
                      pressureTemperature = pressureTemperature * 9.0 / 5.0 + 32.0;
                    int situation = getWeatherSituation(pressure);
                    if (sendAlways || (pressureTemperature != lastPressureTemp))
                      changed = true;
                      lastPressureTemp = pressureTemperature;
                      Serial.print(F("Temperature = "));
                      Serial.print(pressureTemperature);
                      Serial.println(metric ? F(" *C") : F(" *F"));
                      if (!gw.send(tempMsg.set(lastPressureTemp, 1)))
                        lastPressureTemp = -1.0;
                    if (sendAlways || (pressure != lastPressure))
                      changed = true;
                      Serial.print(F("sealevel Pressure = "));
                      if (!gw.send(pressureMsg.set(lastPressure, 1)))
                        lastPressure = -1.0;
                    if (sendAlways || (forecast != lastForecast))
                      changed = true;
                      Serial.print(F("Forecast = "));
                      Serial.println(weatherStrings[forecast]);
                      if (gw.send(forecastMsg.set(weatherStrings[lastForecast])))
                        if (!gw.send(forecastMsg2.set(lastForecast)))
                        lastForecast = -1.0;
                    if (sendAlways || (situation != lastSituation))
                      changed = true;
                      lastSituation = situation;
                      Serial.print(F("Situation = "));
                      Serial.println(situationStrings[situation]);
                      if (!gw.send(situationMsg.set(lastSituation, 0)))
                        lastSituation = -1.0;
                  return changed;
                bool updateHumiditySensor()
                  if (!isnan(temperature))
                #ifdef SEND_WHEN_CHANGED
                      if (!metric)
                      changed = true;
                      Serial.print(F("T: "));
                      if (!gw.send(msgTemp.set(temperature, 1)))
                        lastTemp = -1.0;
                    Serial.println(F("Failed reading temperature from DHT"));
                  if (!isnan(humidity))
                      lastHum = humidity;
                      changed = true;
                      Serial.print(F("H: "));
                      if (!gw.send(msgHum.set(lastHum, 1)))
                        lastHum = -1.0;
                    Serial.println(F("Failed reading humidity from DHT"));
                  return changed;
                   #ifdef DEBUG
                   #ifdef DEBUG
                  updatePressureSensor();
                  gw.sleep(SLEEP_TIME1);
                  updateHumiditySensor();
                  gw.sleep(SLEEP_TIME2);
                  gw.sleep(SLEEP_TIME3);
                  //Serial.print(F("### 5min-Average:"));
                  //Serial.print(lastPressureSamplesAverage);
                  //Serial.println(F(" hPa"));
                  minuteCount++;
                    minuteCount = 6;
                    forecast = UNKNOWN;
                    forecast = CLOUDY;
                    forecast = SUNNY;
                    forecast = STABLE;
                    forecast = UNKNOWN;
                  return forecast;
                • HeinzH Heinz
                  Dylano
                  @Heinz
                  Is this sketch working great now?
                  And how is the battery?
                  How long can work this sketch, on what type battery?
                  Domoticz, with a lot of working hardware, include mysensors :-)
                  OpenPLI, RuneAudio, Solarmeter, etc......
                  Not a great builder of software and hardware, more a user...
                  Only i try to do my best :-(
                  • HeinzH
                    HeinzH
                    Heinz
                    @Dylano the sketch in this thread is from @NBM, if you mean
                    then this one is working very well.
                    This one is the official mysensors example
                    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/WeatherStationSensor/WeatherStationSensor.ino
                    • D
                      Dylano
                      still got an error:
                      C:\Users\DM_PC\Desktop\Mysensors 23-2-2015\Sketches Werkend\sketch_mar05a\sketch_mar05a.ino:8:29: fatal error: Adafruit_Sensor.h: No such file or directory
                      Only where can i download the adafruit library?
                      • D Dylano
                        still got an error:
                        HeinzH
                        HeinzH
                        Heinz
                        @Dylano
                        https://github.com/adafruit/Adafruit_Sensor
                        https://github.com/adafruit/Adafruit_BMP085_Unified
                        D 1 Reply Last reply
                        • HeinzH Heinz
                          @Dylano
                          Dylano
                          @Heinz said:
                          @Dylano
                          Thanks!!!
