  3. rboard - Cheap relay/radio/arduino board ~$10
57 Posts 15 Posters 32.9k Views 7 Watching
  • greglG Offline
    greglG Offline
    gregl
    I realise quite a few are building your own PCB's and i admit i really enjoyed the process of designing and producing my first "mysensors" pcb ... but when you find prebuild boards like this for such little money then its hard to ignore...
    So i bought 2 of these today
    http://imall.iteadstudio.com/im140704001.html
    I plan to use one for my garage door controller...the other not sure yet ;-)
    • J Offline
      J Offline
      jendrush
      Nice price. How much for shipping?
      greglG 1 Reply Last reply
      • J jendrush
        greglG Offline
        greglG Offline
        gregl
        @jendrush
        About $4 to Australia... I think my last order only took about a week....I was amazed!
        I'll try remember to post back when it arrives.
        • K Offline
          K Offline
          korttoma
          Nice find. Please let us now how they perform.
          • Tomas
          • greglG Offline
            greglG Offline
            gregl
            Finally got the email they are on the way....will report in when ive tested them,
            • greglG Offline
              greglG Offline
              gregl
              And they just arrived... 6days ..not too bad!
              Now to test!
              • greglG Offline
                greglG Offline
                gregl
                Well that was easy....
                Loaded up the RelayActuator sketch, changed the relay pin to 4.
                It joined Vera as it should, and after providing it a 5V powersource the relay clicks on and off as commanded!
                • greglG Offline
                  greglG Offline
                  gregl
                  Now loaded up the Garage Door sketch , choosing A0 for the switch and D4 for the relay and again works straight away!
                  I note they also have a header for 433Mhz module and according to the schematic, the pads could be used for 5v,GND, and D3 - so could be used for another sensor such as Dallas temp....or ultrasonic/IR..anything!
                  Great buy for $10
                  ftp://imall.iteadstudio.com/Mainboard/IM140704001_mini_Rboard/SCH_IM140704001_MiniRboard.pdf
                  • D Offline
                    daulagari
                    Good price but a pity you still need an external 5 Volts supply...
                    • greglG Offline
                      greglG Offline
                      gregl
                      Yep no getting away from the need for power! A mains version would be great, but although it only adds a few $ in electronics, getting all the approvals adds $$$. But for DIY'ers adding a phone powersupply is cheap and reasonably compact.
                      • K Offline
                        K Offline
                        korttoma
                        Yeah it seems like a really nice board but it could have had access to a few more digital pins on the board.
                        Is it really only A0 and D3 that can be accessed other then the relay?
                        • Tomas
                        Z 1 Reply Last reply
                        • K korttoma
                          Z Offline
                          Z Offline
                          Zeph
                          Looks like. Surprising that folks don't at least put a few more pins on solderable holes on boards like this, where you could put a pin or solder a wire - seems easy and takes little space.
                          • HomerH Offline
                            HomerH Offline
                            Homer
                            Hey! my first post :-)
                            I read about these boards here a week or so ago, and order one to play with! Just waiting on my Vera to arrive and I'm gonna start playing :-)
                            • D Offline
                              derrij
                              it is possible to add hardware button to the setup and control the relay.
                              H 1 Reply Last reply
                              • D derrij
                                H Offline
                                H Offline
                                wrote on last edited by hek
                                @derrij
                                Yes, here in an example:
                                https://codebender.cc/sketch:47534
                                Y 1 Reply Last reply
                                • H hek
                                  @derrij
                                  Y Offline
                                  Y Offline
                                  @hek there's no code visible on android.....
                                  • Y Yveaux
                                    H Offline
                                    H Offline
                                    @Yveaux
                                    I can see it on my chrome/android.
                                    Update: The stock browser also works.
                                    • H hek
                                      @Yveaux
                                      Y Offline
                                      Y Offline
                                      @hek now it is working... Did you change anything?
                                      • Y Yveaux
                                        H Offline
                                        H Offline
                                        @Yveaux
                                        Nope.
                                        • HomerH Offline
                                          HomerH Offline
                                          Homer
                                          Which board do I choose when uploading a sketch to this?
                                          12.1k
