  3. 💬 AC/DC/Batteries capable atmega328p board
regulatoratmega328atsha204aflashbatterypower supplynrf24l01
20 Posts 7 Posters 10.6k Views 6 Watching
  • G Offline
    G Offline
    GertSanders
    @Carl-H If you use the V+ and V- inputs which are normally used for batteries, then you may also need to bridge the BAT solder jumper on the bottom of the board, but ONLY if the battery gives 3V6 maximum.
    This will connect the 3V3 power rail to VCC.
    If you are using a FTDI interface, this one already powers VCC and via the AMS1117 also gives 3V3 to the NRF.
    The question is which V+ terminal did you use ???
    Can you post an image of your board ?
    The two inputs below give direct connection to VCC (for 5V input):
    The following inputs are for an optional DC converter, and do NOT connect to VCC.
    • G Offline
      G Offline
      GertSanders
      @Carl-H I do not have any DHT22 to test and never have used them, so I do not know how you connect them.
      So I'm not sure what can be wrong. The DHT22 seems sensitive to timing according to documentation on the Adafruit website.
      • Carl HC Offline
        Carl HC Offline
        Carl H
        This is my board:
        I don't want to use the bat jumber because my source is by USB plug (5v).
        My question is why is it working when I plug with my FTDI Cable (5v version).
        I will try tonight with other sensor like Si7021 but i'm pretty sure it will be working.
        G 1 Reply Last reply
        • Carl HC Carl H
          This is my board:
          G Offline
          G Offline
          GertSanders
          @Carl-H I see that you are connected to D6 (not D7 as you mentioned earlier).
          • Carl HC Offline
            Carl HC Offline
            Carl H
            wrote on last edited by Carl H
            I wrote D7 but in my sketch is D6 ;)
            #define DHT_PIN 6
            A 1 Reply Last reply
            • Carl HC Carl H
              #define DHT_PIN 6
              A Offline
              A Offline
              AWI
              @Carl-H did you add a pull up? The DHT can be unstable without.
              Carl HC 1 Reply Last reply
              • G Offline
                G Offline
                GertSanders
                Added a sketch for a combination of 1 PIR, 2 relays and HTU21D Temperature/Humidity.
                • A AWI
                  Carl HC Offline
                  Carl HC Offline
                  Carl H
                  @AWI Yes I have pull up !
                  • Carl HC Offline
                    Carl HC Offline
                    Carl H
                    After make some test this morning I found a solution but I do not know why and what is the difference.
                    I explain:
                    When I used this DHT librairies (https://github.com/markruys/arduino-DHT), this one come with mysensors librairies. I can read my DHT22 sensor with my FTDI cable but is not working with from a DC 5v in, reading always 0.
                    But If now I used this librairies (https://github.com/adafruit/DHT-sensor-library) , is working with FTDI cable and now with my DC 5v in.
                    • Carl HC Carl H
                      I explain:
                      G Offline
                      G Offline
                      GertSanders
                      @Carl-H Very strange indeed, but I'm glad it is sorted out.
                      • alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @Carl-H I have used DHT11/22, DS18B20, SI7021, HTU21D, BMP180 and BME280 sensors with Arduino / Particle Photon and I can only suggest using SI7021, HTU21D and BMP180/BME280 temperature and humidity sensors. DS18B20 is very sensitive to noises and throwing temperature abnormal readings (65000C or something). DHT22 is very temperamental needless to say about the size. Also the sensors I suggested are very-very precise. BME280 being probably the most expensive.
                        • Carl HC Offline
                          Carl HC Offline
                          Carl H
                          @GertSanders I have a couple of your board and I will be very happy. Now I will want to try the OTA feature with this board. Did you have DualOptiboot already compiled (hex file) with D8 led pin and with 8 mhz external crystal? It will be cool you include this file like Optiboot 6.2.. Thanks
                          • Carl HC Carl H
                            G Offline
                            G Offline
                            GertSanders
                            @Carl-H
                            The EEPROMs on this boards are of the I2C type and this is not supported by DualOptiboot, so unfortunatly you can not use OTA on this board.
                            OTA is only supported with SPI type flash memory.
                            I also do not have the sourcefiles for DualOptiboot to recompile it with my D8 LED flashing. At the moment I have to concentrate on other tasks at home, but recompiling DualOptiboot to my own desires is on my TODO list for this year (I hope).
                            • G GertSanders
                              @Carl-H
                              Carl HC Offline
                              Carl HC Offline
                              Carl H
                              @GertSanders oh thanks, I have made an error... Maybe it will be working with MYSBootloader 1.3pre2 because he don't require any external memory.. Did you try before?
                              • Carl HC Carl H
                                G Offline
                                G Offline
                                GertSanders
                                @Carl-H
                                No, so far I have not experimented with OTA on this board or any of my boards.
                                Someone has used OTA on one of my other (batterybased) boards, because that one has an SPI Flash footprint.
                                When I get back to doing more MySensor stuff I will be experimenting with OTA. Being a Mac user my options are a bit limited now.
                                • MiKaM Offline
                                  MiKaM Offline
                                  MiKa
                                  please add order number or ebay link for enclosure (box)
                                  THX!
                                  • MiKaM MiKa
                                    THX!
                                    @MiKa which box are you referring to?
                                    Generic boxes are available here: https://www.mysensors.org/store/boxes
