  3. 💬 AC/DC/Batteries capable atmega328p board
regulatoratmega328atsha204aflashbatterypower supplynrf24l01
20 Posts 7 Posters 10.7k Views 6 Watching
  • Carl HC
    Carl HC
    Carl H
    wrote on last edited by Carl H
    I wrote D7 but in my sketch is D6 ;)
    #define DHT_PIN 6
    AWIA 1 Reply Last reply
    • Carl HC Carl H
      #define DHT_PIN 6
      AWIA
      AWIA
      AWI
      @Carl-H did you add a pull up? The DHT can be unstable without.
      Carl HC 1 Reply Last reply
      • GertSandersG
        GertSandersG
        GertSanders
        Added a sketch for a combination of 1 PIR, 2 relays and HTU21D Temperature/Humidity.
        • AWIA AWI
          Carl HC
          Carl HC
          Carl H
          @AWI Yes I have pull up !
          • Carl HC
            Carl HC
            Carl H
            After make some test this morning I found a solution but I do not know why and what is the difference.
            I explain:
            When I used this DHT librairies (https://github.com/markruys/arduino-DHT), this one come with mysensors librairies. I can read my DHT22 sensor with my FTDI cable but is not working with from a DC 5v in, reading always 0.
            But If now I used this librairies (https://github.com/adafruit/DHT-sensor-library) , is working with FTDI cable and now with my DC 5v in.
            • Carl HC Carl H
              I explain:
              GertSandersG
              GertSandersG
              GertSanders
              @Carl-H Very strange indeed, but I'm glad it is sorted out.
              • alexsh1A
                alexsh1A
                alexsh1
                @Carl-H I have used DHT11/22, DS18B20, SI7021, HTU21D, BMP180 and BME280 sensors with Arduino / Particle Photon and I can only suggest using SI7021, HTU21D and BMP180/BME280 temperature and humidity sensors. DS18B20 is very sensitive to noises and throwing temperature abnormal readings (65000C or something). DHT22 is very temperamental needless to say about the size. Also the sensors I suggested are very-very precise. BME280 being probably the most expensive.
                • Carl HC
                  Carl HC
                  Carl H
                  @GertSanders I have a couple of your board and I will be very happy. Now I will want to try the OTA feature with this board. Did you have DualOptiboot already compiled (hex file) with D8 led pin and with 8 mhz external crystal? It will be cool you include this file like Optiboot 6.2.. Thanks
                  • Carl HC Carl H
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @Carl-H
                    The EEPROMs on this boards are of the I2C type and this is not supported by DualOptiboot, so unfortunatly you can not use OTA on this board.
                    OTA is only supported with SPI type flash memory.
                    I also do not have the sourcefiles for DualOptiboot to recompile it with my D8 LED flashing. At the moment I have to concentrate on other tasks at home, but recompiling DualOptiboot to my own desires is on my TODO list for this year (I hope).
                    • GertSandersG GertSanders
                      @Carl-H
                      Carl HC
                      Carl HC
                      Carl H
                      @GertSanders oh thanks, I have made an error... Maybe it will be working with MYSBootloader 1.3pre2 because he don't require any external memory.. Did you try before?
                      • Carl HC Carl H
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @Carl-H
                        No, so far I have not experimented with OTA on this board or any of my boards.
                        Someone has used OTA on one of my other (batterybased) boards, because that one has an SPI Flash footprint.
                        When I get back to doing more MySensor stuff I will be experimenting with OTA. Being a Mac user my options are a bit limited now.
                        • MiKaM
                          MiKaM
                          MiKa
                          please add order number or ebay link for enclosure (box)
                          THX!
                          • MiKaM MiKa
                            THX!
                            @MiKa which box are you referring to?
                            Generic boxes are available here: https://www.mysensors.org/store/boxes
