  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 34.8k Views 16 Watching
  • Dombo71D Dombo71
    Dear
    I ordered a few...:-)
    Do you have a working sketch that is using less power?
    Perhaps wit a motionsensor and a DHt ore something
    I hope i get you hardware working..
    alexsh1A
    alexsh1A
    alexsh1
    @Dombo71 said:
    Dear
    @Dombo71
    You can find a few working sketches in the 'Build' section of the website. However, don't you have an idea what it is exactly you'd like to build? I would be useful to know before throwing any sketch.
    FYG DHT is by far not a favourite one for a battery use in my view. There are others - SI7120 or BME280
    • Dombo71D Dombo71
      Dear
      GertSandersG
      GertSandersG
      GertSanders
      @Dombo71
      What do you mean with "using less power"?
      D 1 Reply Last reply
      • Dombo71D Dombo71
        Dear
        GertSandersG
        GertSandersG
        GertSanders
        @Dombo71
        Motion sensors are also not so low power and as mentioned before, DHT are power hungry. SI7021 is much better for low power/low voltage use.
        • GertSandersG GertSanders
          @Dombo71
          Dylano
          @GertSanders said:
          SI7021
          I hope i can make a 3 in 1 sensor
          Motion / contact.
          temp and humanity
          Better should be a multisensor, with a lot of option so we can choose .
          The examples on my sensor are most 1 sensor...
          And then work on a battery[s] for a year
          Thanks for the SI7021 tip..
          Domoticz, with a lot of working hardware, include mysensors :-)
          OpenPLI, RuneAudio, Solarmeter, etc......
          Not a great builder of software and hardware, more a user...
          Only i try to do my best :-(
          • D Dylano
            @GertSanders said:
            SI7021
            Motion / contact.
            temp and humanity
            GertSandersG
            GertSandersG
            GertSanders
            #40
            @Dylano
            This board is not meant for more then 1 function.
            • alexsh1A
              alexsh1A
              alexsh1
              @Dylano Have a look at this board - this would let you program via FTDI and connect several sensors.
              http://forum.mysensors.org/topic/2744/battery-based-atmega328p-sensor-no-smd
              • alexsh1A
                alexsh1A
                alexsh1
                @GertSanders How snug is your enclosure? I saw @m26872 used 17x20mm for his slim node, but I was able to find in the UK 16x16mm trunking, which I think maybe a little bit small.
                GertSandersG 2 Replies Last reply
                • alexsh1A alexsh1
                  GertSandersG
                  GertSandersG
                  GertSanders
                  #43
                  @alexsh1
                  I also use a 16x16mm cable guide and it just fits, the batteries are in batteryholders and therefor they stick out by 1mm. Without the batteryholder they fit perfectly.
                  The board is 13mm wide at the base which allows passing a few wires next to it. So 16x16 is ok for my narrow board.
                  • alexsh1A alexsh1
                    GertSandersG
                    GertSandersG
                    GertSanders
                    #44
                    @alexsh1
                    Here are some images of the very narrow node in a 16x16mm cable duct. The batteries are AAA type.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @GertSanders - Thanks for photos. I have got 16x16mm trunking and just waiting for some spare parts. Will be posting photos shortly.
                        @alexsh1
                        Dylano
                        @GertSanders
                        This option with a pir...
                        or a magnet sensor.
                        What is the battery live?
                        alexsh1A 1 Reply Last reply
                        • D Dylano
                          @GertSanders
                          or a magnet sensor.
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #47
                          @Dylano said:
                          @GertSanders
                          or a magnet sensor.
                          This is more a reed sensor. For PIR the size is just not right IMHO.
                          Given that it sleeps most of the time, the battary life should be excellent.
                          I do not know, maybe @GertSanders has got more comments?
                          • alexsh1A alexsh1
                            @Dylano said:
                            @GertSanders
                            or a magnet sensor.
                            GertSandersG
                            GertSandersG
                            GertSanders
                            #48
                            @alexsh1 with a switch (reed or mechanical) i see a consumption of around 5micro amperes in sleep mode. 2 AAA should last minimum a year. We will see as my node is only started last week.
                            A small PIR sensor is possible, see the "small AA project" and the mini PIR example.
                            http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                            No idea what lifetime to expect there.
                            • T
                              TimO
                              I've just ordered a batch of these. Really cool, I can't wait to receive them. Thanks for the great work!
                              • B
                                B
                                Bolliebol
                                YES, my first is working. More to make. In my home now: "Big brother is watching you" Placed my first at the door of the refrigerator ;-)
                                @GertSanders, you write:
                                powering something with low consumption
                                You can set both pins D2 and D3 of the processor to OUTPUT, do not mount the pull up resistors, do not activate the internal PullUPs, and by setting one of the pins to HIGH and the other to LOW you can power something. You will need to take care that a maximum of 20mA is consumed, as this is the recommended maximum amperage the pins of the atmega328 can drive or source.
                                Sure not to mount the pull up resistors. But how do de-activate the internal PullUPs, and by setting one of the pins to HIGH and the other to LOW.
                                Can you explain in "jip en Janneke/suske en wiske" language how to. With the help of this site I made my first one:
                                https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5
                                • B Bolliebol
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @Bolliebol
                                  You need to use these instructions:
                                  pinMode(2, OUTPUT);
                                  digitalWrite(2, HIGH);
                                  pinMode(3, OUTPUT);
                                  digitalWrite(2, LOW);
                                  // this makes pin 2 the "plus" side and pin 3 the "minus" side.
                                  // Connect your low power consuming thing between these two pins as if they are battery pins.
                                  // If you need to power off the device, just do
                                  digitalWrite(2,LOW);
                                    To anyone wanting to build this project: take note that it uses machine pin female headers to seat the mcu. Ordinary female headers won't make a good enough connection with the legs of the atmega328.
                                    • Carl HC
                                      Carl HC
                                      Carl H
                                      Hi, I have finally receive your narrow board.. I try with a Si7021 sensor (the GY-21 ebay version) and I have no success. But with your other board, because I have your 2 other board version (ac/dc board and the small battery one) it's working with no problem. The difference I think is the first board without external crystal. After reading in forum, I think with Slim board version, i'm not the first with this problem. Did you test your board with si7021 sensor, or can you give my a clue ?? Thanks
                                      • Carl HC Carl H
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @Carl-H did you have an error message? Providing logs would also help. Which address and library did you use for this sensor please?
                                        Carl HC 1 Reply Last reply
                                        • alexsh1A alexsh1
                                          Carl HC
                                          Carl HC
                                          Carl H
                                          @alexsh1 I use the this lib: https://github.com/LowPowerLab/SI7021 My board freeze when initialize with begin function.
                                          I can't have the error exactly because this board don't have any FTDI connection. But the same atmega328p chip with other board, it's working !! I think again is it because the board use internal oscillator.
                                          alexsh1A GertSandersG 2 Replies Last reply
