  3. Curtain Control Node.
domoticzcurtain controlmysensors node
51 Posts 15 Posters 29.0k Views 22 Watching
  • Suresh MaliS Offline
    Suresh Mali
    wrote on last edited by Suresh Mali
    My First version of curtain control Node is ready, installed and tested. Some work is pending, which I'll complete on my weekend.
    Edit: Code for the Node:Curtain Node
    Please share your feedback so that I can improvise.
    • H Offline
      H Offline
      What type of motor are you using?
        Suresh Mali
        Its a Geared DC Motor with Voltage Rating of 6-12V and 100 RPM. I am using a L239 to control the motor.
        • A Offline
          A Offline
          AWI
          Looks good. I am curious to see the details... jealous for the speed :runner: your curtain is moving.
          I have been working on a similar project last week. The mechanics and ´looks´ are the most difficult part for me.
          For now I have used a ´tuned´ cheap & small stepper which makes it slooow but effective ;-) The rail and mounting is standard IKEA. The pro-mini has the jModule attached. Works like a charm (/snail)!
          0_1457980545567_upload-c50fc1e9-f23e-458d-a812-62ad4bf478e0
          0_1457981153586_upload-c7064209-3900-4e4b-b335-8c88721367c0
            Suresh Mali
            @AWI Thanks. Why dont you increase the pulley size (larger pulley) that will increase the speed.
            I found driving stepper motor to be bit more complicated than driving a DC motor. I picked the Geared motor basis the calculation using this calculator.
            Since without rails pulling the curtains on a metal pipe needed more torque. Thus I chose 100 RPM to be a suitable fit.
            Will share the Schematics and PCB layout files soon. I have already added the sketch for reference. Since I was testing I did not put the circuit in any housing. But will give some shape soon.
            Also will be adding 3 buttons for Manual Control.
            • barduinoB Offline
              barduinoB Offline
              barduino
              @Suresh-Mali
              DC Motor, very interesting!
              Do you have end stops? The sketch doesn't open for some reason...
              Suresh MaliS S 2 Replies Last reply
              • barduinoB barduino
                @Suresh-Mali
                Suresh Mali
                @barduino I tried downloading the code, it works. Anyways I am pasting the code below.
                For end stops I have not yet decided. I had some Ideas of using Hall effect sensor on both ends and a small piece of magnet in the string to detect ends or Maybe use stop switches. Not sure but will have to try both and see which works the best.
                I am yet to clean the code I have some debugging serial prints in code which will remove once finalized.
                int motor_forward = 5;
                int motor_reverse = 6;
                int LDRinput = 1;     //analog pin to which LDR is connected, here we set it to 0 so it means A0
                int LDRValue = 0;      //that�s a variable to store LDR values
                int light_sensitivity = 500;    //This is the approx value of light surrounding your LDR
                int stopSwLeft = 4;
                int stopSwRight = 3;
                int stopSwNow = 2;
                int CHILD_CURTAIN_ID =1;
                int lastState;
                MyMessage msg_S_COVER_U(CHILD_CURTAIN_ID, V_UP);
                MyMessage msg_S_COVER_D(CHILD_CURTAIN_ID, V_DOWN);
                MyMessage msg_S_COVER_S(CHILD_CURTAIN_ID, V_STOP);
                //MyMessage msg(CHILD_CURTAIN_ID,V_UP);
                // the setup routine runs once when you press reset:
                	// initialize the digital pin as an output for L239D.
                	pinMode(motor_forward, OUTPUT);
                	pinMode(motor_reverse, OUTPUT);
                	// initialize the digital pin as an output for Stop Switches.
                	pinMode(stopSwLeft, INPUT_PULLUP);
                	pinMode(stopSwRight, INPUT_PULLUP);
                	pinMode(stopSwNow, INPUT_PULLUP);
                	gw.sendSketchInfo("Window_Curtain", "1.0");
                	gw.present(CHILD_CURTAIN_ID, S_COVER);
                void loop(){
                void cover(int coverVal){
                	//int coverVal = gw.loadState(CHILD_CURTAIN_ID);
                	Serial.print("Cover is : ");
                	lastState = coverVal;
                	switch (coverVal) {
                	case 0:
                		Serial.println("Opening");
                			while (lastState == coverVal)
                				m_left();
                				checkHWInnputs();
                			gw.send(msg_S_COVER_U.set(V_UP));
                	case 1:
                		Serial.println("Closing");
                				m_right();
                				checkHWInnputs();
                			gw.send(msg_S_COVER_D.set(V_DOWN));
                	case 2:
                		Serial.println("Idle");
                					m_stop();
                					checkHWInnputs();
                			gw.send(msg_S_COVER_S.set(V_STOP));
                	return;
                	Serial.println("recieved incomming message");
                	switch (message.type) {
                	case V_UP:
                		gw.saveState(CHILD_CURTAIN_ID, 0);
                		Serial.println("V_UP");
                		cover(gw.loadState(CHILD_CURTAIN_ID));
                		Serial.print("Done cover procedure");
                		//m_right();
                	case V_DOWN:
                		gw.saveState(CHILD_CURTAIN_ID, 1);
                		Serial.println("V_DOWN");
                		//m_left();
                	case V_STOP:
                		gw.saveState(CHILD_CURTAIN_ID, 2);
                		Serial.println("V_STOP");
                		//m_stop();
                	Serial.print("exiting incoming message");
                	return;
                // the loop routine runs over and over again forever:
                void m_right() {
                	digitalWrite(motor_forward, HIGH); //terminal D1 will be HIGH
                	digitalWrite(motor_reverse, LOW); //terminal D2 will be LOW
                	Serial.print("Set For:High and Rev: Low");
                	exit;
                void m_left() {
                	digitalWrite(motor_forward, LOW); //terminal D1 will be LOW
                	digitalWrite(motor_reverse, HIGH); //terminal D2 will be HIGH
                	Serial.print("Set For:Low and Rev: High");
                	exit;
                void m_stop() {
                	digitalWrite(motor_reverse, LOW); //terminal D2 will be HIGH
                	Serial.print("Set For:Low and Rev: Low");
                	exit;
                void checkHWInnputs()
                		if (digitalRead(stopSwNow) == LOW)
                			Serial.println("Detected stop button push. Stopping");
                			cover(2);
                			Serial.println("Saved stop state to EEPROM");
                		if (digitalRead(stopSwLeft) == LOW)
                			cover(1);
                		if (digitalRead(stopSwRight) == LOW)
                			cover(0);
                barduinoB 1 Reply Last reply
                • franzelareF Offline
                  franzelareF Offline
                  franzelare
                  Sweet!
                  My girl has put this on my todolist...
                  But still have to get started, this is some nice reference for my new porject!
                  Suresh MaliS 1 Reply Last reply
                  • franzelareF franzelare
                    Sweet!
                    Suresh Mali
                    @franzelare Great. Good Luck with the build.
                    I'll be posting my HW design and Code as part of Contest on openhardware.io
                      Suresh Mali
                      I have published my project with all the files.
                      https://www.openhardware.io/view/45/Curtain-Control-Node
                      • Suresh MaliS Suresh Mali
                        int stopSwLeft = 4;
                        int stopSwNow = 2;
                        int lastState;
                        void loop(){
                        	switch (coverVal) {
                        	case 0:
                        				m_left();
                        				checkHWInnputs();
                        	case 1:
                        				m_right();
                        				checkHWInnputs();
                        	case 2:
                        					m_stop();
                        					checkHWInnputs();
                        	return;
                        	case V_UP:
                        		//m_right();
                        	case V_DOWN:
                        		//m_left();
                        	case V_STOP:
                        		//m_stop();
                        	return;
                        void m_right() {
                        	exit;
                        void m_left() {
                        	exit;
                        void m_stop() {
                        	exit;
                        			cover(2);
                        			cover(1);
                        			cover(0);
                        barduinoB Offline
                        barduinoB Offline
                        barduino
                        @Suresh-Mali
                        I'm just curious, maybe its the arduino IDE version or something.
                        I'm using 1.6.4 and I get this:
                        0_1458129604092_upload-1364c257-d6a3-46d0-bdec-ff24cf9d2b41
                        However opening with a text editor is fine:
                        0_1458129652911_upload-e1883418-162b-4aba-bacf-d3e85436cca7
                          @Suresh-Mali
                          Suresh Mali
                          @barduino Seems like the IDE. Open any example MySensors Sketch. Delete the contents from sketch and copy paste from my sketch. I guess that should work.
                          Are you able to compile any other sketch in Arduino?
                          • P Offline
                            P Offline
                            patchmaster
                            @AWI Are you able to share the sketch you used with the UL2003 driver board? I have tried to combine the MySensors servo sketch with other arduino only sketches utilizing the UL2003, but without luck. Thanks.
                            Suresh MaliS A 2 Replies Last reply
                            • P patchmaster
                              Suresh Mali
                              @patchmaster I used the relay sketch and modified it to my needs. Sorry but I dont have any sketch for ULN2003. :disappointed:
                              • P patchmaster
                                A Offline
                                A Offline
                                AWI
                                @patchmaster This is my current curtain control sketch. I work with the development branch, so the syntax can be a little different.
                                The Accelstepper library gives you all the abilities to slow start/stop with numerous kinds of steppers.
                                My sketch includes a calibration function (stored in EEPROM) so the you don't need end stop detection (a stepper knows where it is)
                                 PROJECT: MY Sensors curtain controller
                                 PROGRAMMER: AWI
                                 DATE: march 11, 2016
                                 FILE: AWI stepper1.ino
                                 LICENSE: Public domain
                                 Hardware: ATMega328p board w/ NRF24l01
                                	and MySensors 2.0 (Development)
                                Special:
                                	uses AccelStepper library
                                Summary:
                                	Curtain control with stepper motor.
                                	Manual operation with 1 push button
                                	Calibration with manual button
                                Remarks:
                                	Fixed node-id
                                Change log:
                                20160312 - Cleanup
                                #define MY_NODE_ID 13											// fixed node number
                                // stepper library
                                #include <AccelStepper.h>										// http://www.airspayce.com/mikem/arduino/AccelStepper/
                                #define HALFSTEP 8  											// Stepper uses "Halfstep" mode
                                // button library
                                // used for:
                                // - manual open close - single click: close/ stop/ open/ stop
                                // - calibration  - after long press: open calibarion- until single press - closed calibration - until single press (stop)
                                #include <Button.h>												// https://github.com/JChristensen/Button
                                #define CHILD_ID 1   											// Id of the sensor child
                                #define SN "Curtain control 13"
                                #define SV "1.0"
                                #define buttonPin1 7  											// Arduino pin connected to buttonPin1
                                #define buttonPin2 A0  											// Arduino pin connected to buttonPin2 (fixed to ground)
                                // Motor pin definitions
                                #define motorPin1  3     										// IN1 on the ULN2003 driver 1
                                #define motorPin2  4     										// IN2 on the ULN2003 driver 1
                                #define motorPin3  5     										// IN3 on the ULN2003 driver 1
                                #define motorPin4  6     										// IN4 on the ULN2003 driver 1
                                const unsigned long heartbeatInterval = 1 * 3600UL * 1000UL ;	// heartbeatinterval
                                unsigned long heartbeatCounter = 0 ;
                                // helper routines to store and retrieve long in mysensors EEPROM
                                union {															// used to convert long to bytes for EEPROM storage
                                	long longInt;
                                	uint8_t LongByte[4];
                                	} convLongInt ;
                                void saveStateL(int EEposition, long StateL){
                                	convLongInt.longInt = StateL ;
                                	for (int y = 0; y < 4 ; y++){								// convert to bytes
                                		saveState(EEposition + y , convLongInt.LongByte[y]) ;
                                	Serial.print("State saved: "); Serial.println(StateL);
                                long loadStateL(int EEposition){
                                	for (int y = 0; y < 4 ; y++){								// convert from bytes
                                		convLongInt.LongByte[y] = loadState(EEposition + y) ;
                                	Serial.print("State read: "); Serial.println(convLongInt.longInt);
                                	return convLongInt.longInt ;
                                // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
                                AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
                                // Initialize button active low, debounce and internal pull-up
                                Button myBtn(buttonPin1, true, true, 40);						// Initiate the button (pin, pull_up, invert, debounce_ms)
                                MyMessage percentageMsg(CHILD_ID, V_PERCENTAGE);				// used to send updates to controller
                                const long maxRun = 4000000L ;									// maximum runway
                                long setPosition = 0 ; 											// remembers set position, need to be saved in EEPROM
                                const int setPositionEE = 4 ;									// eeprom location
                                long openPosition = 0 ; 										// Position at open, need to be saved in EEPROM?
                                const int openPositionEE = setPositionEE + 4 ;					// eeprom location
                                long closedPosition = 120000UL ; 								// Position at full close, need to be saved in EEPROM
                                const int closedPositionEE = openPositionEE + 4 ;				// eeprom location
                                unsigned long idleTimer = millis() ;							// return to idle timer
                                unsigned long idleTime = 100000UL ;								// return to idle after 100 secs
                                unsigned long printTimer = millis() ;							// print timer
                                unsigned long printTime = 1000UL ;								// print after 1 secs
                                enum position_t {Open, Close, Idle, Running} ;
                                position_t lastDirection = Open ; 								// lastDirection only for buttonpress
                                position_t runStatus = Idle ;									// indicates current status for running motor. used for status reporting to controller
                                enum State_t {sIdle, sCalibrateOpen, sCalibrateClose} ;
                                State_t State = sIdle ;
                                	// setup buttons
                                	pinMode(buttonPin1, OUTPUT);
                                	stepper1.setMaxSpeed(2000.0);
                                	stepper1.setAcceleration(1000.0);
                                	//saveStateL(closedPositionEE, closedPosition) ; 			// INIT: save closed position in EEPROM
                                	closedPosition = loadStateL(closedPositionEE) ;				// need to get last values from EEPROM and assume the current position is correct
                                	setPosition = loadStateL(setPositionEE) ;
                                	stepper1.setCurrentPosition(setPosition );
                                }//--(end setup )---
                                  present(CHILD_ID, S_COVER, "Curtain");						// Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
                                  // Register the LED Dimmable Light with the gateway
                                  sendSketchInfo(SN, SV);
                                unsigned int now = millis() ;								// current time for loop
                                // simple state machine for button press
                                	myBtn.read();
                                	switch (State) {
                                        // Idle state, waiting for some action
                                		// - button press
                                		// - idleTimer
                                        case sIdle:
                                            if (myBtn.wasReleased()){						// idle
                                				Serial.println("Button release") ;
                                				// if running stop
                                				if (stepper1.isRunning()){
                                					setPosition = stepper1.currentPosition();
                                					stepper1.moveTo(setPosition) ;			// move to current position (was already there..)
                                				} else if (lastDirection == Open) {
                                					stepper1.moveTo(closedPosition) ;
                                					lastDirection = Close ;
                                				} else {									// lastDirection == Close
                                					stepper1.moveTo(openPosition) ;
                                			} else if (myBtn.pressedFor(3000)){				// move to calibratete state with long press
                                				Serial.println("Button press long") ;
                                				idleTimer = now ;							// return to idle after ...
                                				State = sCalibrateOpen ;
                                				stepper1.move(-maxRun) ;					// let the stepper open with maximum
                                			break ;
                                		// if not running and last action was open close ;  else open
                                		// if longpress Calibrate open
                                        case sCalibrateOpen:           						// calibration going on
                                			if (myBtn.wasPressed()){
                                				stepper1.setCurrentPosition(0 );		// set new 0 position ??
                                				openPosition = setPosition = 0 ;
                                				State = sCalibrateClose ;					// next is close calibarion
                                				stepper1.move(maxRun) ;						// let the stepper close with maximum
                                			} else if (now > idleTimer + idleTime) {		// timer expired -> abort calibration
                                				State = sIdle ;
                                			break ;
                                        case sCalibrateClose:								// calibrate closed position, end with keypress
                                			if (myBtn.wasPressed())	{
                                				closedPosition = setPosition = stepper1.currentPosition() ;
                                				saveStateL(closedPositionEE, closedPosition) ; // save closed position in EEPROM
                                				State = sIdle ;
                                				stepper1.moveTo(openPosition) ;				// return to open after calibration
                                				State = sIdle ;
                                			break ;
                                		default :
                                			break ;
                                	// power off stepper if not running (no need to reenable))
                                	if (!stepper1.isRunning()){
                                		if (runStatus != Idle){								// there was a change in runningstatus, so report to controller
                                			setPosition = stepper1.currentPosition() ;		// store in EEPROM and report ready to controller
                                			saveStateL(setPositionEE, setPosition) ;
                                			send( percentageMsg.set((100 * setPosition)/(closedPosition - openPosition))) ;
                                			runStatus = Idle ;
                                		stepper1.disableOutputs();
                                		runStatus = Running ;
                                	stepper1.run();
                                	if (printTimer++ > now + printTime){
                                		printTimer = now ;
                                		Serial.println(stepper1.currentPosition());
                                // This is called when a message is received
                                // We only expect few types of messages from controller, check which
                                	case V_PERCENTAGE:
                                	// Curtain should be opened
                                	stepper1.moveTo(message.getInt() * (closedPosition - openPosition)/100);
                                	Serial.print("Message: "); Serial.print(message.sensor); Serial.print(" , value: % "); Serial.println( message.getInt());
                                	Serial.print("Moving to: "); Serial.println(message.getInt() * (closedPosition - openPosition)/100);
                                	break ;
                                	case V_STATUS:
                                	// Curtain should be opened or closed full
                                	stepper1.moveTo((message.getInt() == HIGH)?openPosition:closedPosition);
                                	Serial.print("Message - valid: ");
                                	break ;
                                	default :
                                	// not recognizable message
                                	Serial.print(", Unrecognized ");
                                	break ;
                                P Tore André RosanderT A 3 Replies Last reply
                                • A AWI
                                   PROGRAMMER: AWI
                                  Special:
                                  Summary:
                                  Remarks:
                                  	Fixed node-id
                                  Change log:
                                  20160312 - Cleanup
                                  // stepper library
                                  // button library
                                  // used for:
                                  #define SV "1.0"
                                  	long longInt;
                                  	} convLongInt ;
                                  	// setup buttons
                                  	myBtn.read();
                                  	switch (State) {
                                  		// - button press
                                  		// - idleTimer
                                          case sIdle:
                                  				// if running stop
                                  			break ;
                                  				State = sIdle ;
                                  			break ;
                                  				State = sIdle ;
                                  				State = sIdle ;
                                  			break ;
                                  		default :
                                  			break ;
                                  			runStatus = Idle ;
                                  	stepper1.run();
                                  		printTimer = now ;
                                  	case V_PERCENTAGE:
                                  	break ;
                                  	case V_STATUS:
                                  	break ;
                                  	default :
                                  	break ;
                                  P Offline
                                  P Offline
                                  patchmaster
                                  @AWI Thanks. I have been using the Accelstepper library, but this has already given me several other ideas.
                                  I appreciate the help.
                                  • A AWI
                                     PROGRAMMER: AWI
                                    Special:
                                    Summary:
                                    Remarks:
                                    	Fixed node-id
                                    Change log:
                                    20160312 - Cleanup
                                    // stepper library
                                    // button library
                                    // used for:
                                    #define SV "1.0"
                                    	long longInt;
                                    	} convLongInt ;
                                    	// setup buttons
                                    	myBtn.read();
                                    	switch (State) {
                                    		// - button press
                                    		// - idleTimer
                                            case sIdle:
                                    				// if running stop
                                    			break ;
                                    				State = sIdle ;
                                    			break ;
                                    				State = sIdle ;
                                    				State = sIdle ;
                                    			break ;
                                    		default :
                                    			break ;
                                    			runStatus = Idle ;
                                    	stepper1.run();
                                    		printTimer = now ;
                                    	case V_PERCENTAGE:
                                    	break ;
                                    	case V_STATUS:
                                    	break ;
                                    	default :
                                    	break ;
                                    Tore André RosanderT Offline
                                    Tore André Rosander
                                    @AWI
                                    I have been searching for something like this for a while, thank you for the code!
                                    But i have some problems compiling it :\
                                    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void saveStateL(int, long int)':
                                    stepper_mysensor:74: error: 'saveState' was not declared in this scope
                                    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'long int loadStateL(int)':
                                    stepper_mysensor:81: error: 'loadState' was not declared in this scope
                                    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void presentation()':
                                    stepper_mysensor:129: error: 'present' was not declared in this scope
                                    stepper_mysensor:132: error: 'sendSketchInfo' was not declared in this scope
                                    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void loop()':
                                    stepper_mysensor:195: error: 'send' was not declared in this scope
                                    exit status 1
                                    'saveState' was not declared in this scope```
                                    A 1 Reply Last reply
                                    • Tore André RosanderT Tore André Rosander
                                      @AWI
                                      exit status 1
                                      A Offline
                                      A Offline
                                      AWI
                                      wrote on last edited by AWI
                                      @Tore-André-Rosander are you using the development branch? The errors seem to indicate that is the case.
                                      Tore André RosanderT 1 Reply Last reply
                                      • A AWI
                                        Tore André Rosander
                                        @AWI Thank you, that helped :)
                                        I now have it up and running.
                                        But how do i connect and use this with a controller (like Domoticz)?
                                        I use an ESP gateway (from the dev branch) and the curtain node is connected and showing up in domoticz.
                                        But how do i make domoticz send commands to the curtain node?
                                        All i get when adding the curtain node both as on/off button and blinds in domoticz is "unreconized" in the curtain serial monoitor.
                                          A Offline
                                          A Offline
                                          AWI
                                          @Tore-André-Rosander I have defined it as "Blinds Percentage" in Domoticz. This send the V_STATUS and V_PERCENTAGE messages where the node should respond to...
                                          0_1458557025507_upload-d16cb932-d511-433f-9488-112b68d308f4
                                          12.2k
