  3. Curtain Control Node.
domoticzcurtain controlmysensors node
51 Posts 15 Posters 31.1k Views 22 Watching
    What type of motor are you using?
    • Suresh MaliS
      Suresh MaliS
      Suresh Mali
      wrote on last edited by Suresh Mali
      Its a Geared DC Motor with Voltage Rating of 6-12V and 100 RPM. I am using a L239 to control the motor.
      • AWIA
        AWIA
        AWI
        Looks good. I am curious to see the details... jealous for the speed :runner: your curtain is moving.
        I have been working on a similar project last week. The mechanics and ´looks´ are the most difficult part for me.
        For now I have used a ´tuned´ cheap & small stepper which makes it slooow but effective ;-) The rail and mounting is standard IKEA. The pro-mini has the jModule attached. Works like a charm (/snail)!
        0_1457980545567_upload-c50fc1e9-f23e-458d-a812-62ad4bf478e0
        0_1457981153586_upload-c7064209-3900-4e4b-b335-8c88721367c0
        TheoLT 1 Reply Last reply
        • Suresh MaliS
          Suresh MaliS
          Suresh Mali
          @AWI Thanks. Why dont you increase the pulley size (larger pulley) that will increase the speed.
          I found driving stepper motor to be bit more complicated than driving a DC motor. I picked the Geared motor basis the calculation using this calculator.
          Since without rails pulling the curtains on a metal pipe needed more torque. Thus I chose 100 RPM to be a suitable fit.
          Will share the Schematics and PCB layout files soon. I have already added the sketch for reference. Since I was testing I did not put the circuit in any housing. But will give some shape soon.
          Also will be adding 3 buttons for Manual Control.
          • barduinoB
            barduinoB
            barduino
            @Suresh-Mali
            DC Motor, very interesting!
            Do you have end stops? The sketch doesn't open for some reason...
            Suresh MaliS S 2 Replies Last reply
            • barduinoB barduino
              @Suresh-Mali
              Suresh MaliS
              Suresh MaliS
              Suresh Mali
              @barduino I tried downloading the code, it works. Anyways I am pasting the code below.
              For end stops I have not yet decided. I had some Ideas of using Hall effect sensor on both ends and a small piece of magnet in the string to detect ends or Maybe use stop switches. Not sure but will have to try both and see which works the best.
              I am yet to clean the code I have some debugging serial prints in code which will remove once finalized.
              int motor_forward = 5;
              int motor_reverse = 6;
              int LDRinput = 1;     //analog pin to which LDR is connected, here we set it to 0 so it means A0
              int LDRValue = 0;      //that�s a variable to store LDR values
              int light_sensitivity = 500;    //This is the approx value of light surrounding your LDR
              int stopSwLeft = 4;
              int stopSwRight = 3;
              int stopSwNow = 2;
              int CHILD_CURTAIN_ID =1;
              int lastState;
              MyMessage msg_S_COVER_U(CHILD_CURTAIN_ID, V_UP);
              MyMessage msg_S_COVER_D(CHILD_CURTAIN_ID, V_DOWN);
              MyMessage msg_S_COVER_S(CHILD_CURTAIN_ID, V_STOP);
              //MyMessage msg(CHILD_CURTAIN_ID,V_UP);
              // the setup routine runs once when you press reset:
              	// initialize the digital pin as an output for L239D.
              	pinMode(motor_forward, OUTPUT);
              	pinMode(motor_reverse, OUTPUT);
              	// initialize the digital pin as an output for Stop Switches.
              	pinMode(stopSwLeft, INPUT_PULLUP);
              	pinMode(stopSwRight, INPUT_PULLUP);
              	pinMode(stopSwNow, INPUT_PULLUP);
              	gw.sendSketchInfo("Window_Curtain", "1.0");
              	gw.present(CHILD_CURTAIN_ID, S_COVER);
              void loop(){
              void cover(int coverVal){
              	//int coverVal = gw.loadState(CHILD_CURTAIN_ID);
              	Serial.print("Cover is : ");
              	lastState = coverVal;
              	switch (coverVal) {
              	case 0:
              		Serial.println("Opening");
              			while (lastState == coverVal)
              				m_left();
              				checkHWInnputs();
              			gw.send(msg_S_COVER_U.set(V_UP));
              	case 1:
              		Serial.println("Closing");
              				m_right();
              				checkHWInnputs();
              			gw.send(msg_S_COVER_D.set(V_DOWN));
              	case 2:
              		Serial.println("Idle");
              					m_stop();
              					checkHWInnputs();
              			gw.send(msg_S_COVER_S.set(V_STOP));
              	return;
              	Serial.println("recieved incomming message");
              	switch (message.type) {
              	case V_UP:
              		gw.saveState(CHILD_CURTAIN_ID, 0);
              		Serial.println("V_UP");
              		cover(gw.loadState(CHILD_CURTAIN_ID));
              		Serial.print("Done cover procedure");
              		//m_right();
              	case V_DOWN:
              		gw.saveState(CHILD_CURTAIN_ID, 1);
              		Serial.println("V_DOWN");
              		//m_left();
              	case V_STOP:
              		gw.saveState(CHILD_CURTAIN_ID, 2);
              		Serial.println("V_STOP");
              		//m_stop();
              	Serial.print("exiting incoming message");
              	return;
              // the loop routine runs over and over again forever:
              void m_right() {
              	digitalWrite(motor_forward, HIGH); //terminal D1 will be HIGH
              	digitalWrite(motor_reverse, LOW); //terminal D2 will be LOW
              	Serial.print("Set For:High and Rev: Low");
              	exit;
              void m_left() {
              	digitalWrite(motor_forward, LOW); //terminal D1 will be LOW
              	digitalWrite(motor_reverse, HIGH); //terminal D2 will be HIGH
              	Serial.print("Set For:Low and Rev: High");
              	exit;
              void m_stop() {
              	digitalWrite(motor_reverse, LOW); //terminal D2 will be HIGH
              	Serial.print("Set For:Low and Rev: Low");
              	exit;
              void checkHWInnputs()
              		if (digitalRead(stopSwNow) == LOW)
              			Serial.println("Detected stop button push. Stopping");
              			cover(2);
              			Serial.println("Saved stop state to EEPROM");
              		if (digitalRead(stopSwLeft) == LOW)
              			cover(1);
              		if (digitalRead(stopSwRight) == LOW)
              			cover(0);
              barduinoB 1 Reply Last reply
              • franzelareF
                franzelareF
                franzelare
                Sweet!
                My girl has put this on my todolist...
                But still have to get started, this is some nice reference for my new porject!
                Suresh MaliS 1 Reply Last reply
                • franzelareF franzelare
                  Sweet!
                  Suresh MaliS
                  Suresh MaliS
                  Suresh Mali
                  @franzelare Great. Good Luck with the build.
                  I'll be posting my HW design and Code as part of Contest on openhardware.io
                  • Suresh MaliS
                    Suresh MaliS
                    Suresh Mali
                    I have published my project with all the files.
                    https://www.openhardware.io/view/45/Curtain-Control-Node
                    • Suresh MaliS Suresh Mali
                      int stopSwLeft = 4;
                      int stopSwNow = 2;
                      int lastState;
                      void loop(){
                      	switch (coverVal) {
                      	case 0:
                      				m_left();
                      				checkHWInnputs();
                      	case 1:
                      				m_right();
                      				checkHWInnputs();
                      	case 2:
                      					m_stop();
                      					checkHWInnputs();
                      	return;
                      	case V_UP:
                      		//m_right();
                      	case V_DOWN:
                      		//m_left();
                      	case V_STOP:
                      		//m_stop();
                      	return;
                      void m_right() {
                      	exit;
                      void m_left() {
                      	exit;
                      void m_stop() {
                      	exit;
                      			cover(2);
                      			cover(1);
                      			cover(0);
                      barduinoB
                      barduinoB
                      barduino
                      @Suresh-Mali
                      I'm just curious, maybe its the arduino IDE version or something.
                      I'm using 1.6.4 and I get this:
                      0_1458129604092_upload-1364c257-d6a3-46d0-bdec-ff24cf9d2b41
                      However opening with a text editor is fine:
                      0_1458129652911_upload-e1883418-162b-4aba-bacf-d3e85436cca7
                        @Suresh-Mali
                        Suresh MaliS
                        Suresh MaliS
                        Suresh Mali
                        @barduino Seems like the IDE. Open any example MySensors Sketch. Delete the contents from sketch and copy paste from my sketch. I guess that should work.
                        Are you able to compile any other sketch in Arduino?
                        • P
                          P
                          patchmaster
                          @AWI Are you able to share the sketch you used with the UL2003 driver board? I have tried to combine the MySensors servo sketch with other arduino only sketches utilizing the UL2003, but without luck. Thanks.
                          Suresh MaliS AWIA 2 Replies Last reply
                          • P patchmaster
                            Suresh MaliS
                            Suresh MaliS
                            Suresh Mali
                            @patchmaster I used the relay sketch and modified it to my needs. Sorry but I dont have any sketch for ULN2003. :disappointed:
                            • P patchmaster
                              AWIA
                              AWIA
                              AWI
                              @patchmaster This is my current curtain control sketch. I work with the development branch, so the syntax can be a little different.
                              The Accelstepper library gives you all the abilities to slow start/stop with numerous kinds of steppers.
                              My sketch includes a calibration function (stored in EEPROM) so the you don't need end stop detection (a stepper knows where it is)
                               PROJECT: MY Sensors curtain controller
                               PROGRAMMER: AWI
                               DATE: march 11, 2016
                               FILE: AWI stepper1.ino
                               LICENSE: Public domain
                               Hardware: ATMega328p board w/ NRF24l01
                              	and MySensors 2.0 (Development)
                              Special:
                              	uses AccelStepper library
                              Summary:
                              	Curtain control with stepper motor.
                              	Manual operation with 1 push button
                              	Calibration with manual button
                              Remarks:
                              	Fixed node-id
                              Change log:
                              20160312 - Cleanup
                              #define MY_NODE_ID 13											// fixed node number
                              // stepper library
                              #include <AccelStepper.h>										// http://www.airspayce.com/mikem/arduino/AccelStepper/
                              #define HALFSTEP 8  											// Stepper uses "Halfstep" mode
                              // button library
                              // used for:
                              // - manual open close - single click: close/ stop/ open/ stop
                              // - calibration  - after long press: open calibarion- until single press - closed calibration - until single press (stop)
                              #include <Button.h>												// https://github.com/JChristensen/Button
                              #define CHILD_ID 1   											// Id of the sensor child
                              #define SN "Curtain control 13"
                              #define SV "1.0"
                              #define buttonPin1 7  											// Arduino pin connected to buttonPin1
                              #define buttonPin2 A0  											// Arduino pin connected to buttonPin2 (fixed to ground)
                              // Motor pin definitions
                              #define motorPin1  3     										// IN1 on the ULN2003 driver 1
                              #define motorPin2  4     										// IN2 on the ULN2003 driver 1
                              #define motorPin3  5     										// IN3 on the ULN2003 driver 1
                              #define motorPin4  6     										// IN4 on the ULN2003 driver 1
                              const unsigned long heartbeatInterval = 1 * 3600UL * 1000UL ;	// heartbeatinterval
                              unsigned long heartbeatCounter = 0 ;
                              // helper routines to store and retrieve long in mysensors EEPROM
                              union {															// used to convert long to bytes for EEPROM storage
                              	long longInt;
                              	uint8_t LongByte[4];
                              	} convLongInt ;
                              void saveStateL(int EEposition, long StateL){
                              	convLongInt.longInt = StateL ;
                              	for (int y = 0; y < 4 ; y++){								// convert to bytes
                              		saveState(EEposition + y , convLongInt.LongByte[y]) ;
                              	Serial.print("State saved: "); Serial.println(StateL);
                              long loadStateL(int EEposition){
                              	for (int y = 0; y < 4 ; y++){								// convert from bytes
                              		convLongInt.LongByte[y] = loadState(EEposition + y) ;
                              	Serial.print("State read: "); Serial.println(convLongInt.longInt);
                              	return convLongInt.longInt ;
                              // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
                              AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
                              // Initialize button active low, debounce and internal pull-up
                              Button myBtn(buttonPin1, true, true, 40);						// Initiate the button (pin, pull_up, invert, debounce_ms)
                              MyMessage percentageMsg(CHILD_ID, V_PERCENTAGE);				// used to send updates to controller
                              const long maxRun = 4000000L ;									// maximum runway
                              long setPosition = 0 ; 											// remembers set position, need to be saved in EEPROM
                              const int setPositionEE = 4 ;									// eeprom location
                              long openPosition = 0 ; 										// Position at open, need to be saved in EEPROM?
                              const int openPositionEE = setPositionEE + 4 ;					// eeprom location
                              long closedPosition = 120000UL ; 								// Position at full close, need to be saved in EEPROM
                              const int closedPositionEE = openPositionEE + 4 ;				// eeprom location
                              unsigned long idleTimer = millis() ;							// return to idle timer
                              unsigned long idleTime = 100000UL ;								// return to idle after 100 secs
                              unsigned long printTimer = millis() ;							// print timer
                              unsigned long printTime = 1000UL ;								// print after 1 secs
                              enum position_t {Open, Close, Idle, Running} ;
                              position_t lastDirection = Open ; 								// lastDirection only for buttonpress
                              position_t runStatus = Idle ;									// indicates current status for running motor. used for status reporting to controller
                              enum State_t {sIdle, sCalibrateOpen, sCalibrateClose} ;
                              State_t State = sIdle ;
                              	// setup buttons
                              	pinMode(buttonPin1, OUTPUT);
                              	stepper1.setMaxSpeed(2000.0);
                              	stepper1.setAcceleration(1000.0);
                              	//saveStateL(closedPositionEE, closedPosition) ; 			// INIT: save closed position in EEPROM
                              	closedPosition = loadStateL(closedPositionEE) ;				// need to get last values from EEPROM and assume the current position is correct
                              	setPosition = loadStateL(setPositionEE) ;
                              	stepper1.setCurrentPosition(setPosition );
                              }//--(end setup )---
                                present(CHILD_ID, S_COVER, "Curtain");						// Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
                                // Register the LED Dimmable Light with the gateway
                                sendSketchInfo(SN, SV);
                              unsigned int now = millis() ;								// current time for loop
                              // simple state machine for button press
                              	myBtn.read();
                              	switch (State) {
                                      // Idle state, waiting for some action
                              		// - button press
                              		// - idleTimer
                                      case sIdle:
                                          if (myBtn.wasReleased()){						// idle
                              				Serial.println("Button release") ;
                              				// if running stop
                              				if (stepper1.isRunning()){
                              					setPosition = stepper1.currentPosition();
                              					stepper1.moveTo(setPosition) ;			// move to current position (was already there..)
                              				} else if (lastDirection == Open) {
                              					stepper1.moveTo(closedPosition) ;
                              					lastDirection = Close ;
                              				} else {									// lastDirection == Close
                              					stepper1.moveTo(openPosition) ;
                              			} else if (myBtn.pressedFor(3000)){				// move to calibratete state with long press
                              				Serial.println("Button press long") ;
                              				idleTimer = now ;							// return to idle after ...
                              				State = sCalibrateOpen ;
                              				stepper1.move(-maxRun) ;					// let the stepper open with maximum
                              			break ;
                              		// if not running and last action was open close ;  else open
                              		// if longpress Calibrate open
                                      case sCalibrateOpen:           						// calibration going on
                              			if (myBtn.wasPressed()){
                              				stepper1.setCurrentPosition(0 );		// set new 0 position ??
                              				openPosition = setPosition = 0 ;
                              				State = sCalibrateClose ;					// next is close calibarion
                              				stepper1.move(maxRun) ;						// let the stepper close with maximum
                              			} else if (now > idleTimer + idleTime) {		// timer expired -> abort calibration
                              				State = sIdle ;
                              			break ;
                                      case sCalibrateClose:								// calibrate closed position, end with keypress
                              			if (myBtn.wasPressed())	{
                              				closedPosition = setPosition = stepper1.currentPosition() ;
                              				saveStateL(closedPositionEE, closedPosition) ; // save closed position in EEPROM
                              				State = sIdle ;
                              				stepper1.moveTo(openPosition) ;				// return to open after calibration
                              				State = sIdle ;
                              			break ;
                              		default :
                              			break ;
                              	// power off stepper if not running (no need to reenable))
                              	if (!stepper1.isRunning()){
                              		if (runStatus != Idle){								// there was a change in runningstatus, so report to controller
                              			setPosition = stepper1.currentPosition() ;		// store in EEPROM and report ready to controller
                              			saveStateL(setPositionEE, setPosition) ;
                              			send( percentageMsg.set((100 * setPosition)/(closedPosition - openPosition))) ;
                              			runStatus = Idle ;
                              		stepper1.disableOutputs();
                              		runStatus = Running ;
                              	stepper1.run();
                              	if (printTimer++ > now + printTime){
                              		printTimer = now ;
                              		Serial.println(stepper1.currentPosition());
                              // This is called when a message is received
                              // We only expect few types of messages from controller, check which
                              	case V_PERCENTAGE:
                              	// Curtain should be opened
                              	stepper1.moveTo(message.getInt() * (closedPosition - openPosition)/100);
                              	Serial.print("Message: "); Serial.print(message.sensor); Serial.print(" , value: % "); Serial.println( message.getInt());
                              	Serial.print("Moving to: "); Serial.println(message.getInt() * (closedPosition - openPosition)/100);
                              	break ;
                              	case V_STATUS:
                              	// Curtain should be opened or closed full
                              	stepper1.moveTo((message.getInt() == HIGH)?openPosition:closedPosition);
                              	Serial.print("Message - valid: ");
                              	break ;
                              	default :
                              	// not recognizable message
                              	Serial.print(", Unrecognized ");
                              	break ;
                              P Tore André RosanderT A 3 Replies Last reply
                              • AWIA AWI
                                 PROGRAMMER: AWI
                                Special:
                                Summary:
                                Remarks:
                                	Fixed node-id
                                Change log:
                                20160312 - Cleanup
                                // stepper library
                                // button library
                                // used for:
                                #define SV "1.0"
                                	long longInt;
                                	} convLongInt ;
                                	// setup buttons
                                	myBtn.read();
                                	switch (State) {
                                		// - button press
                                		// - idleTimer
                                        case sIdle:
                                				// if running stop
                                			break ;
                                				State = sIdle ;
                                			break ;
                                				State = sIdle ;
                                				State = sIdle ;
                                			break ;
                                		default :
                                			break ;
                                			runStatus = Idle ;
                                	stepper1.run();
                                		printTimer = now ;
                                	case V_PERCENTAGE:
                                	break ;
                                	case V_STATUS:
                                	break ;
                                	default :
                                	break ;
                                P
                                P
                                patchmaster
                                @AWI Thanks. I have been using the Accelstepper library, but this has already given me several other ideas.
                                I appreciate the help.
                                • AWIA AWI
                                   PROGRAMMER: AWI
                                  Special:
                                  Summary:
                                  Remarks:
                                  	Fixed node-id
                                  Change log:
                                  20160312 - Cleanup
                                  // stepper library
                                  // button library
                                  // used for:
                                  #define SV "1.0"
                                  	long longInt;
                                  	} convLongInt ;
                                  	// setup buttons
                                  	myBtn.read();
                                  	switch (State) {
                                  		// - button press
                                  		// - idleTimer
                                          case sIdle:
                                  				// if running stop
                                  			break ;
                                  				State = sIdle ;
                                  			break ;
                                  				State = sIdle ;
                                  				State = sIdle ;
                                  			break ;
                                  		default :
                                  			break ;
                                  			runStatus = Idle ;
                                  	stepper1.run();
                                  		printTimer = now ;
                                  	case V_PERCENTAGE:
                                  	break ;
                                  	case V_STATUS:
                                  	break ;
                                  	default :
                                  	break ;
                                  Tore André Rosander
                                  @AWI
                                  I have been searching for something like this for a while, thank you for the code!
                                  But i have some problems compiling it :\
                                  C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void saveStateL(int, long int)':
                                  stepper_mysensor:74: error: 'saveState' was not declared in this scope
                                  C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'long int loadStateL(int)':
                                  stepper_mysensor:81: error: 'loadState' was not declared in this scope
                                  C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void presentation()':
                                  stepper_mysensor:129: error: 'present' was not declared in this scope
                                  stepper_mysensor:132: error: 'sendSketchInfo' was not declared in this scope
                                  C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void loop()':
                                  stepper_mysensor:195: error: 'send' was not declared in this scope
                                  exit status 1
                                  'saveState' was not declared in this scope```
                                  AWIA 1 Reply Last reply
                                  • Tore André RosanderT Tore André Rosander
                                    @AWI
                                    exit status 1
                                    AWIA
                                    AWIA
                                    AWI
                                    wrote on last edited by AWI
                                    @Tore-André-Rosander are you using the development branch? The errors seem to indicate that is the case.
                                    Tore André RosanderT 1 Reply Last reply
                                    • AWIA AWI
                                      Tore André Rosander
                                      @AWI Thank you, that helped :)
                                      I now have it up and running.
                                      But how do i connect and use this with a controller (like Domoticz)?
                                      I use an ESP gateway (from the dev branch) and the curtain node is connected and showing up in domoticz.
                                      But how do i make domoticz send commands to the curtain node?
                                      All i get when adding the curtain node both as on/off button and blinds in domoticz is "unreconized" in the curtain serial monoitor.
                                        AWIA
                                        AWIA
                                        AWI
                                        @Tore-André-Rosander I have defined it as "Blinds Percentage" in Domoticz. This send the V_STATUS and V_PERCENTAGE messages where the node should respond to...
                                        0_1458557025507_upload-d16cb932-d511-433f-9488-112b68d308f4
                                        • AWIA AWI
                                          Tore André Rosander
                                          @AWI THanks again for your fast replys!
                                          This is what i get in serial monitor when i use the "up" "down" buttons for blinds percentage in domoticz.
                                          This is my very first MySensor setup so it might be some error with my setup, i will have a deeper look at it later tonight.
                                          Starting sensor (RNNNA-, 2.0.0-beta)
                                          Radio init successful.
                                          State read: -1
                                          State read: -1
                                          send: 13-13-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                                          send: 13-13-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                                          send: 13-13-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                          read: 0-0-13 s=255,c=3,t=15,pt=0,l=2,sg=0:
                                          read: 0-0-13 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          send: 13-13-0-0 s=1,c=0,t=5,pt=0,l=7,sg=0,st=ok:Curtain
                                          send: 13-13-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Curtain control 13
                                          send: 13-13-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                                          Init complete, id=13, parent=0, distance=1
                                          read: 0-0-13 s=1,c=1,t=29,pt=0,l=0,sg=0:
                                          Message - valid: 1, Unrecognized read: 0-0-13 s=1,c=1,t=30,pt=0,l=0,sg=0:
                                          Message - valid: 1, Unrecognized read: 0-0-13 s=1,c=1,t=29,pt=0,l=0,sg=0:
                                          Message - valid: 1, Unrecognized```
