  3. Auto Node ID Setting?
7 Posts 3 Posters 2.5k Views 3 Watching
  • T
    tcontrada
    I am trying to figure out how to assign a Node ID to a new device on my network.
    I am using a Sensbender Micro set to AUTO mode for receiving a static Node ID.
    When I monitor the serial data from my gateway, it shows the data as 255,255,3,0,3.
    What data do I send to the node in order to give it an static node ID from the gateway, or controller. Note I am not using any specific controller, just a simple Node Red application to display the mode data...
    Tony
    • J
      J
      jkandasa
      wrote on last edited by jkandasa
      @tcontrada send an internal message I_ID_RESPONSE to your node from gateway with payload of new node id. For more details refer http://www.mysensors.org/download/serial_api_15
      • T
        tcontrada
        So if I understand then the response would be 255,255,3,0,4,NODE_ID
        Is this correct?
        Tony
        • J
          J
          jkandasa
          @tcontrada perfect!
          • T
            tcontrada
            So that works setting a new Node ID. However, how can I change the Node ID to another value?
            Tony
            J 1 Reply Last reply
            • T tcontrada
              Tony
              J
              J
              jkandasa
              @tcontrada you have to erase EEPROM of your node. or using bootloaders you can change your node id. http://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta
              • mfalkviddM
                Please don't post the same question in different threads.
                An answer is available at http://forum.mysensors.org/topic/3577/modify-node-id/3
