  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
    @Mark-Jefford
    hmmm... are your relays ACTIVE HIGH (actuate wiht a 5V signal) or ACTIVE LOW (actuate when brought to ground) type?
    Mark JeffordM
    Mark JeffordM
    Mark Jefford
    @BulldogLowell
    Oh, well this is strange, if i disconnect the pin to the relay, it does not activate when unpowered.
    but from the shift register it is +5 when the zone is not active, and 0V when active, so i assume its an active low not active high by your example... surely removing the 5V feed to the relay pin should make it activate.. not sure whats going on there, some sort of black magic :P
    My reading of shift registers has made my brain hurt.. do i need to reverse the 0000000010000000 for 1111111101111111?
    • rechin304R
      rechin304R
      rechin304
      Dear all,
      i have trying to make the irrigation controller to start all zones in same time and run for the specified. I'm using version for domoticz. Can you please help me out with hint of what i can change in the code ?
      Another thing is that from domoticsz when i start a zone that zone start and previous is stopped but that status is not updated.
      Thank you in advance.
      P.S. I will post some pictures of the hardware build soon.
      • rechin304R rechin304
        Dear all,
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @rechin304
        have you tried changing the eight to one?
        #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
        trigger all your relays with the same output.
        • rechin304R
          rechin304R
          rechin304
          Well, that's not the point.
          I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they will finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
          To start all valve at once when is trigger all zones i did change:
              if (lastValve != valveNumber)
                    gw.send(msg1valve.setSensor(i).set(true), false);
                    gw.send(msg1valve.setSensor(i).set(false), false);
              lastValve = valveNumber;
              fastToggleLed();
              if (state != lastState)
                valveNumber = 1;
                updateRelays(ALL_VALVES_OFF);
          with
                    gw.send(msg1valve.setSensor(i).set(true), false); //to update domoticz
              fastToggleLed();
                valveNumber = 1;
                updateRelays(0); //all outputs will be on
                fastToggleLed();
                  valveNumber = 1;
            with
                fastToggleLed();
                  valveNumber = 1;
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they wi finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
            I see your point an understand your questions. The purpose of zone cycling is to be able to have enough pressure in each zone independently while also having pressure for household use. Drawing water to every zone (in my case 9) makes the pressure so low, there may not be enough to open the individual pop-up valves, much less fill the washing machine.
            The wait period (which you may set) is there to allow the time for hydraulic actuation of solenoid valves. These types of valves close slowly, and since they are in a manifold, the next valve to start opens faster if the water pressure at the manifold is allowed time to reach normal static pressure.
            The beauty of open source is that you get to do it your way. If you have the pressure to run all your valves at the same time, with enough to spare to take a shower, then you are fortunate!
            So, did you add another 'switch' to your controller to send the all zone command?
            • rechin304R
              rechin304R
              rechin304
              I did this so all relays on is ok now.
              What i miss is to start individual zones more than once at a time :).
              • rechin304R
                rechin304R
                rechin304
                wrote on last edited by rechin304
                #136
                Pictures of the case project and how is arranged inside. Not yet on the final location, still testing.
                5_1461396298101_IMG_3866.JPG 4_1461396298101_IMG_3865.JPG 3_1461396298101_IMG_3863.JPG 1_1461396298101_IMG_3861.JPG 0_1461396298101_IMG_3860.JPG
                k5mapK 1 Reply Last reply
                • David MoraD
                  David MoraD
                  David Mora
                  Hi I just finished building my first project in arduino ( this one) but the code is too large now for the arduino memory its 32748 bytes could you please share with me the older version of the code / libraries to run it in code bender ?
                  mfalkviddM petewillP 2 Replies Last reply
                  • David MoraD David Mora
                    @David-Mora's question was double-posted. See https://forum.mysensors.org/topic/3921/code-grew-larger-dan-promini/ for the other thread.
                      petewillP
                      petewillP
                      petewill
                      @David-Mora I responded to your comment on the YouTube video but I'll respond here as well just in case people are reading this thread instead.
                      This is probably because debug is enabled in the MyConfig.h file. Please comment out this line: #define DEBUG
                      Make sure to save the .h file then recompile the Arduino code. It should be around 25,342 bytes.
                      • David MoraD
                        David MoraD
                        David Mora
                        wrote on last edited by David Mora
                        #140
                        Hi Pete thank you very much, I am using mysensors online editor , not sure if I should edit that code?0_1463751590886_mysensors.jpg
                          It's not possible to disable this from codebender. You'll need to install the Arduino IDE onto your computer.
                          David MoraD 1 Reply Last reply
                            David MoraD
                            David MoraD
                            David Mora
                            #142
                            @hek in computer I get this:
                            C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
                            #include <../Wire/Wire.h>
                            compilation terminated.
                            exit status 1
                            Error compilación en tarjeta Arduino Pro or Pro Mini.
                            petewillP 1 Reply Last reply
                              exit status 1
                              petewillP
                              petewillP
                              petewill
                              @David-Mora Maybe this will help:
                              https://www.youtube.com/watch?v=qUey_X9n2KI
                              • David MoraD
                                David MoraD
                                David Mora
                                #144
                                thank you for your help ! I just reinstaled arduino and now I getthis ( I just downloaded the I.5 and copy and paste all libraries in the libraries folder:
                                TENCIÓN: Categoría '' en librería UIPEthernet no es válida. Configurando a 'Uncategorized'
                                C:\Users\David\Desktop\IrrigationController\IrrigationController.ino:92:31: fatal error: LiquidCrystal_I2C.h: No such file or directory
                                exit status 1
                                Error compilación en tarjeta Arduino Pro or Pro Mini.0_1463753883896_liquid.jpg
                                  exit status 1
                                  David MoraD
                                  David MoraD
                                  David Mora
                                  @David-Mora quite sad I´ve spent two days now installing and uninstalling arduino and libraries and no luck
                                    petewillP
                                    petewillP
                                    petewill
                                    @David-Mora Did you close all instances of Arduino and open again after you added the LiquidCrystal library? It looks like it can't find it.
                                    • petewillP petewill
                                      David MoraD
                                      David MoraD
                                      David Mora
                                      @petewill Yes Pete it doesnt work at all
                                        David MoraD
                                        David MoraD
                                        David Mora
                                        @David-Mora hope this is the right way to post the code finally the only mistake is
                                        Arduino:1.6.9 (Windows 7), Tarjeta:"Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
                                        El Sketch usa 30,808 bytes (100%) del espacio de almacenamiento de programa. El máximo es 30,720 bytes.
                                        Las variables Globales usan 1,329 bytes (64%) de la memoria dinámica, dejando 719 bytes para las variables locales. El máximo es 2,048 bytes.
                                        processing.app.debug.RunnerException: Programa muy grando: visite http://www.arduino.cc/en/Guide/Troubleshooting#size para ver cómo reducirlo.
                                        at cc.arduino.Compiler.size(Compiler.java:315)
                                        at cc.arduino.Compiler.build(Compiler.java:156)
                                        at processing.app.Sketch.build(Sketch.java:1111)
                                        at processing.app.Sketch.build(Sketch.java:1081)
                                        at processing.app.Editor$BuildHandler.run(Editor.java:1988)
                                        at java.lang.Thread.run(Thread.java:745)
                                        Tarjeta en COM4 no disponible
                                        Este reporte podría tener más información con
                                        "Mostrar salida detallada durante la compilación"
                                        opción habilitada en Archivo -> Preferencias.
                                          petewillP
                                          petewillP
                                          petewill
                                          @David-Mora Looks like you are almost there!
                                          Did you disable debug? The sketch looks too big. To disable go to the MySensors library and open the MyConfig.h file in Notepad and change this line:
                                          #define DEBUG
                                          to
                                          //#define DEBUG
                                          Also, it looks like the Arduino IDE programmer isn't finding your Pro Mini. Did you select the correct Board and Port from the Tools menu? I don't have an Arduino next to me so my port isn't available to select but it should look similar to this (except you would choose your Port the Arduino is connected to):
                                          0_1463835965285_upload-1dd27cba-b4e4-4543-980b-5ac59cc5da52
