  3. gw.sleep on battery powered magnet door switch
42 Posts 13 Posters 17.3k Views 16 Watching
  • siodS siod
    @AWI
    yes, makes sense, but how should you do this wihout the wakeup ? I guess this is just the disadvantage one must accept...
    AWIA
    AWIA
    AWI
    @siod The wakeup function can be disabled by setting the timer values to 0 (or omitting it). There is no purpose in the sketch above for what I can see. If you want to have a kind of "hey I am still alive"/heartbeat feature you need to do a little more (e.g. sending battery level)
    172pilot1 1 Reply Last reply
    • AWIA AWI
      172pilot1
      172pilot1
      172pilot
      @AWI I was going to ask about that.. I dont see any reason to wake up every 24 hours just to go back to sleep again.. I assume the radio doesn't have any reason to send a keepalive or anything? So, you can omit that number, and it will sleep until interrupted? That's cool..
      -Steve
      AWIA 1 Reply Last reply
      • 172pilot1 172pilot
        -Steve
        AWIA
        AWIA
        AWI
        @172pilot yes, no reason to wake up. Especially if there is a regular wake-up from interrupt to let the controller know it it is alive
        • AWIA AWI
          @siod I guess so. But don't ask me why. One should be sufficient to detect if the door is open :smile:
          In addition (and for what it is worth). If you use a real low power circuit you can save around a factor 3 on battery lifetime when you get rid of the timed wakeup. The arduino sleeps a lot better when it doesn't have to look at the alarm clock every few ms :zzz:
          ChakkieC
          ChakkieC
          Chakkie
          wrote on last edited by Chakkie
          #27
          @AWI
          Thanks for the info. I thought you always have to add the sleep time to the gw.sleep. I will disable the a wake timer by removing the 86400000.
          @siod I use one switch for the letterbox and one for the door.
          Raspberry Pi 2
          Domoticz
          RFXCOM
          ZWAVE Aeon stick
          Coming soon Arduino mysensors GW
          • siodS
            siodS
            siod
            well, as you can see, if you don´t know the libraries exactly you accept things as they are or as they seem to be. I wasn´t aware that you can just set the wakeup function to 0. So this said I would like to thank you @AWI for your patience and your willingness of explaining also the most obvious things! :thumbsup:
            still learning...
            • T
              treb0r
              The sketch works with both reeds switches (2 windows) but how to integreate it with DS18B20 temp sensor? I also power it with battery, so I would like to check the temp eg every 5min and if it is changed then send the new value to the controler. How to wake up arduino only if any window is opened or temp is changed (after 5 min)
              treb0r
              dynamiteD 172pilot1 2 Replies Last reply
              • T treb0r
                treb0r
                dynamiteD
                dynamiteD
                dynamite
                @treb0r You can either wake up on the interrupt or on a time period:
                bool sleep(int interrupt, int mode, unsigned long ms=0);
                interrupt - Interrupt that should trigger the wakeup.
                mode - RISING, FALLING, CHANGE
                ms - Number of milliseconds to sleep (or 0 to sleep forever).
                The sleep method returns true if wake up was triggered by pin change and false means timer woke it up.
                • T treb0r
                  treb0r
                  172pilot1
                  172pilot1
                  172pilot
                  @treb0r the problem is, you need to wake up the arduino to tell the temp sensor to take a new reading, so the best you can do is to trigger on the interrupts for the Windows and then use the timer to wake up and take the temperature reading, and then you'll have to compare to your saved value to decide whether it has been 5 degrees or not, so you can't completely sleep until that happens..
                  • siodS
                    siodS
                    siod
                    wrote on last edited by siod
                    #32
                    Hi guys,
                    unfortunately I have to answer again to this topic because I don´t get my nodes work longer then up to two weeks. I guess it is still a sleep function problem and the problem persits though I am usin ver 2.0 now. Please have a look at my code, any hint is very appreciated!!
                    I have attached 2 reed switches which should trigger a wakeup and one Hum/Temp Sensor is attached, too. I would like the device to send temp/hum measurements every 15 minutes, what works, but only for a few days or so. Then I also send battery level, that´s all.
                    I have 3 devices up and running right now, they all fail once in while...
                    // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                    // Define Node ID
                    #define MY_NODE_ID 200
                    //Batterysensor
                    int oldBatteryPcnt = 0;
                    #define CHILD_ID_BATT 7
                    //Kontaktschalter
                    //#include <Bounce2.h>
                    int oldValueReed1=-1;
                    int oldValueReed2=-1;
                    //Tempsensor
                    #include <SparkFunHTU21D.h>
                    #define CHILD_ID_HUM 3
                    #define CHILD_ID_TEMP 4
                    //tempsensor
                    HTU21D myHumidity;
                    float lastTemp;
                    float lastHum;
                    //boolean metric = true;
                    //Messages
                    //Battery
                    // Kontaktschalter
                    //TempMessage
                    void presentation(){
                      sendSketchInfo("Schlafzimmer Messstation", "2.0");
                      present(CHILD1_ID, S_DOOR);
                      present(CHILD2_ID, S_DOOR);
                      //Tempsensor
                      present(CHILD_ID_HUM, S_HUM);
                      //Battery
                    //Setup
                      //Serial.begin(9600);
                      Serial.println("Hello!");
                      //Batterysensor
                       analogReference(INTERNAL1V1);
                       analogReference(INTERNAL);
                    //Tempsensor
                      myHumidity.begin();
                      Serial.println("...done!");
                    // Setup Kontaktschalter 1
                      pinMode(BUTTON1_PIN,INPUT);
                        // Activate internal pull-up
                    // Setup Kontaktschalter 2
                      pinMode(BUTTON2_PIN,INPUT);
                    //Starte den Loop
                      //Batterysensor
                      // get the battery Voltage
                      delay(1000);
                       #ifdef DEBUG
                       #ifdef DEBUG
                       Serial.print(batteryV);
                       Serial.println(" V");
                       Serial.print(batteryPcnt);
                       Serial.println(" %");
                         // Power up radio after sleep
                         send(msgbatt.set(batteryPcnt));
                         oldBatteryPcnt = batteryPcnt;
                      //Kontakstschalter 1
                      sleep(10);
                      // Get the update value
                         // Send in the new value
                         send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                         oldValueReed1 = valueReed1;
                      //Kontakstschalter 2
                         send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                         oldValueReed2 = valueReed2;
                     //Tempsensor
                      if (isnan(temp)) {
                        lastTemp = temp;
                        send(msgTemp.set(temp, 1));
                        Serial.print("T: ");
                        Serial.println(temp);
                      if (isnan(humd)) {
                      } else if (humd != lastHum) {
                          lastHum = humd;
                          send(msgHum.set(humd, 1));
                          Serial.print("H: ");
                          Serial.println(humd);
                     Serial.println("Sleep...");
                    still learning...
                    • slingS
                      slingS
                      sling
                      @siod
                      I'm assuming your batteries are empty when you say fail ?
                      I built 5 of these last week for my dads place.
                      I set internal pullups to LOW and soldered a 3,3MOhm resistor between VCC and Pin2.
                      I'm seeing around 30µA when sleeping on two fresh AA batteries.
                      With internal pullups that would be around 1ma and that would indeed drain the batteries quite fast.
                      • siodS
                        siodS
                        siod
                        no Sir, batteries are still at around 90% charged.
                        still learning...
                        • N
                          N
                          Nicklas Starkel
                          @siod , I had the same problem.
                          I actually ordered a original NRF 24 mini and this seemed to solve some of my problems.
                          i think another problem I'm having is that my batteries has a huge self discharge (old 3.7v 18650)
                          On a side note.. I'm with @sling .
                          Loose the pullups and set them LOW´.
                          I have a 1MOhm resistor between VCC and PIN 2 and PIN 3 (also 2 switches).
                          Using the pullup HIGH draws around 130uA versus LOW it draws between 7 to 10uA!
                          Nca78N 1 Reply Last reply
                          • siodS
                            siodS
                            siod
                            No gentlemen, I don´t think it is a battery problem, maybe a radio problem, but not a battery problem.
                            But my sketch seems to be ok?
                            still learning...
                            • N Nicklas Starkel
                              That's the best solution with a normal reed switch.
                              But the best way is to use a "double" reed switch, with both normally opened and normally closed contacts. I use that connected between GND and pin 2 & 3 and set only the unconnected pin to high (so, with pullup). Current will flow only a very short time through the pullup while the node is waking up from sleep, then first thing I do is set connected input low. So nearly 100% of the time input is not connected and current through the reed switch is 0.
                              I've put a test node on my entrance door, it's been running for over 3 months on a CR2032 cell and has lost only 0.02V meaning it will last at least 2 years, maybe 3.
                               * NCA78: Updated to work with one dual normally open/normally closed reed switch on both interrupt pins.
                              // Enable debug prints
                              #include <MyConfig.h>
                              #include <SystemStatus.h>
                              #define SKETCH_NAME "NCA Door Sensor"
                              #define SKETCH_MAJOR_VER "0"
                              #define SKETCH_MINOR_VER "7"
                              #define PRIMARY_CHILD_ID 3
                              #define MY_PARENT_NODE_ID 0
                              //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
                              // Parameters for VCC measurement
                              const int VccMin        = 2000;  // Minimum expected Vcc level, in Volts. At 2V the cell should be dead
                              const int VccMax        = 2900;  // Maximum expected Vcc level, in Volts.
                              SystemStatus vcc();
                              int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
                              bool isEven = false; // to check+send battery level only for each open+close cycles
                              bool revertValue = false;  // to change this put a jumper on D4/D7 and it is tested at startup
                              // This is the activated pin, on which the interrupt is set
                              byte connectedPin = PRIMARY_BUTTON_PIN;
                              byte connectedPinAtLastSending = 0; // Initialized at 0 so we will always send the first time
                                // First thing to do: change clock prescaling to 8 to change from 8MHz to 1MHz
                                //  of course not necessary if you already have updated fuses and bootloader...
                                #ifndef MY_DEBUG           // only if we are not in debug mode, so we can keep the fast baudrate in debug
                                  clock_prescale_set (clock_div_8);
                                sleep(250); // sleep to let capacitor recharge a bit
                                sleep(5);
                                deActivatePin(PRIMARY_BUTTON_PIN);
                                deActivatePin(SECONDARY_BUTTON_PIN);
                                // Check if the previously connected pin is now connected. We do that because it's the most likely to be unconnected now
                                //  so it's the best way not to lose any current
                                byte newConnectedPin = GetNonConnectedPin();
                                if (checkPinIsConnected(connectedPin)) {
                                  // If pin is still connected we set back the value to connected pin
                                  newConnectedPin = connectedPin;
                                  #ifdef MY_DEBUG
                                    Serial.println("Connected pin is connected !");
                                connectedPin = newConnectedPin;
                                // If connected pin is different that the one during the last sending of status, we send again
                                #ifdef MY_DEBUG
                                  Serial.print("Connected pin = ");
                                  Serial.println(connectedPin);
                                  Serial.print("New Connected pin = ");
                                  Serial.println(newConnectedPin);
                                if (connectedPin != connectedPinAtLastSending) {
                                   send(msg.set(connectedPin==PRIMARY_BUTTON_PIN ? (revertValue ? 0 : 1) : (revertValue ? 1 : 0)));
                                   connectedPinAtLastSending = connectedPin;
                                   isEven = !isEven;
                                if (isEven) {  // send only every two changes for a full open + close cycle
                                  int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
                                  if (currentBatteryPercent != LastBatteryPercent) {
                                      sleep(100); // sleep 100ms (+65ms wake up time) to let capacitor recharge a bit
                                      LastBatteryPercent = currentBatteryPercent;
                                      sendBatteryLevel(currentBatteryPercent);
                                #ifdef MY_DEBUG
                                  Serial.print("Preparing to sleep, pin ");
                                  Serial.println(GetNonConnectedPin());
                                  wait(50);
                                // Activate the non connected pin before setting up interrupt
                                activatePin(GetNonConnectedPin());
                                // Sleep until something happens with the door sensor
                                sleep(GetNonConnectedPin()-2, CHANGE);
                              void activatePin(byte pin) {
                                // Set pin as input
                                pinMode(pin, INPUT);
                                // Activate internal pull up
                                digitalWrite(pin, HIGH);
                              void deActivatePin(byte pin) {
                                // Set back pin as output, low
                                pinMode(pin, OUTPUT);
                                digitalWrite(pin, LOW);
                              // Will check if pin is grounded (returns true) or not
                              boolean checkPinIsConnected(byte pin) {
                                activatePin(pin);
                                // Read value
                                byte valPin = digitalRead(pin);
                                deActivatePin(pin);
                                #ifdef MY_DEBUG
                                  Serial.print("checkPinIsConnected pin = ");
                                  Serial.print(pin);
                                  Serial.print(", value = ");
                                  Serial.println(valPin);
                                return valPin != HIGH;
                              // Returns the pin that is not connected
                              byte GetNonConnectedPin() {
                                return (connectedPin == PRIMARY_BUTTON_PIN) ? SECONDARY_BUTTON_PIN : PRIMARY_BUTTON_PIN;
                              https://www.aliexpress.com/item/20pcs-lot-3-pin-Reed-Switch-2-5X14MM-GLASS-Green-3-pin-Normally-Open-and-Normally/32507762756.html?spm=2114.13010608.0.0.4LJb9I
                              • siodS
                                siodS
                                siod
                                #38
                                Ok guys you convinced me, I will set them LOW instead of HIGH.
                                So now the reed switches are connected: GND | Reed Switch | PIN 2
                                Doing it your way I must connect them: VCC | 1M Ohm Resistor | Reed Switch | PIN2
                                Correct?
                                I just did it the way described here: https://www.mysensors.org/build/binary
                                There is nothing abaout any resistor...
                                But will this solve my problem? I am not sure. I had the feeling that the sensors won´t wake up from sleep or so...
                                still learning...
                                • L
                                  L
                                  LastSamurai
                                  wrote on last edited by LastSamurai
                                  #39
                                  I would be interested too as I have some battery problems with my reed switches too. I guess its VCC | Reed Switch | GND and Reed Switch |1M Ohm Resistor | inputpin, right?
                                  • L LastSamurai
                                    N
                                    N
                                    Nicklas Starkel
                                    @siod and @LastSamurai
                                    Connect the REED Switch with one leg to GND and the other leg to PIN2.
                                    And then you put a 1MOhm resistor between VCC and PIN2.
                                    • dbemowskD
                                      dbemowskD
                                      @siod
                                      This is used as a pull-up resistor to keep the signal to PIN2 active HIGH until the reed switch is closed.
                                      I have never tested and don't know how much of a difference it would make, but you can do the reverse of that too and connect it like this:
                                      GND -- 1MOhm -- PIN2 -- Reed Switch -- VCC
                                      With this setup PIN2 would stay active LOW and in your code you would check to see if it goes HIGH for the switch contact. My thought is that doing it with the resistor to VCC from PIN2, which would be active HIGH, would use a slight bit more power than keeping it active LOW with the resistor from PIN2 to GND . As I said, I have never tested this, so I may be wrong.
                                      • slingS
                                        slingS
                                        sling
                                        @siod
                                        new observation: I have two temp nodes with red Htu21d in them. One keeps locking up randomly. Have to go outside and reset the arduino. I'll try another sensor today and see if it fixes things. Have completely rebuild the node twice now with new parts except the sensor.
                                        12.5k
