  3. nRf24L01+ connection quality meter
43 Posts 18 Posters 26.7k Views 33 Watching
  • OitzuO
    OitzuO
    Oitzu
    wrote on last edited by Oitzu
    @AWI there also 2 versions of the PA/LNA Modules out there. Which one do you tested?
    AWIA 1 Reply Last reply
    • AWIA AWI
      I have been walking through and around the house with the meter to find the best radio solutions. So far I have the best reach with the nRF24L01+PA+LNA with the plastic/ aluminum foil (the ugly fix ;-), credits @Oitzu).
      0_1464961145010_upload-8716e90d-606f-4d9e-8dcb-697cb95fbbd6
      0_1464959045642_upload-85c16c8d-ac9f-40a9-a1cb-8464cc0bba0b
      b.t.w. I added "parent" and "destination" node to the display to show where the meter is connected to. Destination is fixed in the sketch but the "parent" will change if the meter connects to another node (i.e. repeater)
      To give you a real life impression . The transmitter (also nRF24L01+PA+LNA) is where the red arrow is behind two thick brick walls and a few trees. So, unless you live in a big mansion this should be sufficient range. Open field performance would be much better.
      0_1464961025398_upload-b1ddebfd-d124-433f-a00e-6296301a71f1
      For the rest of the tests I had a large variance in results. Some general observations:
      • nRF24L01+PA+LNA without the "shielding" is pretty similar (and sometimes even worse) than the standard radio with the pcb antenna.
      • all nRF24L01+ in SMD version have a comparable performance to the standard ones
      • The standard radio's I have tested with a silk screen (white lines) and pin designation print on the back seem to be fine.
        0_1464960195473_upload-9ff7ca2d-75e5-45b7-bea3-8824b6c19dd2
      • The (around 18) radio's is have tested without silk screen (3 different batches) are either "bad" performers (few meters) or don't perform at all. ( I noticed earlier and already put them apart. I was able to sort out 6 that can be used for short distance.).
        0_1464960320567_upload-b0a4caa9-7764-485b-a12e-8b9577dbe3e5
      • I don;t have any "blob" samples..
      I know this is far from scientific proof, but hope it gives you some guidance..
      In the picture, these radios have the notorious 1242AF datecode on the chip (if you didn't take the pictures yourself, do you have the same date code?). I also have a batch of these and they perform very well!
      • D
        drock1985
        Thanks @awi for this, might have to build one myself to test a potential bad batch of radios i have.
        Do you need the LCD for this or is the data also print in serial?
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        • D drock1985
          AWIA
          AWIA
          AWI
          @drock1985 It will print the data on serial but not very well formatted. You don't need the LCD but it is easy to carry around the house. (a laptop too :smiley: but be aware of disturbances coming from the laptop i.e. Wifi ) I thought off blinking led's also. You can easily change the sketch, there is not much to it..
          • OitzuO Oitzu
            AWIA
            AWIA
            AWI
            @Oitzu which versions do you relate to? I also have some with ceramic antenna (smd connection)
            • B
              B
              boozz
              @AWI
              Kijken je buren niet gek op wanneer je met je meter rondloopt? :wink:
              gr.
              Boozz
              • B boozz
                @AWI
                gr.
                Boozz
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                @boozz my neighbors ask me every two weeks what I am doing and what all those strange looking things in my garden and on my roof are... :flushed:
                • B
                  B
                  boozz
                  @AWI
                  And when you start explaining they look somewhat odd don't they?
                  • mrc-coreM
                    mrc-coreM
                    mrc-core
                    I'm having a problem in this part off the code:
                    "present(counterChild, S_DIMMER, "Quality counter " NODE_TXT) ; // counter uses percentage from dimmer value"
                    I'm getting this error:
                    "exit status 1
                    'present' was not declared in this scope"
                    How can i fix this ?
                    • mrc-coreM mrc-core
                      "exit status 1
                      @mrc-core sounds like you are using the stable (1.5.x) version of MySensors. This sketch requires the development version which is available on github
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        Thanks for the quick reply.
                        i'm going to change the versions :)
                        • bjacobseB
                          bjacobseB
                          bjacobse
                          Can this be extended to also measure NRF24l01 standby current? Maybe some "fake" modules have a high current consumption in stadnby mode, this could drain batteries quickly when used in battery operated devices
                          • cjrpriestC
                            cjrpriestC
                            cjrpriest
                            wrote on last edited by cjrpriest
                            #21
                            Hi @AWI, could you kindly post your updated version of the sketch that has the parent and destination node numbers on the display?
                            • cjrpriestC cjrpriest
                              AWIA
                              AWIA
                              AWI
                              @cjrpriest Here you go..
                               PROJECT: MySensors / Quality of radio transmission
                               PROGRAMMER: AWI (MySensors libraries)
                               DATE: 20160529/ last update: 20160530
                               FILE: AWI_Send.ino
                               LICENSE: Public domain
                               Hardware: ATMega328p board w/ NRF24l01
                              	and MySensors 2.0
                              Special:
                              Summary:
                              	Sends a radio message with counter each  x time to determine fault ratio with receiver
                              Remarks:
                              	Fixed node-id & communication channel to other fixed node
                              Change log:
                              20160530 - added moving average on fail/ miss count, update to 2.0
                              //****  MySensors *****
                              #define MY_RADIO_NRF24									// Enable and select radio type attached
                              //#define MY_RF24_CHANNEL 80								// radio channel, default = 76
                              #define MY_NODE_ID 250
                              #define NODE_TXT "Q 250"								// Text to add to sensor name
                              //#define MY_PARENT_NODE_ID 42							// fixed parent to controller when 0 (else comment out = AUTO)
                              // #define MY_RF24_CE_PIN 7								// Ceech board, 3.3v (7,8)  (pin default 9,10)
                              // #define MY_RF24_CS_PIN 8
                              #define DESTINATION_NODE 0								// receiving fixed node id (default 0 = gateway)
                              // display
                              #include <Wire.h>											// I2C
                              #include <LiquidCrystal_I2C.h>								// LCD display with I2C interface
                              // helpers
                              #define LOCAL_DEBUG
                              #ifdef LOCAL_DEBUG
                              #define Sprint(a) (Serial.print(a))						// macro as substitute for print, enable if no print wanted
                              #define Sprintln(a) (Serial.println(a))					// macro as substitute for println
                              #define Sprint(a)										// enable if no print wanted -or-
                              #define Sprintln(a)										// enable if no print wanted
                              // MySensors sensor
                              #define counterChild 0
                              // send constants and variables
                              int messageCounter = 0 ;
                              const int messageCounterMax = 100 ; 					// maximum message counter value
                              const unsigned counterUpdateDelay = 500 ;				// send every x ms and sleep in between
                              // receive constants and variables
                              boolean failStore[messageCounterMax] ;					// moving average stores & pointers
                              int failStorePointer = 0 ;
                              boolean missedStore[messageCounterMax] ;
                              int missedStorePointer = 0 ;
                              int newMessage = 0 ;
                              int lastMessage = -1 ;
                              int missedMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
                              int failMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
                              uint8_t parent = 0 ;									// parent node-id
                              // Loop delays
                              const unsigned long displayInterval = 1000UL ;			// display update in ms
                              unsigned long lastDisplayUpdate = 0 ;					// last update for loop timers
                              // standard messages
                              MyMessage counterMsg(counterChild, V_PERCENTAGE);		// Send value
                              // ***** LCD
                              //LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
                              LiquidCrystal_I2C lcd(0x27, 16, 2);  // Set the LCD I2C address
                              	Wire.begin();  // I2C
                                  // ** LCD display **
                                  // LCD 2 lines * 16 char.
                                  lcd.begin(16, 2);
                                  lcd.setBacklight(HIGH);
                                  lcd.setCursor(0, 0);
                              	lcd.print("AWI Quality nRF24");
                              	for(int i= 0 ; i <  messageCounterMax ; i++){		// init stores for moving averages
                              		failStore[i] = true ;
                              		missedStore[i] = true ;
                              	missedStorePointer = failStorePointer = 0 ;
                              	delay(1000);
                              void presentation(){
                              // MySensors
                              	// Sprint("count:") ; Sprintln(messageCounter) ;
                              	LCD_local_display();
                              	missedStore[failStorePointer] = false  ; 			// set slot to false (ack message needs to set) ;
                              	boolean succes = failStore[failStorePointer] = send(counterMsg.setDestination(DESTINATION_NODE).set(failStorePointer), true);  // send to destination with ack
                              	if (!succes){
                              		failMessageCounter++ ;
                              		Sprint("Fail on message: ") ; Sprint(failStorePointer) ;
                              		Sprint(" # ") ; Sprintln(failMessageCounter);
                              	failStorePointer++ ;
                              	if(failStorePointer >= messageCounterMax){
                              		failStorePointer =  0	;						// wrap counter
                              	parent = getParentNodeId();							// get the parent node (0 = gateway)
                              	wait(counterUpdateDelay) ;							// wait for things to settle and ack's to arrive
                              void receive(const MyMessage &message) {  				// Expect few types of messages from controller
                              	newMessage = message.getInt();						// get received value
                              	switch (message.type){
                              		case V_PERCENTAGE:
                              			missedStore[newMessage] = true ;			// set corresponding flag to received.
                              			if (newMessage > lastMessage){				// number of messages missed from lastMessage (kind of, faulty at wrap)
                              				Sprint("Missed messages: ") ; Sprintln( newMessage - lastMessage - 1) ;
                              				missedMessageCounter += newMessage - lastMessage - 1 ;
                              			lastMessage = newMessage ;
                              			break ;
                              		default: break ;
                              // calculate number of false values in array
                              // takes a lot of time, but who cares...
                              int getCount(boolean countArray[], int size){
                              	int falseCount = 0 ;
                              	for (int i = 0 ; i < size ; i++){
                              		falseCount += countArray[i]?0:1 ;
                              	return falseCount ;
                              void LCD_local_display(void){
                              /* prints all available variables on LCD display with units
                                  char buf[17]; 											// buffer for max 16 char display
                                  snprintf(buf, sizeof buf, "p%-3dFail%4d%3d%%", parent, failMessageCounter, getCount(failStore, messageCounterMax));
                                  lcd.print(buf);
                                  lcd.setCursor(0, 1);
                                  snprintf(buf, sizeof buf, "d%-3dMiss%4d%3d%%", DESTINATION_NODE , missedMessageCounter, getCount(missedStore, messageCounterMax));
                              	lcd.print(buf);
                              cjrpriestC karl261K 2 Replies Last reply
                              • AWIA AWI
                                 FILE: AWI_Send.ino
                                	and MySensors 2.0
                                Special:
                                Summary:
                                Remarks:
                                Change log:
                                // display
                                // helpers
                                #define LOCAL_DEBUG
                                #ifdef LOCAL_DEBUG
                                // MySensors sensor
                                // Loop delays
                                // ***** LCD
                                    lcd.begin(16, 2);
                                	delay(1000);
                                // MySensors
                                	if (!succes){
                                		case V_PERCENTAGE:
                                			break ;
                                		default: break ;
                                	return falseCount ;
                                    lcd.print(buf);
                                	lcd.print(buf);
                                cjrpriestC
                                cjrpriestC
                                cjrpriest
                                Thanks very much @AWI 👍
                                • AWIA AWI
                                   FILE: AWI_Send.ino
                                  	and MySensors 2.0
                                  Special:
                                  Summary:
                                  Remarks:
                                  Change log:
                                  // display
                                  // helpers
                                  #define LOCAL_DEBUG
                                  #ifdef LOCAL_DEBUG
                                  // MySensors sensor
                                  // Loop delays
                                  // ***** LCD
                                      lcd.begin(16, 2);
                                  	delay(1000);
                                  // MySensors
                                  	if (!succes){
                                  		case V_PERCENTAGE:
                                  			break ;
                                  		default: break ;
                                  	return falseCount ;
                                      lcd.print(buf);
                                  	lcd.print(buf);
                                  karl261K
                                  karl261K
                                  karl261
                                  wrote on last edited by karl261
                                  #24
                                  @AWI Strange, with the latest sketch I get
                                  nrf-quality-meter.ino:88:34: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
                                  In file included from nrf-quality-meter.ino:45:0:
                                  C:\Dokumente und Einstellungen\Philipp\Eigene Dateien\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:53:4: error: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)' [-fpermissive]
                                  LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
                                  compiling...
                                  It works using the other line...
                                  // ***** LCD
                                  • karl261K karl261
                                    compiling...
                                    // ***** LCD
                                    AWIA
                                    AWIA
                                    AWI
                                    @karl261 probably I am using another library for the display. I got it from the Arduino library manager.
                                    • N
                                      N
                                      Nicklas Starkel
                                      @AWI what is the board between the nano and the radio?
                                      Something available via aliexpress?
                                      I really do not need this as I live in a small flat.. but I NEED THIS! :laughing:
                                      • N Nicklas Starkel
                                        AWIA
                                        AWIA
                                        AWI
                                        #27
                                        @Nicklas-Starkel you can find it in the MySensors shop It is a nrf24l01+ socket adapter board. It guarantees a stable supply and includes the famous "radio capacitor"
                                        • siodS
                                          siodS
                                          siod
                                          wrote on last edited by siod
                                          #28
                                          Hi @AWI,
                                          thanks for the code and the project! ~~Unfortunately my biggest problem is to get my LCD working. It does not do anything with your code, other testcode to test the display is working fine. I am using this line and it should work fine:
                                          Any idea what else I could check? I am using arduino IDE 1.6.10
                                          edit: getting this in the serial monitor of the device:
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSP:ASSIGNID:OK (ID=250)
                                          TSM:FPAR
                                          TSP:MSG:SEND 250-250-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          TSP:MSG:BC
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          then it starts over again...
                                          edit2:
                                          Think I got it now, seems like my gateway wasn´t responding or whatever, now it seems to work...
                                          Edit3:
                                          I got 1 fail and 5000 miss 60%...
                                          Now what does this mean??
                                          Edit4:
                                          I think I need some help: Most of the time I get this on my gw´s Serial Monitor:
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          0;255;3;0;9;TSP:MSG:READ 250-250-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:BC
                                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=250)
                                          0;255;3;0;9;TSP:MSG:GWL OK
                                          After some reboots of the quality meter and I guess with a lot of luck it starts working occasionally
                                          This is from the serial monitor of the quality meter:
                                          TSP:MSG:READ 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                                          !TSP:MSG:PVER mismatch
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          I already added a 47u Cap and added those lines to the code:
                                          #define MY_PARENT_NODE_ID 0                         // fixed parent to controller when 0 (else comment out = AUTO)
                                          no luck at all...
                                          edit5:
                                          Now I opened the serial output of my GW again, which seems to started the communication:
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          0;255;3;0;9;TSP:MSG:PINGED (ID=250, hops=1)
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          0;255;3;0;9;!TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                          0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/0/0/17
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/3/0/6
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=0,t=4,pt=0,l=21,sg=0:Quality counter Q 250
                                          0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/0/0/4
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                                          0;255;3;0;9;TSP:MSG:ACK msg
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:0
                                          0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/1/0/3
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:1
                                          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:2
                                          I don´t get it what is going on here. Restarted quality meter: blank LCD... :(
                                          still learning...
