  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • AnticimexA Anticimex
    @alexsh1 Ok. I guess that is "good news for me" as it rules out signing related hardware as well. I guess so far, the only conclusion is that rf performance is to some extent degraded on the sensebender.
    alexsh1A
    alexsh1A
    alexsh1
    @Anticimex Yeah it seems like a combination of things but not a signing problem
    • ximinezX ximinez
      Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
      AnticimexA
      AnticimexA
      Anticimex
      @ximinez not sure. I know it has been discussed. But you can always patch the library to test.
      • ximinezX ximinez
        alexsh1A
        alexsh1A
        alexsh1
        #494
        @ximinez I do not think so. Either to patch the library or you do it in the sketch. Unless I do not know some other secret place.
        • ximinezX ximinez
          @ximinez
          You can add a before()-method.
          ximinezX 1 Reply Last reply
            @ximinez
            ximinezX
            ximinezX
            ximinez
            @hek said:
            @ximinez
            It's that easy? I'll give it a try when I get around to it, unless @alexsh1 feels like trying it first :)
            • HaakonH
              HaakonH
              Haakon
              Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
              alexsh1A 1 Reply Last reply
              • T
                tomkxy
                I have bought another couple of sensebenders.
                I am not able to upload sketches to one of them.
                When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
                What is the meaning of a solid red status LED?
                  What does the log say when you upload?
                  • HaakonH Haakon
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                    Just change your board for sensebender.
                    • T
                      tomkxy
                      @hek
                      D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i
                               User configuration file is "/Users/tom/.avrduderc"
                               Using Port                    : /dev/cu.usbserial-DA01IGTO
                               Overriding Baud Rate          : 57600
                      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                      avrdude: ser_recv(): read error: Device not configured
                      Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload
                      I have Sensebender selected as board.
                      Btw, where is the hardware folder? It is not present anymore in the development branch?
                        You can use the build in board manager nowadays.
                        https://github.com/mysensors/ArduinoBoards
                        Check board for solder bridges or anything suspicious.
                        • J
                          J
                          johnr
                          I wonder if anyone modified the original sensebender sketch to include a door sensor?
                          Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
                          martinhjelmareM alexsh1A 2 Replies Last reply
                          • J johnr
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @johnr
                            Here's one for a button, but shouldn't matter:
                            https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
                            • J johnr
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @johnr This is easy.
                              // PIN = 2 or 3 only
                              void setup {
                                pinMode(PIN,INPUT);
                                digitalWrite(PIN,HIGH);
                              This activates internal pull-up.
                              The sensebender has got pinout of Pro Mini
                              • T
                                timropp
                                Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
                                VeraEdge UI7 with Mysensors ethernet gateway
                                  :scream: Did you find the problem?
                                  • T timropp
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @timropp sounds like you shorted batteries somewhere
                                    • T
                                      timropp
                                      Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
                                        Available Pins - GND, GND, VCC (on the right)
                                          mvader
                                          I am having an odd issue with one of my sensebender boards.
                                          I have flashed 5 in a row, same sketch, same everything.
                                          all look fine (and in english) in the serial monitor. but this one board displays different.
                                          it does seem to work. but i can't figure out why it's showing up different in the monitor.
                                          any ideas?
                                          Óåîóåâåîäåò Íéãòï Æ× 1.5óåîä: 2-2-0-0 ó=255,ã=0,ô=17,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                          óåîä: 2-2-0-0 ó=255,ã=3,ô=6,ðô=1,ì=1,óç=0,óô=ïë:0
                                          óåîóïò óôáòôåä, éä=2, ðáòåîô=0, äéóôáîãå=1
                                           - Ïîìéîå!
                                          óåîä: 2-2-0-0 ó=255,ã=3,ô=11,ðô=0,ì=17,óç=0,óô=ïë:Óåîóåâåîäåò Íéãòï
                                          óåîä: 2-2-0-0 ó=255,ã=3,ô=12,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                          óåîä: 2-2-0-0 ó=1,ã=0,ô=6,ðô=0,ì=0,óç=0,óô=ïë:
                                          óåîä: 2-2-0-0 ó=2,ã=0,ô=7,ðô=0,ì=0,óç=0,óô=ïë:
                                          óåîä: 2-2-0-0 ó=3,ã=0,ô=1,ðô=0,ì=0,óç=0,óô=ïë:
                                          óåîä: 2-2-0-0 ó=4,ã=0,ô=16,ðô=0,ì=0,óç=0,óô=ïë:
                                          éóÍåôòéã: 0
                                          ÔåíðÄéææ :174.85
                                          ÈõíÄéææ  :154.00
                                          Ô: 74.85
                                          È: 54
                                          óåîä: 2-2-0-0 ó=1,ã=1,ô=0,ðô=7,ì=5,óç=0,óô=ïë:74.8
                                          óåîä: 2-2-0-0 ó=2,ã=1,ô=1,ðô=2,ì=2,óç=0,óô=ïë:54
                                          óåîä: 2-2-0-0 ó=255,ã=3,ô=0,ðô=1,ì=1,óç=0,óô=ïë:97
                                          ÏÔÁ Æ× õðäáôå åîáâìåä
                                          óåîä: 2-2-0-0 ó=4,ã=1,ô=23,ðô=2,ì=2,óç=0,óô=ïë:99
                                          Ìéçèô: 99
                                          ÔåíðÄéææ :0.01
                                          ˆõíÄéææ  :0.00
                                          Ìéçèô: 99
                                          tbowmoT 1 Reply Last reply
