  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • ximinezX ximinez
    Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
    AnticimexA
    AnticimexA
    Anticimex
    @ximinez not sure. I know it has been discussed. But you can always patch the library to test.
    • ximinezX ximinez
      alexsh1A
      alexsh1A
      alexsh1
      #494
      @ximinez I do not think so. Either to patch the library or you do it in the sketch. Unless I do not know some other secret place.
      • ximinezX ximinez
        @ximinez
        You can add a before()-method.
        ximinezX 1 Reply Last reply
          @ximinez
          ximinezX
          ximinezX
          ximinez
          @hek said:
          @ximinez
          It's that easy? I'll give it a try when I get around to it, unless @alexsh1 feels like trying it first :)
          • HaakonH
            HaakonH
            Haakon
            Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
            alexsh1A 1 Reply Last reply
            • T
              tomkxy
              I have bought another couple of sensebenders.
              I am not able to upload sketches to one of them.
              When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
              What is the meaning of a solid red status LED?
                What does the log say when you upload?
                • HaakonH Haakon
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                  Just change your board for sensebender.
                  • T
                    tomkxy
                    @hek
                    D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i
                             User configuration file is "/Users/tom/.avrduderc"
                             Using Port                    : /dev/cu.usbserial-DA01IGTO
                             Overriding Baud Rate          : 57600
                    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                    avrdude: ser_recv(): read error: Device not configured
                    Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload
                    I have Sensebender selected as board.
                    Btw, where is the hardware folder? It is not present anymore in the development branch?
                      You can use the build in board manager nowadays.
                      https://github.com/mysensors/ArduinoBoards
                      Check board for solder bridges or anything suspicious.
                      • J
                        J
                        johnr
                        I wonder if anyone modified the original sensebender sketch to include a door sensor?
                        Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
                        martinhjelmareM alexsh1A 2 Replies Last reply
                        • J johnr
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @johnr
                          Here's one for a button, but shouldn't matter:
                          https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
                          • J johnr
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @johnr This is easy.
                            // PIN = 2 or 3 only
                            void setup {
                              pinMode(PIN,INPUT);
                              digitalWrite(PIN,HIGH);
                            This activates internal pull-up.
                            The sensebender has got pinout of Pro Mini
                            • T
                              timropp
                              Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
                              VeraEdge UI7 with Mysensors ethernet gateway
                                :scream: Did you find the problem?
                                • T timropp
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @timropp sounds like you shorted batteries somewhere
                                  • T
                                    timropp
                                    Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
                                      Available Pins - GND, GND, VCC (on the right)
                                        mvader
                                        I am having an odd issue with one of my sensebender boards.
                                        I have flashed 5 in a row, same sketch, same everything.
                                        all look fine (and in english) in the serial monitor. but this one board displays different.
                                        it does seem to work. but i can't figure out why it's showing up different in the monitor.
                                        any ideas?
                                        Óåîóåâåîäåò Íéãòï Æ× 1.5óåîä: 2-2-0-0 ó=255,ã=0,ô=17,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                        óåîä: 2-2-0-0 ó=255,ã=3,ô=6,ðô=1,ì=1,óç=0,óô=ïë:0
                                        óåîóïò óôáòôåä, éä=2, ðáòåîô=0, äéóôáîãå=1
                                         - Ïîìéîå!
                                        óåîä: 2-2-0-0 ó=255,ã=3,ô=11,ðô=0,ì=17,óç=0,óô=ïë:Óåîóåâåîäåò Íéãòï
                                        óåîä: 2-2-0-0 ó=255,ã=3,ô=12,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                        óåîä: 2-2-0-0 ó=1,ã=0,ô=6,ðô=0,ì=0,óç=0,óô=ïë:
                                        óåîä: 2-2-0-0 ó=2,ã=0,ô=7,ðô=0,ì=0,óç=0,óô=ïë:
                                        óåîä: 2-2-0-0 ó=3,ã=0,ô=1,ðô=0,ì=0,óç=0,óô=ïë:
                                        óåîä: 2-2-0-0 ó=4,ã=0,ô=16,ðô=0,ì=0,óç=0,óô=ïë:
                                        éóÍåôòéã: 0
                                        ÔåíðÄéææ :174.85
                                        ÈõíÄéææ  :154.00
                                        Ô: 74.85
                                        È: 54
                                        óåîä: 2-2-0-0 ó=1,ã=1,ô=0,ðô=7,ì=5,óç=0,óô=ïë:74.8
                                        óåîä: 2-2-0-0 ó=2,ã=1,ô=1,ðô=2,ì=2,óç=0,óô=ïë:54
                                        óåîä: 2-2-0-0 ó=255,ã=3,ô=0,ðô=1,ì=1,óç=0,óô=ïë:97
                                        ÏÔÁ Æ× õðäáôå åîáâìåä
                                        óåîä: 2-2-0-0 ó=4,ã=1,ô=23,ðô=2,ì=2,óç=0,óô=ïë:99
                                        Ìéçèô: 99
                                        ÔåíðÄéææ :0.01
                                        ˆõíÄéææ  :0.00
                                        Ìéçèô: 99
                                        tbowmoT 1 Reply Last reply
                                        • M mvader
                                          any ideas?
                                           - Ïîìéîå!
                                          éóÍåôòéã: 0
                                          ÔåíðÄéææ :174.85
                                          ÈõíÄéææ  :154.00
                                          Ô: 74.85
                                          È: 54
                                          Ìéçèô: 99
                                          ÔåíðÄéææ :0.01
                                          ˆõíÄéææ  :0.00
                                          Ìéçèô: 99
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @mvader
                                          What baudrate are you using? It seems like it's to much off, for the ftdi to decode it correctly. Have you tried to lower it to, let's say 9600 baud? And does it still do this?
