  3. CE line on sensor node?
29 Posts 6 Posters 10.5k Views 1 Watching
  • aquaproA aquapro
    @aquapro sagte:> Hi,
    I have tested 1000 times, wasted complete weekend. Rechecked with built up the wiring from scratch. Same Problem.
    Suppose I have swap the cables, which I doubt, why it works when I disconnect it completely?
    I have all the cables replaced, also new from different suppliers. I used the next pins on the Arduino. For the pictures I have to build something stretched to better overview.
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @aquapro
    So the pictures don't reflect the current wiring?
    RJ_Make
    • aquaproA
      aquaproA
      aquapro
      Pictures reflect the curren?t wiring! Same Problem with closer wiring
      • aquaproA aquapro
        If I disconnect orange wire (red marker on first sensor picture), sensor works fine.
        Sensor figures:
        Gateway figures:
        @aquapro The MySensors site (http://www.mysensors.org/build/connect_radio) gives the following wiring:
        Arduino     nRF24
        9           CE
        10          CSN
        13          SCK
        11          MOSI
        12          MISO
        2           IRQ
        These are the defaults for the library. CE & CSN you can adapt through the constructor of MySensor (did you do that?)
        Looking at the pictures I have a hard time figuring out the connections for pins 8..12, while these are just the interesting part...
        aquaproA 2 Replies Last reply
        • aquaproA aquapro
          hello,
          very good project!
          I currently testing version 1.4b1 and I have a problem. Only if I disconnect the CE line on the sensor, the values ​​are transferred.
          If the CE line is connected, only one part will be sent, see Figure 1, the LED on the sensor remains on. As soon as I disconnect CE line, all values ​​are not sent are transmitted (Figure 2) and the LED goes out and lights up briefly in the next transmission.
          Does anyone have an idea?
          greeting
          aqua
          Figure1
          Figure 2
          DammeD
          DammeD
          Damme
          Code Contributor
          wrote on last edited by Damme
          @aquapro Hmmmm
          The chip on your looks like a blob more than this; You might have gotten a chinese ripoff .. I dont remember the chip name... Hmmmm hard to see!
          edit:
          maybe : http://forum.mysensors.org/topic/300/rfm73-experience/ ?
          inverted CE?
          YveauxY RJ_MakeR 2 Replies Last reply
          • DammeD Damme
            @aquapro Hmmmm
            edit:
            inverted CE?
            @Damme Sharp observation, dude!
            Have a look at these: http://www.aliexpress.com/item/Free-shipping-10pcs-lot-NRF24L01-wireless-data-transmission-module-NRF24L01-wireless-module/1996222121.html
            Claimed to be nRF24L01+!!
            • DammeD Damme
              @aquapro Hmmmm
              edit:
              inverted CE?
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @Damme
              Nice Catch Indeed!
              RJ_Make
              • YveauxY Yveaux
                Arduino     nRF24
                9           CE
                10          CSN
                13          SCK
                11          MOSI
                12          MISO
                2           IRQ
                aquaproA
                aquaproA
                aquapro
                wrote on last edited by aquapro
                @Yveaux yes I checked wiring with (http://www.mysensors.org/build/connect_radio)
                more detail picture, hope so. (bad light)
                @Damme
                Chip is covered.
                • YveauxY Yveaux
                  Arduino     nRF24
                  9           CE
                  10          CSN
                  13          SCK
                  11          MOSI
                  12          MISO
                  2           IRQ
                  aquaproA
                  aquaproA
                  aquapro
                  @Yveaux
                  Pin 8?
                  YveauxY DammeD 2 Replies Last reply
                  • aquaproA aquapro
                    @Yveaux
                    Pin 8?
                    @aquapro said:
                    Pin 8?
                    It looked like you could have a connection to pin 8, but apparently (in the better pictures) you haven't...
                    • aquaproA aquapro
                      @Yveaux
                      Pin 8?
                      DammeD
                      DammeD
                      Damme
                      Code Contributor
                      @aquapro I dont think you got a nordic semiconductor nrf24l01, What I can find they are only in QFN package.
                      http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01
                      So the specs on that chip may be different. Maybe CE is inverted?
                      • aquaproA
                        aquaproA
                        aquapro
                        hm ... if CE inverted, ping sample should not work?! CE must switch between hight and low for TX and RX right? But Ping sample send and receive works.
                        • aquaproA
                          aquaproA
                          aquapro
                          I have bought the new modules (right on pic), which operate without modification. I simply swapped and all is fine.
                          What do I do with the other. How can I test inverted.
                          hekH 1 Reply Last reply
                          • aquaproA aquapro
                            @aquapro
                            I hope you didn't get the left one when purchasing through the links in the MySensors "store"?
                            • aquaproA
                              aquaproA
                              aquapro
                              I got the left one from other eb..-"store".
                              • aquaproA
                                aquaproA
                                aquapro
                                The left one works with MySensor-Coding, but only with disconnected CE line.
                                • Z
                                  Z
                                  Zeph
                                  If it truly works correctly with CE disconnected, that could be an advantage when there is a shortage of pins (eg: 8 pin ATTiny).
                                  Have you achieved full operation without CE on the old modules?
                                  And did you leave CE floating or tie it high?
                                  • aquaproA
                                    aquaproA
                                    aquapro
                                    I still see no difference when CE is disconnected.Only it as work at all.
                                    • Z
                                      Z
                                      Zeph
                                      What vendor did you use to get the "no CE needed" variants? That could be useful to test.
                                      I'm assuming that the nRF24L01+ doesn't work without CE connected, right?
                                      • aquaproA
                                        aquaproA
                                        aquapro
                                        Eb.. no. 360917673897 vendor "liuddndd2009"
