  3. Sensebender Micro & External Sensors (ds18b20)
2 Posts 2 Posters 734 Views 2 Watching
  • M Offline
    M Offline
    Marcus Schmidke
    Hello all,
    I'm succesfully using some Sensebender boards with 2 AA rechargeable batteries each, and I'm very pleased about the function and battery lifetime. It's very far beyond my expectations!
    But until now, I only used the internal temperature sensor. Now I want to use an external sensor (because the signal quality out of my fridge is really bad), an ds18b20 for example.
    I'm wondering if that's possible since the sensor has a voltage minimum around 3 Volts, and my batteries supply at most 2.6V.
    Any experiences out there? Or some hints for me? What can I do?
    Regards,
    Marcus.
    • mfalkviddM Online
      mfalkviddM Online
      Get a sensor that supports lower voltages or get a step-up.
      Earlier discussions on the same topic:
      https://forum.mysensors.org/topic/3801/witch-temp-hum-sensor-is-best-to-use-for-battery-powered-sensors/
      https://forum.mysensors.org/topic/3203/cheap-good-boost-converter-and-good-temperature-sensors/
      https://forum.mysensors.org/topic/2027/test-of-step-up-modules-sparkfun-pololu-china-module-any-other/
      https://forum.mysensors.org/topic/444/battery-powered-motion-sensor
      https://forum.mysensors.org/topic/171/efficiency-of-voltage-boosters
