  3. 💬 Wall Switch Insertable Node
contest2017rfm69atsha204amysensorslonglifeswitchbatterycoincell
37 Posts 15 Posters 14.6k Views 17 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node
    • bjornhallbergB Offline
      bjornhallberg
      Fantastic! Finally some hardware debouncing! This would make a perfect mailbox alert system as well right? If a little overkill perhaps.
      Do you know of any integrated hardware debouncer solutions besides going for schmitt triggers? (that are affordable!) I did look at the MAX6816/MAX6817/MAX6818 (https://www.maximintegrated.com/en/products/interface/circuit-protection/MAX6818.html) series myself, but I never got around to using them, and they aren't super cheap exactly and only operate from 2.7V. Surely there must be other manufacturers doing similar ICs?
      KoreshK 1 Reply Last reply
        KoreshK Offline
        KoreshK Offline
        Koresh
        @bjornhallberg
        Unfortunately I couldn't find cheap initegrated debouncer. :( More over - I don't need ordinary debouncer, I need debouncer + edge detector for each channel (to hook 0->1 and 1->0 transitions).
        • S Offline
          Samuel235
          Very nice! The next revision to https://www.openhardware.io/view/48/Homini-In-Wall-Battery-Powered-Light-Switch-Module will attempt to get smaller much like yours here. I use a nRF24L01+ for my communication and will need to attempt to get this flat on the board to make my footprint any thinner. Thank you for the inspiration!
          MySensors 2.1.1
          • KoreshK Offline
            KoreshK Offline
            Koresh
            :smiley:
            • KoreshK Offline
              KoreshK Offline
              Koresh
              wrote on last edited by Koresh
              And after mounting :)
              • KoreshK Offline
                KoreshK Offline
                Koresh
                Oh.. Earlier I received cr2032 holders instead of cr2450. And now I've received cr2477 instead of cr2450... It's better, because it's possible to cut holders so they can be compatible with cr2450 battery :stuck_out_tongue:
                And I'm ready to start mass testing :smiley:
                • S Offline
                  Samuel235
                  Very nice, super professional finish to those board, nice work dude! I'm very interested in the way you have the power supply. I may just learn a few things from you and apply to my modules! Thank you!
                  MySensors 2.1.1
                  • KoreshK Offline
                    KoreshK Offline
                    Koresh
                    I've added SPI flash for OTA on this board too. And I've replaced 0402 components to 0603 so this board becomes not so crazy :grinning:
                    • V Offline
                      V Offline
                      vikasjee
                      Fantastic! Can i buy it pre-assembled from somewhere?
                      • V Offline
                        V Offline
                        vikasjee
                        Great! Which is the one with the transformer? any link to it?
                        • Y Offline
                          Y Offline
                          yury
                          We are changing PCBA contractor which is supposed to assemble Koresh projects. Since current one gave us way too many errors while assembling other projects for our "Day Job" we work with Koresh together. so may be some delay for all Koresh projects.
                          • tonnerre33T Offline
                            tonnerre33T Offline
                            tonnerre33
                            Hello
                            Will you build an nrf24l01 smd version ?
                            • blaceyB Offline
                              blaceyB Offline
                              blacey
                              Interesting board. While you have designed this to be a wall-insertable board, one could envision packaging this into a small case with 4 buttons attached to the surface for a portable scene controller/remote. Well done!
                              • Cliff KarlssonC Offline
                                Cliff Karlsson
                                Is it possible to buy this board assembled from you now?
                                  KoreshK Offline
                                  KoreshK Offline
                                  Koresh
                                  @Cliff-Karlsson
                                  Hope the batch of assembled boards (latest version after all fixes) will be ready in a week.
                                  • Sander TeunissenS Offline
                                    Sander Teunissen
                                    @koresh Great to hear you have assembled components available! I am following your other projects too (like the usb dongle and switchable power supply) .Will these become available as assembled components too ?
                                    • KoreshK Offline
                                      KoreshK Offline
                                      Koresh
                                      Board works with nrf24 too :wink:
                                      S 1 Reply Last reply
                                      • KoreshK Koresh
                                        Samuel235
                                        @Koresh - Do you happen to have a link for the JST connectors? I can't seem to find any at a reasonable price at the moment. And the male side too, if you don't mind me asking :)
                                        MySensors 2.1.1
                                        • S Samuel235
                                          KoreshK Offline
                                          KoreshK Offline
                                          Koresh
                                          @Samuel235 said in 💬 Wall Switch Insertable Node:
                                          The price depends on a batch size. You can try to ask any supplier on ali for 100-200 pcs and may be price will be reasonable :)
                                          11.9k
                                          113.3k
