  3. Has anyone tried software reset of an Arduino?
21 Posts 8 Posters 12.5k Views 9 Watching
  • T Offline
    T Offline
    TheoL
    wrote on last edited by TheoL
    I'm doing some research on how to reset an Arduino from within a Sketch. My first choice would be to do this without connecting a wire to the reset pin.
    Here is an example. But I've read that it's not always the best way to perform a rest. I gues I have to try if the NFR accepts it ;-)
    • T TheoL
      T Offline
      T Offline
      TheoL
      I used it in a test sketch.
      void(* resetFunc) (void) = 0; //declare reset function @ address 0
        if ( Serial.available() ) {
          // read the incoming byte:
          char incomingByte = Serial.read();
          // say what you got:
          Serial.print("I received: ");
          Serial.println(incomingByte, DEC );
          if ( incomingByte == 115 ) {
            Serial.println( "Resetting??" );
            gw.wait(50 ); // give serial some time to complete it's printing
            resetFunc();  //call reset
      And the Serial output is:
      Resetting??
      send: 17-17-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
      send: 17-17-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
      send: 17-17-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-17 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      sensor started, id=17, parent=0, distance=1
      So on my Uno it seems to wok fine. Looks promissing
      Y 1 Reply Last reply
      • T TheoL
        Resetting??
        Y Offline
        Y Offline
        @TheoL another way to reset is to enable the watchdog, but don't kick it. When it times out, it will reset the avr.
        Have to look up an example if you want.
        T K 2 Replies Last reply
        • Y Yveaux
          T Offline
          T Offline
          TheoL
          @Yveaux Thank you for your quick reply. Don't ask why, but I need to be able to reset a node by sending a message to it ;-). It's desired functionality not because of hardware problems.
          • T TheoL
            Y Offline
            Y Offline
            @TheoL could very well be that 2.0.0 already supports it. Maybe @tekka can shed some light on it ?
            • Y Yveaux
              T Offline
              T Offline
              TheoL
              @Yveaux That would be awesome. Saves me from code that might not be cross Arduino compatible. As I read somewhere during my research.
              • T TheoL
                T Offline
                T Offline
                tekka
                @TheoL sending an C_INTERNAL/I_REBOOT will do the job, it's a wdt reset.
                • T tekka
                  T Offline
                  T Offline
                  TheoL
                  @tekka Thank you. Not yet sure how to do that. If you have an example for that I would be much obliged. Otherwise I'll spend some time on that later on. Either way, thanx again.
                  Edited: Found it will update this answer later on with code
                  Edit 2. My test didn't work, but I will try again tomorrow
                  • Y Yveaux
                    K Offline
                    K Offline
                    Koresh
                    wrote on last edited by Koresh
                    @Yveaux
                    Watchdog is used by sleep() function in mysensors, so it is not possible to use it. Also it is not safe to use it on arduino boards with standard bootloader. If I need watchdog on standard arduino boards (without mysensors library) with standard bootloader I use next ISR to handle WDT interrupt
                    // Watchdog Timer interrupt service routine. This routine is required
                    // to allow automatic WDIF and WDIE bit clearance in hardware.
                    ISR (WDT_vect)
                    	// WDIE & WDIF is cleared in hardware upon entering this ISR
                    	wdt_disable();
                    	asm volatile ("  jmp 0");
                    This ISR prevents bootloop.
                    If I need just soft reset arduino I use the technique very similar to TheoL's
                    asm volatile ("  jmp 0"); //call anywhere
                    T T 2 Replies Last reply
                    • K Koresh
                      @Yveaux
                      ISR (WDT_vect)
                      	wdt_disable();
                      T Offline
                      T Offline
                      TheoL
                      @Koresh I haven't seen assembler for a while. Do you use that on all of your projects?
                      K 1 Reply Last reply
                      • T TheoL
                        K Offline
                        K Offline
                        Koresh
                        @TheoL
                        In general - no. Only for such tricks :) Of course these tricks are not invented by me.
                        • K Koresh
                          @TheoL
                          T Offline
                          T Offline
                          TheoL
                          @Koresh I understand my friend ;-) Although I have deep respect for people who are able to code completely in assembly. For me that was ages ago, almost in another life.
                          • K Koresh
                            @Yveaux
                            ISR (WDT_vect)
                            	wdt_disable();
                            T Offline
                            T Offline
                            tekka
                            wrote on last edited by tekka
                            Not sure what you are referring to, sleep() uses WDIE (wdt interrupt before reset, see here) whereas the reboot functionality is implemented via wdt reset (see here).
                            Can you elaborate why?
                            • S Offline
                              @Koresh @TheoL i use wdt with mysensors..but i cheated a bit :)
                              • you can use your own sleep and then handle wdt, but then careful if really need mysensors sleep(x ms) as it resets wdt.
                              • or as i do too, i have added a weak empty function in mysensors lib to have isr wdt available from sketch ;), temporarily I will submit a pr for the few features i have added locally..
                              • T tekka
                                K Offline
                                K Offline
                                Koresh
                                @tekka
                                Standard bootloader can fail to switch off wdt after reboot (on the boards with most chips) and it will cause bootloop. After rebooting watchog is still working and it is very important to disable it. We can use modified bootloader or bootloader like optiboot.
                                • S Offline
                                  @tekka I am not sure I will let answer, but if i remember well it was related to a problem that some old bootloader version were not handling properly wdt irq resulting in bootloader loop.
                                  ISR (WDT_vect) is used by mysensors lib if using mysensors sleep.
                                  but you can do something like:
                                  in MyHwATMega328.h
                                  void MY_WDT_Callback() __attribute__((weak));
                                  in MyHwATMega328.cpp, just add this in the wdt isr function
                                  if (MY_WDT_Callback) MY_WDT_Callback();
                                  and finally in your sketch you can use MY_WDT_Callback() which will be fired at every wdt irq. Something like
                                    wdt_reset(); // or do what you want
                                    irqWdt = true;
                                  maybe there are better ways. another note, is I don't advice to do too much change locally without pr because then..arrghh :pensive: :scream:
                                  • T Offline
                                    T Offline
                                    TheoL
                                    I when you thought you finally knew a bit about the Arduino, there comes a topic like this ;-) Thanx to you all. I understand to I have still much to learn.
                                    • B Offline
                                      B Offline
                                      bjacobse
                                      Hi, as I remember about watchdog is to set it to 8S, so there is enough time to upload an sketch (8 seconds) before the Arduino will reboot. WDT0_time_in_seconds. If using WDT08S Always call the wdt_reset() no later than 7 seconds to avoid reset/reboot. This is usually used in case that the Arduino/avr is "hanging" in an infinite loop and stopped responding to actions, then this will automatically reset/reboot
                                      Include this in your sketch:
                                      #include <avr/wdt.h>
                                      setup ();{
                                      // WDTO_1S
                                      // WDTO_2S
                                      // WDTO_4S
                                      // WDTO_8S
                                      wdt_enable(WDTO_8S);
                                      loop (){
                                      wdt_reset(); // You must call this within less seconds set as WDT0_8S
                                      • T Offline
                                        T Offline
                                        ToniA
                                        For whatever strange reason, the Arduino stock bootloader is broken, so that it will not disable the watchdog on startup, causing just an infinite reset loop. I'd recommend updating the bootloader with something like MYSBootloader or Optiboot.
                                        • D Offline
                                          donnacarter0103
                                          Banned
                                          Hey Buddy,
                                          [spam post removed by moderator]
                                          B 1 Reply Last reply
