  3. Door sensor Radio OK !TSM:FAILURE
19 Posts 5 Posters 6.9k Views 5 Watching
  • Dominic BonneauD
    Dominic BonneauD
    Dominic Bonneau
    Hi i made a door sensor with this exemple : https://www.mysensors.org/build/binary
    And the log always give me this :
    TSM:INIT
    TSM:RADIO:OK
    !TSP:ASSIGNID:FAIL (ID=0)
    !TSM:FAILURE
    TSM:PDT
    TSM:FPAR
    TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    • Dominic BonneauD Dominic Bonneau
      TSM:INIT
      TSM:RADIO:OK
      !TSM:FAILURE
      TSM:PDT
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      @Dominic-Bonneau See my response to this thread: https://forum.mysensors.org/topic/4515/first-tries-with-mysensors-v2-0-problem-staring-up/2
      I guess you also assigned an illegal node ID.
      • Dominic BonneauD
        Dominic BonneauD
        Dominic Bonneau
        Ok set I manualy set my ID to 2 and now a got the :
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=2)
        TSM:FPAR
        TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        TheoLT YveauxY 2 Replies Last reply
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          TheoLT
          TheoLT
          TheoL
          @Dominic-Bonneau can you post your sketch? It's hard to help without it
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            @Dominic-Bonneau said:
            !TSM:FPAR:FAIL
            It fails to connect to the gateway
            • Dominic BonneauD
              Dominic BonneauD
              Dominic Bonneau
              Oups... Yeah my bad I was trying something with not the same library of my gateway.
              This is the sketch :
              #define SKETCH_MAJOR_VER "1"
              #define SKETCH_MINOR_VER "0"
              #define PRIMARY_CHILD_ID 3
              #define SECONDARY_CHILD_ID 4
                // Setup the buttons
                // Activate internal pull-ups
                present(SECONDARY_CHILD_ID, S_DOOR);
                uint8_t value;
                static uint8_t sentValue=2;
                static uint8_t sentValue2=2;
                sleep(5);
                if (value != sentValue) {
                   send(msg.set(value==HIGH ? 1 : 0));
                   sentValue = value;
                if (value != sentValue2) {
                   send(msg2.set(value==HIGH ? 1 : 0));
                   sentValue2 = value;
                sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
              And this is the log :
              MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta
              TSM:INIT
              TSM:INIT:TSP OK
              TSF:ASID:OK,ID=2
              TSM:FPAR
              TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              !TSM:FPAR:NO REPLY
              TSM:FPAR
              !TSM:FPAR:NO REPLY
              TSM:FPAR
              !TSM:FPAR:NO REPLY
              TSM:FPAR
              !TSM:FPAR:FAIL
              TSM:FAILURE
              TSM:FAILURE:PDT
              I don’t know why he said no reply my gateway is in 2.0.1 like my sensor. I can ping it .. And receive data from my gateway on my mqtt broker …
              tekkaT 1 Reply Last reply
              • TheoLT
                TheoLT
                TheoL
                    uint8_t value;
                    sleep(5);
                       sentValue = value;
                       sentValue2 = value;
                  TSM:INIT
                  TSM:INIT:TSP OK
                  TSF:ASID:OK,ID=2
                  TSM:FPAR
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  !TSM:FPAR:NO REPLY
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  TSM:FAILURE
                  TSM:FAILURE:PDT
                  tekkaT
                  tekkaT
                  tekka
                  Can you provide a more detailed log showing what you describe? (Ideally of both, GW and node). Thanks
                  • Dominic BonneauD
                    Dominic BonneauD
                    Dominic Bonneau
                    I can I have a more detailed log ?
                      tekkaT
                      tekkaT
                      tekka
                      @Dominic-Bonneau By more detailed I mean covering a longer period.
                      • Dominic BonneauD
                        Dominic BonneauD
                        Dominic Bonneau
                        For the sensor it's repeating the something over and over ....
                        For the Gateway I got this :
                        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:INIT:TSP OK
                        0;255;3;0;9;TSM:INIT:GW MODE
                        0;255;3;0;9;TSM:READY
                        IP: 192.168.111.6
                        0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                        IP: 192.168.111.6
                        0;255;3;0;9;MQTT connected
                        0;255;3;0;9;TSF:SANCHK:OK
                        • Dominic BonneauD
                          Dominic BonneauD
                          Dominic Bonneau
                          Ok so i'm still not able to make it work...
                          My gateway is an arduino uno and my node a mini pro 3.3v 8mhz ...
                          i don't have anny capacitor for the radio and i could pass this afternoon at an electronic store...
                          do i need one for my gateway AND my node ?
                          on the my sensor web site they recommand 47µF but on the forum i saw at some place that i should use 100µF
                          TheoLT 1 Reply Last reply
                            TheoLT
                            TheoLT
                            TheoL
                            @Dominic-Bonneau you'll need one capacitor for each radio. So in your case two, one for the gateway and one for the node.
                            I hear some people use a 47uF others a 100uF. Since I've hear no complaints about the 100uF I'd use a 100uF. The bigger means in these case, that the capacitor can store a bit more power. If you're not sure buy two of both. They're really cheap - at least they should be.
                            sinczeS 1 Reply Last reply
                            • TheoLT TheoL
                              sinczeS
                              sinczeS
                              sincze
                              MySensors Evangelist
                              @TheoL , Indeed. I use 47uF and 100uF , just the first one I grab out of the spare tool box ;-) I use them with my NANO's and Rf24 antenna.
                              Ow yes, and I power all from the NANO ;-)
                              As long as I don't add the LED FLASH and the external big antenna
                              I'm fine. If I use the external antenna with LED FLASH... no way that it works.
                              If I just use the external antenna without LED FLASH there is enough power in the capacitor to help the antenna do its thing ;-0
                              • sinczeS sincze
                                TheoLT
                                TheoLT
                                TheoL
                                @sincze Hello my friend.
                                If you want flashing lights as well, I guess you have to an external power adapter. use a power regulator to power the radio with the big antenna. If you have a multi meter I advice to buy a couple of these:
                                buck converter
                                They're great and you can adjust the output by turning the potentiometer, but you'll need a multimeter to calibrate it. It's a cheap and easy power regulator solution, which is also very efficient (Thanx to @AWI)
                                • sinczeS
                                  sinczeS
                                  sincze
                                  haha tnx
                                  Gues what.
                                  I just looked in the box of gadgets.
                                  they are ... in the box still in plastic.Let's find out ;-)
                                  • sinczeS sincze
                                    haha tnx
                                    Gues what.
                                    TheoLT
                                    TheoLT
                                    TheoL
                                    @sincze Good luck. Let me hear of it works. Just be sure to power the buck converter externally and not from the Arduino.
                                    Also on the back is an arrow which points from the Input through the output. But you're a smart guy, you've probably already figured that one out yourself.
                                    • TheoLT TheoL
                                      sinczeS
                                      sinczeS
                                      sincze
                                      @TheoL 12v attached, still no blue smoke. Let's bring it down to 3,3 for the antenna. Off-topic: Seems a bit of overkill to use this unit for just the antenna ??
                                      • sinczeS sincze
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        @sincze I've got some buck converters that regulate 12V to 3.3V without any pain. I use it for my gesture controlled lamp. Works like a charm.
                                        Well I'm by far any export on this field. But I'm working on a node which I couldn't get stable. The Node crashed after 6, 8 sometimes 12 hours. I've added a watchdog, which works great, but after the watchdog did it's work some sensors on the node just couldn't work. Although I've powered them externally.
                                        To make this story shorter ;-). I found out that it's better to always power the radio externally. For some kind of reason it consumes more power than my ProMini 3.3V can provide. This symptom occurs when you add multiple sensors to an Arduino. It took me a long time to investigate what the problem was. But my conclusion is, just don't power anything from the Arduino and use an external power adapter if possible.
                                        Except for dedicated Arduino's that can be found on openhardware. My sensebender has been running for 4 month on the same batteries without any problems.
