  3. Which Arduino IDE version?
31 Posts 12 Posters 14.9k Views 12 Watching
  • TheoLT TheoL
    Just doing some last minute changes for the presentation of the workshop.
    I've read on the forum that not all version of the Arduino IDE work well with MySensors 2.0? What's the best version to use?
    @TheoL I'm using 1.6.8 and I think I've seen that version mentioned in some threads as well.
    I have also has luck with using 1.6.9 but downgrading the Arduino library (through the library manager) one step. Without downgrading something was broken but I don't remember what.
    I would recommend to use the latest version, to make the content reusable in the future without having to update everything that mentions a version. But using the latest version comes with a risk of course.
    • TheoLT TheoL
      @TheoL there is an issue with the avr compiler used in all 1.6.x versions, mysensors 2.0.x and debug enabled. This combination causes resets on w5100 gateways.
      Apart from that I would just use the latest one (1.6.11 at the time of writing I think)
      TheoLT sundberg84S 2 Replies Last reply
      • YveauxY Yveaux
        TheoLT
        TheoLT
        TheoL
        wrote on last edited by TheoL
        @Yveaux I'll be using a serial gateway with soft SPI (don't ask why ;-) it's a left over stackable print I soldered for an old WS5100 Arduino Uno ethernet gateway) so 6.11 would be okay for the participants?
        p.s. thack stackable radio print with the LEDs just sticking it adds to the tinker experience ;-)
        • TheoLT TheoL
          @TheoL I'm not aware of any issues, but for safety I should be careful when defining MY_DEBUG and test your setup upfront (which you probably will :bowtie:)
          TheoLT 1 Reply Last reply
          • YveauxY Yveaux
            sundberg84S
            sundberg84S
            What is the correct way to handle this? (Im upgrading my w5100 with 2.0). Using an older avr compiler or its fixed in dev?
            • tbowmoT
              tbowmoT
              tbowmo
              @sundberg84
              Its a bug in the compiler. Which should be fixed in a newer version of gcc. @tekka did some investigations together with arduino folks on this. So I think he has more info
              tekkaT 1 Reply Last reply
              • tbowmoT tbowmo
                @sundberg84
                tekkaT
                tekkaT
                tekka
                @sundberg84 Yes, read here for further information related to the compiler bug: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=77326
                • YveauxY Yveaux
                  TheoLT
                  TheoLT
                  TheoL
                  @Yveaux Today we uploaded the serial gateway with soft SPI. The radio initializes and the gateway doesn't reset. Tonight my colleague will try it home, since it would interfere with my own serial gateway network. But I think it will work. Never did soft SPI on a serial gateway, and probably no one has ever tried that before ;-)
                  • tekkaT tekka
                    TheoLT
                    TheoLT
                    TheoL
                    @tekka Great job. Hopefully they'll soon release a bug fix for this.
                    • TheoLT
                      TheoLT
                      TheoL
                      Confirmed that soft SPI also works an a Serial Gateway. Uploaded 2.0 on that one and tested with 1.5 sketch.
                      • TheoLT TheoL
                        tekkaT
                        tekkaT
                        tekka
                        @TheoL Maybe important for your MySensors tutorial: I suggest using Arduino IDE 1.6.11 with AVR board defs 1.6.11 (1.6.12 and 1.6.13 seem buggy, at least regarding the Ethernet lib)
                        • tekkaT tekka
                          sundberg84S
                          sundberg84S
                          @tekka - If i want to build myself a ethernet gw with 2.0 it should work if i download and use IDE < 1.6.12 ?
                          • sundberg84S sundberg84
                            tekkaT
                            tekkaT
                            tekka
                            @sundberg84 Not IDE, but AVR board defs 1.6.11
                            • tlpeterT
                              tlpeterT
                              tlpeter
                              And how do i downgrade AVR board devs?
                              • AndurilA
                                AndurilA
                                Anduril
                                in your IDE go to tools -> boards: "..." -> board manager and there select Arduino AVR board in the correct version.
                                • tlpeterT
                                  tlpeterT
                                  tlpeter
                                  Thanks, i would not have found that by myself :smile:
                                  • petewillP
                                    petewillP
                                    petewill
                                    It has been a long time since I've updated my IDE (currently running 1.6.6) and I wanted to update before I start converting everything to MySensors 2.0. I noticed that there is a newer version 1.6.12 and the bug reported above appears to have been fixed. Has anyone used the newest IDE and boards files? I will be using an Ethernet gateway but I'm not sure if it is still best to downgrade the boards files. Thanks!
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      Crash still happens using the latest version, downgraded to 1.6.11 :(
                                      petewillP 1 Reply Last reply
                                      • Mark SwiftM Mark Swift
                                        petewillP
                                        petewillP
                                        petewill
                                        @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          My W5100 will not start with 1.6.14, it just reboots after getting an IP...
