  3. Which Arduino IDE version?
31 Posts 12 Posters 14.9k Views 12 Watching
  • YveauxY Yveaux
    @TheoL there is an issue with the avr compiler used in all 1.6.x versions, mysensors 2.0.x and debug enabled. This combination causes resets on w5100 gateways.
    Apart from that I would just use the latest one (1.6.11 at the time of writing I think)
    TheoLT
    TheoLT
    TheoL
    wrote on last edited by TheoL
    @Yveaux I'll be using a serial gateway with soft SPI (don't ask why ;-) it's a left over stackable print I soldered for an old WS5100 Arduino Uno ethernet gateway) so 6.11 would be okay for the participants?
    p.s. thack stackable radio print with the LEDs just sticking it adds to the tinker experience ;-)
    • TheoLT TheoL
      @TheoL I'm not aware of any issues, but for safety I should be careful when defining MY_DEBUG and test your setup upfront (which you probably will :bowtie:)
      TheoLT 1 Reply Last reply
      • YveauxY Yveaux
        sundberg84S
        sundberg84S
        What is the correct way to handle this? (Im upgrading my w5100 with 2.0). Using an older avr compiler or its fixed in dev?
        • tbowmoT
          tbowmoT
          tbowmo
          @sundberg84
          Its a bug in the compiler. Which should be fixed in a newer version of gcc. @tekka did some investigations together with arduino folks on this. So I think he has more info
          tekkaT 1 Reply Last reply
          • tbowmoT tbowmo
            @sundberg84
            tekkaT
            tekkaT
            tekka
            @sundberg84 Yes, read here for further information related to the compiler bug: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=77326
            • YveauxY Yveaux
              TheoLT
              TheoLT
              TheoL
              @Yveaux Today we uploaded the serial gateway with soft SPI. The radio initializes and the gateway doesn't reset. Tonight my colleague will try it home, since it would interfere with my own serial gateway network. But I think it will work. Never did soft SPI on a serial gateway, and probably no one has ever tried that before ;-)
              • tekkaT tekka
                TheoLT
                TheoLT
                TheoL
                @tekka Great job. Hopefully they'll soon release a bug fix for this.
                • TheoLT
                  TheoLT
                  TheoL
                  Confirmed that soft SPI also works an a Serial Gateway. Uploaded 2.0 on that one and tested with 1.5 sketch.
                  • TheoLT TheoL
                    tekkaT
                    tekkaT
                    tekka
                    @TheoL Maybe important for your MySensors tutorial: I suggest using Arduino IDE 1.6.11 with AVR board defs 1.6.11 (1.6.12 and 1.6.13 seem buggy, at least regarding the Ethernet lib)
                    • tekkaT tekka
                      sundberg84S
                      sundberg84S
                      @tekka - If i want to build myself a ethernet gw with 2.0 it should work if i download and use IDE < 1.6.12 ?
                      • sundberg84S sundberg84
                        tekkaT
                        tekkaT
                        tekka
                        @sundberg84 Not IDE, but AVR board defs 1.6.11
                        • tlpeterT
                          tlpeterT
                          tlpeter
                          And how do i downgrade AVR board devs?
                          • AndurilA
                            AndurilA
                            Anduril
                            in your IDE go to tools -> boards: "..." -> board manager and there select Arduino AVR board in the correct version.
                            • tlpeterT
                              tlpeterT
                              tlpeter
                              Thanks, i would not have found that by myself :smile:
                              • petewillP
                                petewillP
                                petewill
                                It has been a long time since I've updated my IDE (currently running 1.6.6) and I wanted to update before I start converting everything to MySensors 2.0. I noticed that there is a newer version 1.6.12 and the bug reported above appears to have been fixed. Has anyone used the newest IDE and boards files? I will be using an Ethernet gateway but I'm not sure if it is still best to downgrade the boards files. Thanks!
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  Crash still happens using the latest version, downgraded to 1.6.11 :(
                                  petewillP 1 Reply Last reply
                                  • Mark SwiftM Mark Swift
                                    petewillP
                                    petewillP
                                    petewill
                                    @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      My W5100 will not start with 1.6.14, it just reboots after getting an IP...
                                        petewillP
                                        petewillP
                                        petewill
                                        @Mark-Swift Wow, that's strange. What Ethernet library are you using? I'm on 1.1.2.
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          @petewill same! :-(
                                          I will try it again when I find a moment, I was using DCHP, are you?
