  3. Which Arduino IDE version?
31 Posts 12 Posters 14.9k Views 12 Watching
  • TheoLT TheoL
    Just doing some last minute changes for the presentation of the workshop.
    I've read on the forum that not all version of the Arduino IDE work well with MySensors 2.0? What's the best version to use?
    @TheoL there is an issue with the avr compiler used in all 1.6.x versions, mysensors 2.0.x and debug enabled. This combination causes resets on w5100 gateways.
    Apart from that I would just use the latest one (1.6.11 at the time of writing I think)
    TheoLT sundberg84S 2 Replies Last reply
    • YveauxY Yveaux
      TheoLT
      TheoLT
      TheoL
      wrote on last edited by TheoL
      @Yveaux I'll be using a serial gateway with soft SPI (don't ask why ;-) it's a left over stackable print I soldered for an old WS5100 Arduino Uno ethernet gateway) so 6.11 would be okay for the participants?
      p.s. thack stackable radio print with the LEDs just sticking it adds to the tinker experience ;-)
      • TheoLT TheoL
        @TheoL I'm not aware of any issues, but for safety I should be careful when defining MY_DEBUG and test your setup upfront (which you probably will :bowtie:)
        TheoLT 1 Reply Last reply
        • YveauxY Yveaux
          sundberg84S
          sundberg84S
          What is the correct way to handle this? (Im upgrading my w5100 with 2.0). Using an older avr compiler or its fixed in dev?
          • tbowmoT
            tbowmoT
            tbowmo
            @sundberg84
            Its a bug in the compiler. Which should be fixed in a newer version of gcc. @tekka did some investigations together with arduino folks on this. So I think he has more info
            tekkaT 1 Reply Last reply
            • tbowmoT tbowmo
              @sundberg84
              tekkaT
              tekkaT
              tekka
              @sundberg84 Yes, read here for further information related to the compiler bug: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=77326
              • YveauxY Yveaux
                TheoLT
                TheoLT
                TheoL
                @Yveaux Today we uploaded the serial gateway with soft SPI. The radio initializes and the gateway doesn't reset. Tonight my colleague will try it home, since it would interfere with my own serial gateway network. But I think it will work. Never did soft SPI on a serial gateway, and probably no one has ever tried that before ;-)
                • tekkaT tekka
                  TheoLT
                  TheoLT
                  TheoL
                  @tekka Great job. Hopefully they'll soon release a bug fix for this.
                  • TheoLT
                    TheoLT
                    TheoL
                    Confirmed that soft SPI also works an a Serial Gateway. Uploaded 2.0 on that one and tested with 1.5 sketch.
                    • TheoLT TheoL
                      tekkaT
                      tekkaT
                      tekka
                      @TheoL Maybe important for your MySensors tutorial: I suggest using Arduino IDE 1.6.11 with AVR board defs 1.6.11 (1.6.12 and 1.6.13 seem buggy, at least regarding the Ethernet lib)
                      • tekkaT tekka
                        sundberg84S
                        sundberg84S
                        @tekka - If i want to build myself a ethernet gw with 2.0 it should work if i download and use IDE < 1.6.12 ?
                        • sundberg84S sundberg84
                          tekkaT
                          tekkaT
                          tekka
                          @sundberg84 Not IDE, but AVR board defs 1.6.11
                          • tlpeterT
                            tlpeterT
                            tlpeter
                            And how do i downgrade AVR board devs?
                            • AndurilA
                              AndurilA
                              Anduril
                              in your IDE go to tools -> boards: "..." -> board manager and there select Arduino AVR board in the correct version.
                              • tlpeterT
                                tlpeterT
                                tlpeter
                                Thanks, i would not have found that by myself :smile:
                                • petewillP
                                  petewillP
                                  petewill
                                  It has been a long time since I've updated my IDE (currently running 1.6.6) and I wanted to update before I start converting everything to MySensors 2.0. I noticed that there is a newer version 1.6.12 and the bug reported above appears to have been fixed. Has anyone used the newest IDE and boards files? I will be using an Ethernet gateway but I'm not sure if it is still best to downgrade the boards files. Thanks!
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    Crash still happens using the latest version, downgraded to 1.6.11 :(
                                    petewillP 1 Reply Last reply
                                    • Mark SwiftM Mark Swift
                                      petewillP
                                      petewillP
                                      petewill
                                      @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        My W5100 will not start with 1.6.14, it just reboots after getting an IP...
                                          petewillP
                                          petewillP
                                          petewill
                                          @Mark-Swift Wow, that's strange. What Ethernet library are you using? I'm on 1.1.2.
