  3. [SOLVED ... partially] Ethernet gateway without radio don't present local sensors to domoticz
16 Posts 5 Posters 5.7k Views 4 Watching
  • toninT Offline
    toninT Offline
    tonin
    wrote on last edited by tonin
    First of all, as this is my first message, regards to all people that are working in this nice project. I hope to collaborate from now because I have decided to use this project with domoticz to make my projects.
    My project have a RPI controller with domoticz, and two arduino mega 2560 compatible board, one using USB gateway directly attached to the RPI and other with w5100 compatible shield in a remote site. using mysensors V2 library with the Ethernet gateway sketch (not the MTQQ variant). Now the RPI and the W5100 are plugged to a local switch, in the future I'll use two PLC to connect them.
    When I put this code in presentation function in the Ethernet Gateway sample sketch:
    void presentation(){
        sendSketchInfo("Arduino Ethernet", "1.0");
        present(15, S_LIGHT,"My test relay");
    I don't get any registration in domoticz. Using the same code in gateway USB the sketch info and the test relay device are registered ok.
    In my test I:
    • Commented all #define of MY_RADIO_XXXX to use only local sensors and relays an avoid radio errors.
    • Define the IP of the gateway, the IP of the controller, the MAC, the port, etc and add the gateway in the hardware of domotiz. I can ping the gateway from my network, domoticz show in the log that is connected and in the serial console of the gateway I receive the PING messages that I suppose tha come from the controller.
    But there is no way to get the test relay and the sketch name registered in domotixz. With the USB gateway I have now a sketch tha present 8 relays and one temperature sensor that works fine, I can turn on/off all relays, read the temperature, etc.
    Anyone have a idea that which is the problem?
    Regards.
    • toninT tonin
      In my test I:
      Regards.
      Welcome @tonin, great to have you here!
      Domoticz does not display any devices until the first value has been sent. This has confused a lot of people. Could that be the case here?
      • toninT Offline
        toninT Offline
        tonin
        I don't think so because a relay is an s_switch than don't send data, only receive orders from the controller to switch on or off.
        Also in the usb gateway i get the registration of relays. Anyway i'll try to put one temp sensor in the ethernet gateway to see if it appear in domoticz.
        • toninT Offline
          toninT Offline
          tonin
          I do some tests. In the serial console of the usb gateway, after sendSketch and calls to present functions, with MY_DEBUG defined I see the message sent to the controller.
          In the ethernet gateway sample I can do a telnet to the ip and port of the gateway, type anything and I see the "connect" message in the serial console. But the sendSketch and present functions don't show anything in the serial console and of course nothing in the telnet session.
          Also if I call a send function with any arbitrary message, I can't see anything in the serial or the telnet. It seems that the send function or any function that it calls isn't working right in ethernet gateway.
          I cleared the eprom of the arduino but no way. I'm trying to put more debug code in the core library to see what is happening.
          • toninT tonin
            T Offline
            T Offline
            TheoL
            @tonin I'm following this with much curiosity. My first guess was that it can't work. Because the gateway shouldn't startup, in my mind at will stop the bootup sequence because there's it can't initialize the radio. At least that's what I expected.
            toninT 1 Reply Last reply
            • toninT Offline
              toninT Offline
              tonin
              Mystery solved ....
              I was using client mode gateway because in server mode my arduino mega reset every time that send an ethernet packet. In client mode as I say, domoticz connect to the arduino but there is no traffic from arduino to RPI domoticz presenting my relays. I read that client mode is buggy at this time, so I try to get server mode without the resets.
              To avoid resets in my chinese arduino mega 2560 & chinese w5100 I need to downgrade de AVR library from 1.6.13 to 1.6.11. So all works Ok with my to gateways (usb & ethernet() connected to my RPI domoticz controller.
              • T TheoL
                toninT Offline
                toninT Offline
                tonin
                @TheoL No, in mysensors 2.0 you can have gateways with local sensors or relays without radio only commenting all radio #define's
                • toninT tonin
                  Mystery solved ....
                  T Offline
                  T Offline
                  TheoL
                  @tonin Great to hear you've solved it.
                  • TmasterT Offline
                    TmasterT Offline
                    Tmaster
                    wrote on last edited by Tmaster
                    Hi. I have the same problem with my serialgateway. its usb conected to VERA 3
                    (ui7).
                    There are no inclusion on vera. Normally i use the software arduino gateway start button on vera to include ,and reset the sensor be detected. Now my buzzer(relay based sketch) it's on gateway.
                    What i do now for vera include my buzzer???? :disappointed:
                    i even dont know if the scketch work but i need inclusion first...
                    #define CHILD_ID 5
                      sendSketchInfo("BUZZER", "1.0");
                        present(CHILD_ID,S_DOOR);
                      if (message.type==V_TRIPPED)
                        tone(2, 2500, 1000) ;
                    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                    • toninT Offline
                      toninT Offline
                      tonin
                      Try to call the presentation function in setup. I remembered that i needed to do it on usb gateway, the ethernet gateway has a patched code to call presentation after connection to the controller.
                      • TmasterT Offline
                        TmasterT Offline
                        Tmaster
                        Not worked. I think maybe i need an include button or some function that preset that sensor after gateway was already running and waiting for messages..I don't now. This new feature on gateway was one of my requests but still a mistery for me how it work :P
                        • toninT Offline
                          toninT Offline
                          tonin
                          This code
                          //Comento la siguiente linea para que no necesite radio
                          //#define MY_RADIO_NRF24
                          // Enable serial gateway
                          #define MY_GATEWAY_SERIAL
                          #if F_CPU == 8000000L
                          #define MY_BAUD_RATE 38400
                          // Flash leds on rx/tx/err
                          // Set blinking period
                          // Enable inclusion mode
                          //Para el sensor de temperatura
                          #ifdef TEMP
                           #include <OneWire.h>
                           #define ONE_WIRE_BUS 2
                           MyMessage msg(0,V_TEMP);
                          //Structura de reles
                          typedef struct  {
                           int  pin;
                           char desc[20];
                           bool ON;
                           bool OFF;
                          } sRELE;
                          sRELE Rele [] = { {13 , "LED", HIGH, LOW},
                                           {31 , "RELE ASPERSOR PORCHE", LOW, HIGH},
                                           {33 , "RELE TURBINAS", LOW, HIGH},
                                           {35 , "RELE GOTEROS BAJOS", LOW, HIGH}
                          #ifdef TEMP
                           sensors.begin();
                           //Para los reles
                             Serial.println("start call Setup");
                           for (int sensor=0 ; sensor<NUMBER_OF_RELAYS;sensor++) {
                             // Poner el rele en output mode
                             pinMode(Rele[sensor].pin, OUTPUT);
                             // Poner el rele en el ultimo estado conocido (usando eeprom storage)
                             digitalWrite(Rele[sensor].pin, loadState(sensor)?Rele[sensor].ON:Rele[sensor].OFF);
                             Serial.println("End call Setup");
                             presentation();
                           // Presentar los sensores y actuadores locales
                           Serial.println("start call presentation");
                           // Mandar la info del sketch
                           sendSketchInfo("Arduino USB", "1.0");
                           //Presentar los reles
                           for (int rele=0; rele<NUMBER_OF_RELAYS;rele++) {
                             // Registrar todos los reles al gw
                             present(rele, S_LIGHT,Rele[rele].desc);
                           Serial.println("End call presentation");
                          #ifdef TEMP
                           //Presento el sensor de temperatura
                           present(9,S_TEMP,"SENSOR_TEMP");
                          bool STATUS;
                          #ifdef TEMP
                           Serial.print("Solicitando temperaturas...");
                           sensors.requestTemperatures(); // Send the command to get temperatures
                           float temperatura = sensors.getTempCByIndex(0);
                           send(msg.setSensor(9).set(temperatura,1));
                           Serial.println("DONE");
                           sleep(2000);
                           // Solo esperamos mensajes V_LIGTH de momento, pero lo chequeamos por si acaso.
                           if (message.type==V_LIGHT) {
                              // Cambiar estado del rele
                              digitalWrite(Rele[message.sensor].pin, message.getBool()?Rele[message.sensor].ON:Rele[message.sensor].OFF);
                              // Almacenar estado en la eeprom
                              // Escribir informacion de debug
                              Serial.print("Cambio entrante para sensor:");
                              Serial.print(", Nuevo status: ");
                          works ok for me. As you can see I define the relays in an structure to do it configurable. The only trick for me is to call the presentation function in the setup function. In the ethernet gateway it isn't needed.
                          A note for the structure sRELE. yo can see the pin, description and the state of the pin that mean ON or OFF. It's so because my relay boards have an inverse logic. When the pin is in low state, the relay is on. This relay boards are opto coupled and have an isolated circuit between arduino pins and relays, this is the reason for that.
                          The sample code also have some lines to read temperature from a dallas sensor.
                          I hope that this help you.
                          • TmasterT Offline
                            TmasterT Offline
                            Tmaster
                            Viva la espanã:p :palm_tree: . gracias.
                            Tankyou.I will try tomorow. :+1:
                            • TmasterT Offline
                              TmasterT Offline
                              Tmaster
                              hi. i just add presentation function on setup but still the same. No sign of the sensor on vera. maybe yor sketch its sending back another call in some other line ... i can't make it work.
                              changes:
                                presentation();
                                   // Change relay state
                                   //digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                                   // Store state in eeprom
                                   //saveState(message.sensor, message.getBool());
                              • H Offline
                                H Offline
                                This was fixed in development back in august but has not yet made it to master branch (which you might be using if you downloaded through library manager).
                                https://github.com/mysensors/MySensors/pull/532
                                • TmasterT Offline
                                  TmasterT Offline
                                  Tmaster
                                  So i need install the devbranch. . i will try...
                                  thankyou
                                  12.1k
