  3. What does !TSP:MSG:PVER mismatch mean?
12 Posts 5 Posters 6.6k Views 5 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    I have a DHT11 running for about 2 weeks now and suddenly the GW says the following lines over and over again:
    What does that mean?
    0;255;3;0;9;TSP:MSG:READ 101-101-101 s=101,c=5,t=101,pt=3,l=12,sg=1:25957
    0;255;3;0;9;!TSP:MSG:PVER mismatch
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      https://ci.mysensors.org/job/Verifiers/job/MySensorsArduino/branch/development/Doxygen_HTML/group__MyTransportgrp.html
      You seem to have some serious problems with your radio the data in the log looks corrupted. I.e. t=101...
      • TmasterT
        TmasterT
        Tmaster
        It happens to me with an amplified version of nrf24. i change the module and works fine
        i'm a arduino fan .Even sometimes don't undestanding how to use it :P
        • Martin TellblomM
          Martin TellblomM
          Martin Tellblom
          I restarted the sensor and it now works like a charm, haven't done anything to it.
          I have to wait another two weeks to see if it happens again
          Thanks @hek for the link ( I was looking for that the other day)
          • Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            This started today again and if I read the values correctly its a sensor with ID 101?
            What I can find I can decode this:
            TSF:MSG:READ,sender-last-destination,s=%d,c=%d,t=%d,pt=%d,l=%d,sg=%d:%s
            s=sensor ID
            c=command
            t=msg type
            pt=payload type
            l=length
            sg=signing flag
            But I can't find what the values mean.
            The other problem is that I do not have a sensor with id 101! I think this is something else that is messing with my radio.
              The radio looks seriously broken or underpowered. I've seen similar results when trying to use an amplified radio (with high PA level) and supplying it with too little power.
              • Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                You mean the gateway I suppose? The radio is a NFR24L01+ with PA and LNA. a cap (right now the UNO is power by a computer USB port)
                  Try lowering pa -level
                  or
                  #define MY_RF24_PA_LEVEL RF24_PA_MIN
                  • Martin TellblomM
                    Martin TellblomM
                    Martin Tellblom
                    Thanks, I try it
                    • Daniel ErikssonD
                      Daniel ErikssonD
                      Daniel Eriksson
                      I am having exactly the same issue with 2.0, works fine with 1.5.
                      Using Arduino Mini Pro 5v - I do not have a Decoupling-Capacitor cause it hasnt been needed for 1.5 will that really be needed with 2.0?
                      • Daniel ErikssonD Daniel Eriksson
                        Yes. Decoupling was needed for 1.5 as well, but in some cases people were lucky and it happened to work anyway. Being lucky can work with 2.0 as well, but relying on luck for your home automation is not recommended.
                        Daniel ErikssonD 1 Reply Last reply
                          Daniel ErikssonD
                          Daniel ErikssonD
                          Daniel Eriksson
                          @mfalkvidd Ah ok, then I just have to wait for the stuff :) Thanks!
