  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.9k Views 53 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Battery Powered Sensors" posted on MySensors.org.
    • GertSandersG
      GertSandersG
      GertSanders
      Here is a view of a node running exactly 1year. The effect of a bad radio is seen here as the fast voltage drops. I had a very low charged battery to start with, replaced it with new batteries which also discharged fast, and replaced both batteries and the radio. Since mid january 2016 the node has been running as expected. My guess is that this combo will run for 2 years (given how it has been working the past 9 months).
      This node measures battery voltage, temperature and humidity and sends 3 messages about every 5 minutes.
      And here is the battery measurement of the second node that went "online" the same day (18/sep/2015, with a good radio, and similarly used batteries from the start). This node sends very few messages (at least 1 every 24 hours, and when one of 3 contacts are opened). Most days it just sends 1 message.
      So even with batteries already at a low level, you can make useful nodes using the MySensors setup :-)
      C 1 Reply Last reply
      • CravecodeC
        CravecodeC
        Cravecode
        • N
          N
          Nicklas Starkel
          Sorry, where do you measure the power when it is in sleep mode? ie, where do you put your multimeter probes.
          • N Nicklas Starkel
            @Nicklas-Starkel you put them in serial. So:
            battery+ to multimeter- (set to uA mode)
            Multimeter+ to vcc
            Battery- to gnd
            You need a very sensitive multimeter though. Most multimeters won't be able to measure low current reliably.
            N 1 Reply Last reply
              Multimeter+ to vcc
              Battery- to gnd
              N
              N
              Nicklas Starkel
              @mfalkvidd that's what I thought! I see that I'm getting 3.4V in the multimeter but my pro mini nor nano will start up (I have not removed the LEDs so they should light up).
              If I use more V (6.8V) I put in via RAW on the PRO mini, and I can see teh voltage, but the same thing, it's not starting up, hmmm I wonder what rookie mistake I'm doing!
              • N Nicklas Starkel
                @Nicklas-Starkel sounds like you have the multimeter set to measure voltage instead of current. Which multimeter model are you using? Could you post a photo? There is usually a dial that can be turned to switch mode. Many multimeters also require moving one of the probes to a different connector (on the multimeter itself).
                  N
                  N
                  Nicklas Starkel
                  @mfalkvidd , it was too late at night for me.
                  I had it at current but it didn't show anything. So without thinking I put it at voltage.
                  And the problem with not showing anything when I had it at current was I had blown the internal multimeter fuse some days ago.
                  Ehrmm.. yes. move along, nothing to see here :)
                  • N Nicklas Starkel
                    @Nicklas-Starkel great that you figured out what was wrong
                    • bjacobtB
                      bjacobtB
                      bjacobt
                      Hi, I built this circuit and arduino reads 1.11 V or 33%. I've new batteries and multimeter reads 3.10 volts. Do you know what could be wrong? I'm using 1M and 470k resistors on pin A0.
                      • tonnerre33T
                        tonnerre33T
                        tonnerre33
                        Did you put this command in the setup sketch ?
                        analogReference(INTERNAL);
                        • bjacobtB
                          bjacobtB
                          bjacobt
                          @tonnerre33, yes I've analogReference(INTERNAL); in setup()
                          • tonnerre33T
                            tonnerre33T
                            tonnerre33
                            It's normal to have 1.1V on A0 when you have 3.3V on your batteries.
                            Where did you get the 1.11V value ? In the serial print or with your multimeter ?
                            If you read the value with the serial print, which variable is it (sensorValue or batteryV) ?
                            • bjacobtB
                              bjacobtB
                              bjacobt
                              @tonnerre33 in the serial print and MySensor MQTT gateway
                              • bjacobtB
                                bjacobtB
                                bjacobt
                                @tonnerre33, I'm trying to build arduio that can run on 2 AA batteries. I'm using MySensors for library and building arduino circuit based on this https://openhomeautomation.net/arduino-battery/
                                • tonnerre33T
                                  tonnerre33T
                                  tonnerre33
                                  Can you post the logs of your node and the skech used ?
                                  bjacobtB 1 Reply Last reply
                                  • bjacobtB bjacobt
                                    @bjacobt https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level describes how the battery voltage is calculated and the example sketch has code for doing the calculation. Looks like you've missed reading this part:
                                    • tonnerre33T tonnerre33
                                      bjacobtB
                                      bjacobtB
                                      bjacobt
                                      @tonnerre33
                                      Here are the logs from Arduino Serial console
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=101)
                                      TSM:FPAR
                                      TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=101)
                                      TSM:UPL
                                      TSP:PING:SEND (dest=0)
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                      TSP:MSG:READ 0-0-101 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:Battery Meter
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                      Request registration...
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-101 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=101, parent=0, distance=1, registration=1
                                      330
                                      Battery Voltage: 1.11 V
                                      Battery percent: 33 %
                                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:33
                                      The sketch used is this:
                                      #define MY_NODE_ID  101
                                      unsigned long SLEEP_TIME = 100000;  // sleep time between reads (seconds * 1000 milliseconds)
                                      int oldBatteryPcnt = 0;
                                         analogReference(INTERNAL1V1);
                                         sendSketchInfo("Battery Meter", "1.0");
                                         // get the battery Voltage
                                         #ifdef MY_DEBUG
                                         Serial.println(sensorValue);
                                         #ifdef MY_DEBUG
                                         Serial.print(batteryV);
                                         Serial.println(" V");
                                         Serial.print(batteryPcnt);
                                         Serial.println(" %");
                                           // Power up radio after sleep
                                           oldBatteryPcnt = batteryPcnt;
                                         sleep(SLEEP_TIME);
                                      What I see on the gateway is:
                                      mysGateway: TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      mysGateway: TSF:MSG:BC
                                      mysGateway: TSF:MSG:FPAR REQ,ID=101
                                      mysGateway: TSF:PNG:SEND,TO=0
                                      mysGateway: TSF:CKU:OK
                                      mysGateway: TSF:MSG:GWL OK
                                      mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                      mysGateway: TSF:MSG:PINGED,ID=101,HP=1
                                      mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      mysGateway: !TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/6
                                      mysGateway: TSF:CKU:OK,FCTRL
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
                                      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/11
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/12
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                      mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=0,pt=1,l=1,sg=0:33
                                      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/0```
                                      Thank for your help!
                                      Jacob
                                        bjacobtB
                                        bjacobtB
                                        bjacobt
                                        hi @mfalkvidd,
                                        Do you mind clarifying a bit, I've done sensorValue * 0.003363075
                                        Gives me 330, so
                                        330 * 0.003363075 = 1.10981475 volts
                                        Thank You!
                                        Jacob
                                        • bjacobtB bjacobt
                                          hi @mfalkvidd,
                                          Gives me 330, so
                                          Thank You!
                                          Jacob
                                          @bjacobt hmm. Yes, you are correct. The calculation seem a bit strange.
                                          Using this calculator I entered
                                          output 1.10981475 V
                                          R1 1000000
                                          R2 470000
                                          Which gives a battery voltage of 3.471V
                                          Looks like the calculations in the sketch are wrong? Or at least confusing :) I'm pretty lost.
