  3. some problem in sensor + repeater !
15 Posts 3 Posters 4.6k Views 2 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    hi i have some problem to convert a node to sensor+repeater !
    for example light sensor :
    #include <BH1750.h>
    #define CHILD_ID_LIGHT 0
    BH1750 lightSensor;
    // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
    // If your controller supports the new V_LEVEL variable, use this instead for
    // transmitting LUX light level.
    // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux;
      gw.begin();
      gw.sendSketchInfo("Light Lux Sensor", "1.0");
      lightSensor.begin();
      Serial.println(lux);
      if (lux != lastlux) {
          gw.send(msg.set(lux));
          lastlux = lux;
      gw.sleep(SLEEP_TIME);
    i remove lines :
    and
    and i add #define MY_REPEATER_FEATURE
    sensor is start to report many lux... each second 1000 report . . .
    please change this code to a repeater+sensor and report every 1 min !
    B 1 Reply Last reply
    • R Reza
      #include <BH1750.h>
      BH1750 lightSensor;
      uint16_t lastlux;
        gw.begin();
            lastlux = lux;
      i remove lines :
      and
      B
      B
      boozz
      @Reza
      You can change your code yourself: replace gw.sleep(sleep_time) by gw.wait(sleep_time).
      Given the posted code I think you use the MySensors 1.5 libraries.
      BR,
      Boozz
      R 1 Reply Last reply
      • B boozz
        @Reza
        BR,
        Boozz
        R
        R
        Reza
        @boozz
        hi thank you for help me ,
        now i use 2 library . and in some sketchs (sensor without repeater) , there are 2 line for sleep :
        sleep(SLEEP_TIME);
        for convert this sensors to sensor+repeater , what am i do ?
        add line:
        and change this line to :
        sleep(SLEEP_TIME); ~~> wait(SLEEP_TIME);
        is this correct ?
        • R Reza
          @boozz
          sleep(SLEEP_TIME);
          add line:
          is this correct ?
          B
          B
          boozz
          @Reza
          Instead of asking people in the forum at every step you take, you could use the trial and error method.
          BR,
          Boozz
          • B boozz
            @Reza
            BR,
            Boozz
            R
            R
            Reza
            @boozz
            :) ok but if it is possible guidance me just This time
            this is true ?
            sleep(SLEEP_TIME); ~~> wait(SLEEP_TIME); ?
            thank you
            • R Reza
              @boozz
              this is true ?
              thank you
              B
              B
              boozz
              @Reza
              just try it and see what happens
              • B boozz
                @Reza
                R
                R
                Reza
                ok thank you :(
                  @Reza
                  @boozz has already answered you how to. You should try, that does not hurt, and you may be happy by the result. You don't want a sleeping repeater? better a waiting repeater!
                  That said i would not use the wait, it's possible to code this quicker. But it's a little bit more advanced.
                  I advice you to read some reference about Arduino etc... and try. always try or you don't learn anything!
                  An howto which could be useful for you, perhaps later, is the blink led without delay from Arduino Reference for instance. And lot of other things. That's not always easy to write code for others, can take time or not same config. and others don't learn then..
                  R scalzS 2 Replies Last reply
                  • scalzS scalz
                    @Reza
                    R
                    R
                    Reza
                    hi my friend , i know this but about this issue , i need this quickly and I don't have time for begin in arduino and full programming :(
                      Have you tried ??
                      well, about needing quickly, without learning... you're perhaps misunderstanding a bit things.. imho mysensors is great, open, dynamic community which try to make things easier for noobs. Sure that's very attractive, but don't forget you're in arduino/dev/mcu world...if you don't want to read&learn a minimum, you will be stuck in the examples sketch folders...
                      • scalzS scalz
                        Have you tried ??
                        R
                        R
                        Reza
                        @scalz said:
                        Have you tried ??
                        i want try to learn but not now ! now i need this quickly :( so after this i try to learn step by step. . .
                          okay but have you tried wait instead of sleep?? we still don't know..
                          • scalzS scalz
                            R
                            R
                            Reza
                            no
                            well , this topic for this !!! i told you , can i replace wait Instead sleep? i fear for The arbitrary action so before i want sure
                            • scalzS scalz
                              @Reza
                              No fear to have! A sleep or wait won't burn your node.
                              I told you above:
                              what do you think ;) Does a repeater should sleep?? If so, how could he listens and repeat? So.. the repeater can't sleep! you would prefer to use wait, so it listens/wait and repeat.
                              I hope this is okay. If you have a problem then why not, but imho your issue is solved.
                              • scalzS scalz
                                I told you above:
                                R
                                R
                                Reza
                                @scalz
                                so i test with wait :) thank you my friend
