  3. Domoticz
  4. ESP8266 GW with sensors
11 Posts 2 Posters 4.1k Views 2 Watching
  • Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    I´m using MySensors dev branch 2.0.1 as I heard this one should allow GW´s to have sensors on them and show for controllers.
    I´m using a NodeMCU with the follow sketch, I can add the GW and it shows up, it presents me with nodes and there I can see S_LIGHT_LEVEL but there is no Name or Value to it. And I do not see any device.
    Can anyone see some error in the code?
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "******"
    #define MY_ESP8266_PASSWORD "*********"
    // Enable UDP communication
    //#define MY_USE_UDP
    // #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_IP_ADDRESS 10,35,10,70
    #define MY_IP_GATEWAY_ADDRESS 10,35,10,1
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
      #include <ESP8266WiFi.h>
    #define CHILD_ID_LIGHT 0
    int lastLightLevel;
      sendSketchInfo("Light Sensor", "1.0");
        int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      sleep(SLEEP_TIME);
    • Patrik SöderströmP Patrik Söderström
      int lastLightLevel;
        sleep(SLEEP_TIME);
      @Patrik-Söderström the sketch looks fine to me.
      Could you post the serial debug output?
      Adding Serial.println(lightLevel); after int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23; could also be useful, to verify the value read. The analog pin on ESP8266/NodeMcu is a bit special. For example, it is only able to read voltages up to 1V.
        Patrik SöderströmP
        Patrik Söderström
        wrote on last edited by Patrik Söderström
        The Serial.printIn(lightLeve) is there already.
        Serial Monitor
        0;255;3;0;9;Client 0: 0;0;3;0;18;PING
        -6306
        0;255;3;0;9;MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
        0;255;3;0;9;!MCO:SLP:REP
        Telnet
                                              0;255;0;0;18;2.0.1-beta
        0;255;3;0;11;Light Sensor
              0;255;3;0;12;1.0
                              0;0;0;0;16;
                                         0;255;3;0;2;2.0.1-beta
                                                               0;255;3;0;22;14999
        0;255;3;0;22;25062
                   0;255;3;0;22;35146
                                     0;255;3;0;22;45277
                                                       0;255;3;0;22;55305
        0;255;3;0;22;65331
           0;255;3;0;22;75360
        I´m using a LM393 Light sensor, if that helps.
          It is. Sorry.
          -6306
          So your lightLevel is -6306. The value is expected to be between 0 and 100 I think. So we're getting closer to the source of the problem.
          -6306 * 10.23 is -64,510.38. int16_t can only hold values between -32,678 and +32,767. 64,510.38 is suspiciously close to 65,535. So my guess is that some calculation overflows.
          If the voltage on the analog pin is above 1V I think analogRead() will return 1024. The calculation 1023-1024=-1 which probably is unexpected.
          This could be verified by printing the return value of analogRead(LIGHT_SENSOR_ANALOG_PIN)
            Patrik SöderströmP
            Patrik Söderström
            65535 is the value I get when I print analogRead(LIGHT_SENSOR_ANALOG_PIN).
            So, then I´m unable to use this light sensor on this NodeMCU? I better set it up on some other node.
            Thanks for quick and informative replies :)
            • mfalkviddM
              You're welcome. It is still possible to use the sensor if you want to.
              The problem lies in that the light sensor gives values of up to 3.3V while the ESP analog pin can only read up to 1V.
              The voltage from the light sensor needs to be scaled down with a voltage divider, and the code needs to be changed to subtract from 65535 instead of 1023.
              A suitable voltage divider could be 330kohm and 680kohm.
                Instead of connecting LM393-A0 directly to NodeMcu-A0, connect LM393-A0 to a 680kohm resistor. Connect the other end of the resistor to NodeMcu-A0 AND to a 330khom resistor. Connect the other end of the 330kohm resistor to GND.
                It could be that 330/680kohm resistors are too large for the LM393 though. You could try with 330 and 680 ohm (not kohm).
                Patrik SöderströmP 1 Reply Last reply
                • mfalkviddM
                  If you don't have resistors at home, buy a set. They are cheap and great to have when tinkering. I bought these http://www.ebay.com/itm/131504016234
                    Patrik SöderströmP
                    Patrik Söderström
                    Thanks! :)
                    Yes I ordered a couple of days ago, waiting for them :) Need them for the temp. sensor as well.
                      Patrik SöderströmP
                      Patrik SöderströmP
                      Patrik Söderström
                      @mfalkvidd how did you come up with what kind of resistor I should use? Could be good to know in coming project. If you want to share, thanks :)
                        @Patrik-Söderström I used this calculator.
                        I entered 3.3V as the input voltage and 1.0 as the output voltage. I set R2 to 330 which is a common resistor value.
                        I pressed "Compute" and got a value of 759 for R1:
                        759 ohm is not a resistor value that is available, but I looked at the values in the pack on ebay and saw that the nearest was 680. I entered that in R1 and cleared the output field:
                        0_1475435362217_output_calc.png and pressed Compute again. I now got an output of 1.078V which can be seen as close enough to 1V.
                        This can of course be done by hand, and is a nice educational task if you want to learn the details :-)
                        The important part is the ratio between the two resistors. Try with 680,000 and 330,000 in the calculator and you'll see that you get the same output value. However, there is a third component: The LM393. It also has a resistor value. If the resistors in the voltage divider are small compared to the resistor in the LM393, the calculations will be correct. But if the resistors have about the same value as the resistor in the LM393 the calculations must take the LM393 into account. That's why 330 and 680 ohm probably works better than 330kohm and 680kohm.
                        A caveat with using small resistor values is that they will consume more power. This is important if the sensor is battery powered, but since the NodeMCU generally consumes too much power to run on battery anyway we can ignore the power consumption for now. As long as the resistors are at least 100ohm the used power will be less than what the NodeMCU consumes.
