  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 81.8k Views 44 Watching
    yes this is possible.
    • xydixX
      xydixX
      xydix
      Can i even have it powered during the process?
        that should work depending of the different voltage source. if your mini pro is 3v and also your programming tool, this is ok (but not the best advice ;) ). or keep your batt, and don't connect vcc from your programming tool. It's always better to use only one source if you're not sure and, also not sure if there are all protection .
        • xydixX
          xydixX
          xydix
          Sorry for asking stupid questions but, "USBtinyISP AVR ISP Programmer" from the shopping guide. Is this able to do the same as "usbasp (clone, USBASP 2.0 LC Technology)" in this guide.
            yes this should work
            • C
              C
              cdr
              For some reason I can't set the extended fuse to 0x06, it always reverts to 0xFE;
              avrdude.exe: verifying ...
              avrdude.exe: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
              This behaviour is deprecated and will result in an error in future version
              You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
              avrdude.exe: 1 bytes of efuse verified
              Anyone knows why?
                @cdr
                The Extended fuse handle the bod level. Only the 3 least significant bits are meaningful. Others are not used.
                Be careful: This is true for this fuse, not for all fuses, check datasheet or fuses calculator!
                That's why :
                • 0x06 = 00000110
                • 0xFE = 11111110
                are doing the same job for the extended fuse. It depends of the tool you use for burning this fuse. Simply, if you get this warning, use the "equivalent".
                • C
                  C
                  cdr
                  Thanks for the explanation, first try didn't work so I suspected the fuses, but turned out to be a voltage issue. :)
                  • starfish133S
                    starfish133S
                    starfish133
                    Is it possible to do OTA over RS485 connections?
                      Yes, it should be possible. The node doesn't really care which transport that was used.
                      • skywatchS
                        skywatchS
                        skywatch
                        Does OTA work with the NRF24L01+ modules?
                        • skywatchS skywatch
                          @skywatch yes.
                          skywatchS 1 Reply Last reply
                            @skywatch yes.
                            skywatchS
                            skywatchS
                            skywatch
                            @mfalkvidd
                            Thanks for the (very) fast reply!
                            I have arduino in my greenhouse and in winter when it can be constantly wet and cold it is a real pain to take the laptop out to make any changes. This would be a good solution that would allow me and my laptop to stay warm and dry! - - - But how do I stop any one else programming it remotely? Is there some security to stop random programs being installed (it is controlling mains electricity and I need to be sure it is a safe option.
                            tbowmoT 1 Reply Last reply
                              @mfalkvidd
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @skywatch
                              You can use signing to authenticate a firmware upload. Then the attacker first need to get your pre shared keys to reprogram via ota
                              • AndurilA
                                AndurilA
                                Anduril
                                @skywatch just to be complete: using signing as @tbowmo suggested only works with dualoptiboot bootloader.
                                When using MYSBootloader it will, as far as I know, accept any firmware when booting. To attack the node the attacker would have to reboot your node (power cycle,...) and then send his own firmware. So this is possible, but needs quite a good amount of control of your systems.
                                • AndurilA Anduril
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Anduril
                                  @tekka have been looking at making a secure Ota boot loader, if I remember right. I thought that it was released already.
                                  But if an intruder is able to get yo your node to do a reset in order to have the mysbootloader kick in, he could just as well put a new firmware in by attaching a programmer directly to the node.
                                  • b0rmannB
                                    b0rmannB
                                    b0rmann
                                    Is it possible OTA from linux without MYSController?
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      Thank you all for the responses. If someone gets physical access then the game is over anyway. I just want to protect from some bored malicious person getting remote access and causing problems or even a fire.
                                      If it is secure from 'others' hacking it remotely I might give it a try.
                                      • AndurilA
                                        AndurilA
                                        Anduril
                                        When initiating a ota firmware update MYSController sends a reboot message to the node. Does anyone knows if that is protected by signing (if enabled)? If so, it would be quite safe excluding the physical access.
                                        • chrilleC
                                          chrilleC
                                          chrille
                                          Same question as @b0rmann - is it possible to do OTA from a non-Windows environment (Mac OSX or Linux)? A simple implementation in python or perl, that could talk to the gateway, and do OTA from the command line, would be a really nice to have. I would prefer the dualoptiboot solution, since it'll work with RFM69 nodes as well (at least that's my understanding)
