  3. Battery Level and Step Up Power Converter
4 Posts 2 Posters 2.0k Views 1 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    I don't think this was discussed before so here are the questions:
    How would I know the battery level if I measure it before the step up power converter.
    If I am correct I can not use the 1.1 reference because the supplied current is always the same.
    Is it as simple as compare the input on A0 (in the sample) with the measured current using my multi meter?
    Would the formula be comparable if I use 2 x 10MOhm resistors instead of what is mentioned 1MOhm and 470KOhm.
    Fulltime Servoy Developer
    RJ_MakeR 1 Reply Last reply
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @marceltrapman
      I'm not sure I understand.. I take "before" as before the converter as in off the battery directly? Do you mean something else?
      I use the Vin post on the converter to supply the battery sense circuit.
      RJ_Make
      • RJ_MakeR RJ_Make
        @marceltrapman
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        @ServiceXp said:
        @marceltrapman I take "before" as before the converter as in off the battery directly?
        That is exactly what I mean :)
        What I fail to see, probably my ignorance, is how I can recalculate the outputted value on A0 (in case of the example) to a value that really represents the battery level.
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @marceltrapman
          Good question, one in which I have no answer. My sensors typically return ~75% for 2 fully charged AA batteries.
          RJ_Make
