  3. Domoticz
  4. Domotiocz + Rain gauge
61 Posts 12 Posters 45.5k Views 12 Watching
  • HilltanH
    HilltanH
    Hilltan
    Maybe a stupid question, but it is possible to replace the SI7021 sensor with a DHT-22 sensor (the code has to be changed offsourse)? And get everything to work with ThresholdUtil? I have all parts, but not the SI7021 sensor to build the rain gauge.
    TheoLT AWIA 2 Replies Last reply
    • HilltanH Hilltan
      TheoLT
      TheoLT
      TheoL
      @Hilltan That should really be easy. I've created the threshold util especially for this. You only have to replace the si7021 init part with the DHT22 init part and replace the reading part of the si7021 in the threshold util callback with reading the DHT22 part. Then you're done.
      Just give it a try yourself. It's really not that hard.
      There's however a reason why I use the si7021 instead of the DHT's. I've had serious troubles with the DHT sensors. Some of them wouldn't report the values to the gateway for a week. After the that the node spontaneously started reporting again. I have a sense bender running for more than a half year flawlessly. So in my opinion the si7021 is superior to the DHT.
      HilltanH 1 Reply Last reply
      • HilltanH Hilltan
        AWIA
        AWIA
        AWI
        @Hilltan Like @TheoL mentioned, try to avoid the DHT22, especially for battery powered operation. The DHT-22 is (apart from other disadvantages) specified for a working voltage from 3.3-6V. And tend to get unstable at low voltages.
          Hmm.. @AWI, @TheoL maybe we should replace DHT example on the main site for something more modern?
            TheoLT
            TheoLT
            TheoL
            @hek That sounds like a good idea. Should we also indicate that the SI7021 is a sensor for more experienced users? Because you need to solder wires or headers to it.
              Yes, But they exist in breakout board variants. So it shouldn't be much more effort than connecting a DHT module.
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                #44
                @hek @TheoL let's join forces. Dht21 or si7021 share the same code and both available on a board with level converter. And a sketch wit Bme280 (with pressure)
                Making a drawing (kicad) is not my thing. The rest ok
                TheoLT 1 Reply Last reply
                  Yep, note that the BMP180/BMP085 is described in the https://www.mysensors.org/build/pressure example. BME280 might be a better choice nowadays perhaps.
                  • AWIA AWI
                    TheoLT
                    TheoLT
                    TheoL
                    @AWI Would love to join forces with you my friend. I can make a Fritzing ;-)
                    AWIA 1 Reply Last reply
                    • TheoLT TheoL
                      AWIA
                      AWIA
                      AWI
                      @TheoL deal:thumbsup:
                        TheoLT
                        TheoLT
                        TheoL
                        @hek The BME280 is very interesting. But for most of my temp sensors I'm only interested in Temp and Humidity. At the moment I have only one Pressure sensor.
                        • TheoLT TheoL
                          HilltanH
                          HilltanH
                          Hilltan
                          @TheoL
                          How will the numbers affect the Thresholds reading and reporting of the sensor?
                          registerThresholdedSensor( CHILD_ID_TEMP, 1, TEMPERATURE_SENSOR, 0.5, 30, 20 );
                          0.5 //What will this do?
                          30 //What will this do?
                          20 //That one I assume is how often the value will be sent to the gateway?
                          void updatedTHSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
                          switch ( child_id ) {
                          case CHILD_ID_TEMP:
                          Serial.print( "Sending temp " );
                          Serial.println( value, 1 ); //What will this do?
                          send( msgTemp.set( value, 1 ) ); //What will this do?
                          I don’t have the SI7021 sensor yet so therefore my questions
                          And a problem with the DHT sensor is correct me if I am wrong, is that the DHT sensor does not like to be “read” to often. How will I do this? Or maybe the answer to my question is in the registerThresholdedSensor code ;).
                          • HilltanH Hilltan
                            @TheoL
                            case CHILD_ID_TEMP:
                            TheoLT
                            TheoLT
                            TheoL
                            wrote on last edited by TheoL
                            #50
                            @Hilltan I assume that you've downloaded my ThresholdUtil library from my github.
                            The three values are:
                            • theshHold: The value of threshold is indicates how much the new value needs to differ from the last send value before it triggers a resend.
                            • readingInterval: The amount of seconds the library waits before it request a new value for this sensor
                            • forcedTransmissionInterval: The amount of measurements without retransmissions, before a retransmission is triggered. In other words if the values of a sensor don't extend the threshold, a retransmissionis triggered of this given amount of readings.
                            I just checked my github and there's a none MySensors example handling a DHT22 and a Lux sensors. You can find it here
                            I initialize the threshold util as follows
                            #include "ThresholdUtil.h"
                            #include "DHT.h"
                            DHT dht;
                            #define DHT 0
                            #define CHILD_ID_TEMP 0
                            #define CHILD_ID_HUMIDITY 1
                            #define CHILD_ID_LIGHT_SENSOR 2
                            #define DHT22_PIN 14
                              Serial.begin( 115200 );
                              registerThresholdedSensor( CHILD_ID_TEMP, DHT, TEMPERATURE_SENSOR, 0.5, 30, 20 ); // every 30 seconds report at least every 10 minutes
                              registerThresholdedSensor( CHILD_ID_HUMIDITY, DHT, HUMIDTY_SENSOR, 1.0, 60, 10 ); // every 60 seconds
                              dht.setup( DHT22_PIN ); // data pin 2
                              delay( dht.getMinimumSamplingPeriod() );
                              checkThresholdedSensors( checkThrsedSensor, reportSensorValue ); // Necessary call for intializing ThresholdUtil
                            This means that I read the temp value every 30 seconds and report the temperature at least every 10 minutes or if the temperature lowers a half degree. But it would be better to change the half degree into 1 degree.
                            The humidity gets read every minute and will report at least every 10 minutes as well. Or when the humidity drops or raises 1 %. But I think I would use 2 percent in production.
                            To make sure the DHT is not being read to often. I remember the humidity when I read the temperature from the DHT. So when the ThresholdUtil requests the humidity state I return the humidity we last read.
                            float dhtHumidity;
                            void checkThrsedSensor( uint8_t aSensorId, ThreshHoldedSensorType aType, float *value ) {
                              if ( aSensorId == DHT  ) {
                                if ( aType == TEMPERATURE_SENSOR ) {
                                  dhtHumidity = dht.getHumidity();
                                  *value = dht.getTemperature();
                                else {
                                  *value = dhtHumidity;
                              if ( aSensorId == LUX_SENSOR && aType == LIGHTLEVEL_SENSOR ) {
                                *value = random( 30, 40 ); // not sure why but I apparently just fake the light level sensor
                            The remainder of the sketch contains a callback handler for reporting the sensor values e.g. to MySensors. But I've noticed that I need to update that example on github
                            void reportSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
                              Serial.print( millis() ); Serial.print( ": new sensor value " );
                             Serial.print( value );
                            Serial.print( child_id == CHILD_ID_TEMP ? " C" : " %" );
                             Serial.print( " for child " );
                             Serial.println( child_id == CHILD_ID_TEMP ? "temp" : ( child_id == CHILD_ID_HUMIDITY ? "hum" : "light" ) );
                            And in the loop we continuously call the checkThresholdedSensors method, that well handle all the timing part for you. So that the check only gets called when needed and the report only when a sensor value needs to be reported.
                            Hope this helps you a bit. I'm currently to occupied to update the sketch for you.
                            • HilltanH
                              HilltanH
                              Hilltan
                              Thanks @TheoL, I will give it a try.
                              • HilltanH
                                HilltanH
                                Hilltan
                                Finally I get it to run with a light sensor (BH1750), temp/hum sensor (DHT22), and the rain tipping sensor. But there are some problems:
                                Domoticz seems not to want to divide the DHT sensor in to two, one humidity and one temperature. What I get in Domoticz is one WTGR800 (temp/hum) and one LaCrosse TX3 (temp). Have played around with the code a little bit, just ending up with one WTGT800 (temp/hum) and one LaCrosse TX3 (temp or humidity).
                                The rain sensor gets fault impulse from time to time, the sensor got trigged without that the sensor have been set off?
                                Overall your @TheoL Threshhold util is a very nice tool to work with, but the DHT sensor is not that easy to deal with I think…
                                  Include libraries used by the sketch
                                #include <math.h>
                                #include <Time.h>
                                #include <BH1750.h>
                                #include "DHT.h"
                                DHT dht;
                                #define DHT 0
                                #define BUCKET_PIN 3                  // The Arduino pin to which the bucket is attached. We need an interrupt pin (2 or 3 on the Uno and the Pro Mini)
                                #define SKETCH_INFO "Outside weather" // The name of the sketch as presented to the gateway
                                #define SKETCH_VERSION "1.0"          // The version of the sketch as presented to the gateway
                                #define CHILD_ID_RAIN_LOG 4           // The child id of the rain gauge
                                #define MS_WAIT 100                   // short delay used to give the NRF24L01+ antenna some time to recover from the last data sending
                                #define bucketSize 0.3                // I've used a MI-SOL Rain Guage which has a bucket size of 0.3 mm
                                #define LIGHTLEVEL_SENSOR_CHILD_ID 0
                                #define LIGHTLEVEL_SENSOR_ID 3
                                #define CHILD_ID_TEMP 5
                                #define DHT_TEMP 6
                                #define CHILD_ID_HUMIDITY 7
                                #define DHT_HUM 9
                                #define DHT_DATA_PIN 8
                                MyMessage lightLevelMsg(LIGHTLEVEL_SENSOR_CHILD_ID, V_LIGHT_LEVEL);
                                MyMessage msgHum( CHILD_ID_HUMIDITY, V_HUM );
                                MyMessage msgTemp( CHILD_ID_TEMP, V_TEMP );
                                MyMessage msgRain( CHILD_ID_RAIN_LOG, V_RAIN );
                                MyMessage lastCounterMsg( CHILD_ID_RAIN_LOG, V_VAR1 );
                                BH1750 lightSensor;
                                float hwRainVolume = 0;           // Current rainvolume calculated in hardware.
                                unsigned long hwPulseCounter = 0; // Pulsecount recieved from GW
                                boolean pcReceived = false;       // If we have recieved the pulscount from GW or not
                                unsigned long lastTipTime = millis(); // TS of when the bucket tip has been detected for the last time
                                volatile unsigned long wasTippedCounter; // Queue for storing the tipped counter as been set by the interrupt handler.
                                byte lastHour;                    // Stores the hour used for checking if time needs to be synchronized
                                  sendSketchInfo( SKETCH_INFO, SKETCH_VERSION );
                                  wait( MS_WAIT );
                                  present(LIGHTLEVEL_SENSOR_CHILD_ID, S_LIGHT_LEVEL, "Light level" );
                                  wait( MS_WAIT );
                                  present( CHILD_ID_HUMIDITY, S_HUM, "Outside Humidity" );
                                  wait( MS_WAIT );
                                  present( CHILD_ID_TEMP, S_TEMP, "Outside Temperature" );
                                  wait( MS_WAIT );
                                  present( CHILD_ID_RAIN_LOG, S_RAIN, "Rain fall" );
                                  wait( MS_WAIT );
                                  unsigned long functionTimeout = millis();
                                  while ( pcReceived == false && millis() - functionTimeout < 30000UL ) {
                                    request( CHILD_ID_RAIN_LOG, V_VAR1);
                                    Serial.println(F("Getting pulse count"));
                                    Serial.println(F("."));
                                    wait( 1000 );
                                  attachInterrupt( digitalPinToInterrupt( BUCKET_PIN ), sensorTipped, LOW ); //FALLING );  // depending on location of the hall effect sensor may need CHANGE
                                  pinMode( BUCKET_PIN, INPUT_PULLUP );
                                  lightSensor.begin();
                                  registerThresholdedSensor( LIGHTLEVEL_SENSOR_CHILD_ID,  LIGHTLEVEL_SENSOR_ID,  LIGHTLEVEL_SENSOR,  20,  30, 20 ); // read every 5 sec and report at least every 5 minute ändrat 300 till 20
                                  registerThresholdedSensor( CHILD_ID_TEMP, DHT_TEMP, TEMPERATURE_SENSOR, 0.5, 30, 20 ); // every 30 seconds report at least every 10 minutes
                                  registerThresholdedSensor( CHILD_ID_HUMIDITY, DHT_HUM, HUMIDTY_SENSOR, 1.0, 60, 10 ); // every 60 seconds
                                  dht.setup( DHT_DATA_PIN ); // data pin 8
                                  while ( timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL ) {
                                    requestTime();
                                    Serial.println(F("Getting Time"));
                                    wait( 1000 );
                                  lastHour = hour();
                                  Sends the value of the rain gauge to the Gateway.
                                void sendRainVolumeData() {
                                  float hwRainVolume = hwPulseCounter * bucketSize;
                                  Serial.print( "Tipped " );
                                  Serial.print( hwPulseCounter );
                                  Serial.println( " times." );
                                  Serial.print( "Rain fall is " );
                                  Serial.print( hwRainVolume, 1 );
                                  Serial.println( " mm." );
                                  send( msgRain.set( (float)hwRainVolume, 1 ) );
                                  wait( MS_WAIT );
                                  send( lastCounterMsg.set( hwPulseCounter ) );
                                  wait( MS_WAIT );
                                  if ( wasTippedCounter != hwPulseCounter ) {
                                    hwPulseCounter = wasTippedCounter;
                                    sendRainVolumeData();
                                  byte currentHour = hour();
                                  if (currentHour != lastHour) {
                                    Serial.println( "Resyncing hour" );
                                    requestTime(); // sync the time every hour
                                    wait( MS_WAIT );
                                    lastHour = currentHour;
                                    sendRainVolumeData(); // Send heart beat
                                checkThresholdedSensors( readSensorValue, updatedSensorValue );
                                void sensorTipped() {
                                  unsigned long thisTipTime = millis();
                                  if (thisTipTime - lastTipTime > 100UL) {
                                    wasTippedCounter++;
                                  lastTipTime = thisTipTime;
                                float dhtHumidity;
                                void readSensorValue( uint8_t aSensorId, ThreshHoldedSensorType aType, float *value ) {
                                  switch ( aSensorId ) {
                                    case LIGHTLEVEL_SENSOR_ID:
                                      if ( aType == LIGHTLEVEL_SENSOR ) {
                                        *value = lightSensor.readLightLevel();
                                      case DHT_TEMP:
                                      case DHT_HUM:
                                      if ( aType == HUMIDTY_SENSOR ) {
                                        *value = dht.getHumidity();
                                void updatedSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
                                    case LIGHTLEVEL_SENSOR_CHILD_ID:
                                      Serial.print( "Light level " );
                                      Serial.print( value, 0 );
                                      Serial.println( "%" );
                                      send( lightLevelMsg.set( value, 5 ) );
                                      wait( MS_WAIT );
                                    case CHILD_ID_TEMP:
                                      Serial.print( "Temperatur " );
                                      Serial.print( "C" );
                                      wait( MS_WAIT );
                                    case CHILD_ID_HUMIDITY:
                                      Serial.print( "HUMIDITY " );
                                      Serial.print( "%" );
                                      send( msgHum.set( value, 1 ) );
                                      wait( MS_WAIT );
                                void receiveTime(unsigned long time) {
                                  Serial.println( F("Time received..."));
                                  setTime(time);
                                  char theTime[6];
                                  sprintf(theTime, "%d:%2d", hour(), minute());
                                  Serial.println(theTime);
                                  if ( message.sensor == CHILD_ID_RAIN_LOG && message.type == V_VAR1) { // We only expect pulse count values from the gateway
                                    hwPulseCounter = message.getULong();
                                    wasTippedCounter = hwPulseCounter;
                                    pcReceived = true;
                                    Serial.print("Received last pulse count from gw: ");
                                    Serial.println(hwPulseCounter);
                                There are probably strange things in the sketch, I am new to this ;)
                                • HilltanH Hilltan
                                  #include <math.h>
                                  #include <Time.h>
                                  #include <BH1750.h>
                                  #include "DHT.h"
                                  DHT dht;
                                  #define DHT 0
                                  #define DHT_TEMP 6
                                  #define DHT_HUM 9
                                  BH1750 lightSensor;
                                    wait( MS_WAIT );
                                    wait( MS_WAIT );
                                    wait( MS_WAIT );
                                    wait( MS_WAIT );
                                    wait( MS_WAIT );
                                      wait( 1000 );
                                      requestTime();
                                      wait( 1000 );
                                    lastHour = hour();
                                    wait( MS_WAIT );
                                    wait( MS_WAIT );
                                      wait( MS_WAIT );
                                      wasTippedCounter++;
                                  float dhtHumidity;
                                        case DHT_TEMP:
                                        case DHT_HUM:
                                        wait( MS_WAIT );
                                      case CHILD_ID_TEMP:
                                        wait( MS_WAIT );
                                        wait( MS_WAIT );
                                    setTime(time);
                                    char theTime[6];
                                      pcReceived = true;
                                  AWIA
                                  AWIA
                                  AWI
                                  @Hilltan it is a Domoticz 'feature' to combine temperature, humidity and barometric sensors. There is a method to separate them if you have (or pretend to have) multiple sensors of the same type. This is done by presenting the one you want to combine right after each other.
                                  In your case I would just keep it...
                                  • sundberg84S sundberg84
                                    This is my rainsensor/tipping bucket for MySensors that works with Domoticz.
                                    It uses 2xAA as power source, a Pro Mini 3.3v with a 0.9 to 3.3 booster.
                                    The bucket has a magnet which triggeras a reed switch which triggers an interrupt pin.
                                    I also use battery sensing with voltage divider.
                                    #define MY_NODE_ID 7
                                    // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
                                    #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
                                    #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
                                    #define CHILD_ID 1                              // Id of the sensor child
                                    #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
                                    #define SKETCH_VERSION "1.1"                    // Your version
                                    unsigned long SLEEP_TIME = 18*60000;            // Sleep time (in milliseconds).
                                    //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
                                    int hwPulseCounter = 0;                         // Pulsecount recieved from GW
                                    float fullCounter = 0;                           // Counts when to send counter
                                    float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
                                    boolean reedState;                              // Current state the reedswitch is in
                                    boolean oldReedState;                           // Old state (last state) of the reedswitch
                                    unsigned long lastSend =0;                      // Time we last tried to fetch counter.
                                    MyMessage volumeMsg(CHILD_ID,V_RAIN);
                                    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                                      // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
                                      present(CHILD_ID, S_RAIN);
                                      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);  // sets the reed sensor digital pin as input
                                      reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
                                      oldReedState = reedState; // Set startup position for reedswitch
                                      Serial.println("Startup completed");
                                    unsigned long currentTime = millis();
                                        //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
                                        if (!pcReceived && (currentTime - lastSend > 5000)) {
                                          request(CHILD_ID, V_VAR1);
                                          lastSend=currentTime;
                                          return;
                                        if (!pcReceived) {
                                          return;
                                    //Read if the bucket tipped over
                                    boolean tipped = oldReedState != reedState;
                                        //BUCKET TIPS!
                                        if (tipped==true) {
                                        Serial.println("The bucket has tipped over...");
                                        hwRainVolume = hwRainVolume + bucketSize;
                                        send(volumeMsg.set((float)hwRainVolume,1));
                                        wait(1000);
                                        fullCounter = fullCounter + bucketSize;
                                          //Count so we send the counter for every 1mm
                                          if(fullCounter >= 1){
                                          hwPulseCounter++;
                                          send(lastCounterMsg.set(hwPulseCounter));
                                          wait(1000);
                                          fullCounter = 0;
                                        if (tipped==false) {
                                         //No bucket tipped over last sleep-period, check battery then...
                                         batM();
                                    sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                                    //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
                                    //Read if we have a incoming message.
                                    void receive(const MyMessage &msg) {
                                        if (msg.type==V_VAR1) {
                                        hwPulseCounter = msg.getULong();
                                        hwRainVolume = hwPulseCounter;
                                        pcReceived = true;
                                    void batM(){  //The battery calculations
                                       delay(500);
                                       // Battery monitoring reading
                                       delay(500);
                                       // Calculate the battery in %
                                       if (batLoop > 1) {
                                         batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
                                       if (batteryPcnt > 100) {
                                         batteryPcnt=100;
                                           batLoop = 0;
                                         //Sends 1 per hour as a heartbeat.
                                         batLoop++;
                                    Matt
                                    @sundberg84 sorry I know this is an old thread but hoping you can remember how you wrote this code.I have changed it to suit MYS 2.1 as below. I have also added battery level as a separate child ID so I can watch performance over time. Aside from these simple changes the code is all yours from the start of this post. It is built on v8 of your board, controller/GW is latest domoticz beta running on a PI2 using NRFs.
                                    I have a couple of questions though. I am curious as to why bucketSize needs to be 1, 0.5, 0.25, 0.2 or 0.1 as per your comments and I suspect that when I calibrate my gauge it wont be any of these.
                                    I am testing at the moment without the gauge. When I earth D3 it actually reports as TWO bucket tips and the volume goes up by 0.5 twice. I dont think this is a bounce issue due to the many wait(1000) functions in your code. Would you know why this is? I have tried changing CHANGE to FALLING in the sleep function. I have a simple reed switch gague.
                                    Which leads to my third question. Are all the wait times necessary? Could they be much less? I wonder if I will miss bucket tips because of these during heavy rain...
                                    Many many thanks,
                                    Matt
                                    #define CHILD_ID_BAT 2                          // Id of BAT
                                    MyMessage msgBat(CHILD_ID_BAT, V_VOLTAGE);
                                      present(CHILD_ID_BAT, S_MULTIMETER);
                                      delay(500);                                    // Allow time for radio if power used as reset
                                          return;
                                        if (!pcReceived) {
                                          return;
                                        //BUCKET TIPS!
                                        if (tipped==true) {
                                        wait(1000);
                                          hwPulseCounter++;
                                          wait(1000);
                                          fullCounter = 0;
                                         batM();
                                    sleep(INTERRUPT, FALLING, SLEEP_TIME);
                                        pcReceived = true;
                                       delay(500);
                                       delay(500);
                                       if (batLoop > 1) {
                                         batteryPcnt=100;
                                           send(msgBat.set(Vbat, 4));
                                           batLoop = 0;
                                         batLoop++;
                                    • M Matt
                                      Many many thanks,
                                      Matt
                                            return;
                                          if (!pcReceived) {
                                            return;
                                          //BUCKET TIPS!
                                          if (tipped==true) {
                                          wait(1000);
                                            hwPulseCounter++;
                                            wait(1000);
                                            fullCounter = 0;
                                           batM();
                                          pcReceived = true;
                                         delay(500);
                                         delay(500);
                                         if (batLoop > 1) {
                                           batteryPcnt=100;
                                             batLoop = 0;
                                           batLoop++;
                                      sundberg84S
                                      sundberg84S
                                      #55
                                      @Matt said in Domotiocz + Rain gauge:
                                      OK :) Lets see what I can do...
                                      Its because of this calculaction and that Domoticz uses 1mm counter:
                                            hwPulseCounter++;
                                            wait(1000);
                                            fullCounter = 0;
                                      If the bucketsize is set to say 0,3mm it will not add up to a full 1 and the code is lost. (0,3+0,3+0,3+0,3 = 1.2) and 0,2 is lost. Im sure you can code this better (code is not my strong side!!!)
                                      Do you have a pulldown/up resistor to avoid the pin floats?
                                      Its a matter of code and what bucket you have. Some wait() are for debounce and stabilising power for radio and readings. I would not change those but I always aim for the high numbers to be sure(wait(1000); = really high!!). Try!
                                      Other wait() could depend on what kind of bucket you use - im sorry to say, but all you can do is try!
                                              hwPulseCounter++;
                                              wait(1000);
                                              fullCounter = 0;
                                        Matt
                                        @sundberg84
                                        Thankyou very much for your reply.
                                        It seems strange that domoticz would only accept 1mm pulses I wonder if this has changed... In any case it should be easy to save the 'lost' volume and add it to the next bucket in code...
                                        The internal pullup is switched on in code so reed switch pin won't be floating. Will have a fiddle round with your code today.
                                        Will also try to calibrate by gauge today will be easy to see max tipping speed and can adjust wait times accordingly...
                                        Thanks again,
                                        Matt
                                        • M Matt
                                          @sundberg84
                                          Thanks again,
                                          Matt
                                          sundberg84S
                                          sundberg84S
                                          @Matt - Let me know if I can help you anything-
