  3. Domoticz
  4. Domotiocz + Rain gauge
61 Posts 12 Posters 45.6k Views 12 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    #32
    I have adjust my bucked to tip every ~0.25mm and calibrated it ofcourse
    AWIA 1 Reply Last reply
    • F flopp
      AWIA
      AWIA
      AWI
      Domoticz just recently changed the method of rain rate calculation. It does not interpret rainrate values sent by sensors but calculates this by the total value coming in.
      TheoLT 1 Reply Last reply
      • AWIA AWI
        TheoLT
        TheoLT
        TheoL
        @AWI Thank you again. I already had a gut feeling this would be the case. I'll strip out the rain rate code from the sketch.
        • TheoLT TheoL
          @sundberg84 Using a real pulse counter instead of a 1mm pulse counter seems to work perfectly. Luckily it makes the sketch a bunch easier to implement and read. And there will also be no loss of 0.2 or 0.5 mm rain fall whenever you reset the node while it didn't have a .0 value.
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @TheoL
          Great to see this project continuing to grow legs!
          • HilltanH
            HilltanH
            Hilltan
            • sundberg84S sundberg84
              This is great!
              1 year - times fly by, but my rainsensor is going strong!
              I just wanted to celebrate 1 year for my Rainsensor on batteries, reporting every hour (or less when it rains). Still going strong and 81% battery left! Except for some range issues in the beginning you can see its working as it should:
              Also It will be my (almost) 1000th post so thank you all for making MySensors such a great community. I just love every minute here!
              F
              F
              flopp
              WOW, nice. Would it be possible to see your Battery graph, if you have one?
              I am send data every 2h or often when it rains but my battery is draining much quicker than yours. Maybe I will get 1 year out of it, so I am happy anyway.
              But I am interested in your graph if the voltage is going down quicker in the beginning.
              • HilltanH
                HilltanH
                Hilltan
                Maybe a stupid question, but it is possible to replace the SI7021 sensor with a DHT-22 sensor (the code has to be changed offsourse)? And get everything to work with ThresholdUtil? I have all parts, but not the SI7021 sensor to build the rain gauge.
                TheoLT AWIA 2 Replies Last reply
                • HilltanH Hilltan
                  TheoLT
                  TheoLT
                  TheoL
                  @Hilltan That should really be easy. I've created the threshold util especially for this. You only have to replace the si7021 init part with the DHT22 init part and replace the reading part of the si7021 in the threshold util callback with reading the DHT22 part. Then you're done.
                  Just give it a try yourself. It's really not that hard.
                  There's however a reason why I use the si7021 instead of the DHT's. I've had serious troubles with the DHT sensors. Some of them wouldn't report the values to the gateway for a week. After the that the node spontaneously started reporting again. I have a sense bender running for more than a half year flawlessly. So in my opinion the si7021 is superior to the DHT.
                  HilltanH 1 Reply Last reply
                  • HilltanH Hilltan
                    AWIA
                    AWIA
                    AWI
                    @Hilltan Like @TheoL mentioned, try to avoid the DHT22, especially for battery powered operation. The DHT-22 is (apart from other disadvantages) specified for a working voltage from 3.3-6V. And tend to get unstable at low voltages.
                      Hmm.. @AWI, @TheoL maybe we should replace DHT example on the main site for something more modern?
                        TheoLT
                        TheoLT
                        TheoL
                        @hek That sounds like a good idea. Should we also indicate that the SI7021 is a sensor for more experienced users? Because you need to solder wires or headers to it.
                          Yes, But they exist in breakout board variants. So it shouldn't be much more effort than connecting a DHT module.
                            AWIA
                            AWIA
                            AWI
                            wrote on last edited by AWI
                            #44
                            @hek @TheoL let's join forces. Dht21 or si7021 share the same code and both available on a board with level converter. And a sketch wit Bme280 (with pressure)
                            Making a drawing (kicad) is not my thing. The rest ok
                              Yep, note that the BMP180/BMP085 is described in the https://www.mysensors.org/build/pressure example. BME280 might be a better choice nowadays perhaps.
                              • AWIA AWI
                                TheoLT
                                TheoLT
                                TheoL
                                @AWI Would love to join forces with you my friend. I can make a Fritzing ;-)
                                • TheoLT TheoL
                                  AWIA
                                  AWIA
                                  AWI
                                  @TheoL deal:thumbsup:
                                    TheoLT
                                    TheoLT
                                    TheoL
                                    @hek The BME280 is very interesting. But for most of my temp sensors I'm only interested in Temp and Humidity. At the moment I have only one Pressure sensor.
                                    • TheoLT TheoL
                                      HilltanH
                                      HilltanH
                                      Hilltan
                                      @TheoL
                                      How will the numbers affect the Thresholds reading and reporting of the sensor?
                                      registerThresholdedSensor( CHILD_ID_TEMP, 1, TEMPERATURE_SENSOR, 0.5, 30, 20 );
                                      0.5 //What will this do?
                                      30 //What will this do?
                                      20 //That one I assume is how often the value will be sent to the gateway?
                                      void updatedTHSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
                                      switch ( child_id ) {
                                      case CHILD_ID_TEMP:
                                      Serial.print( "Sending temp " );
                                      Serial.println( value, 1 ); //What will this do?
                                      send( msgTemp.set( value, 1 ) ); //What will this do?
                                      I don’t have the SI7021 sensor yet so therefore my questions
                                      And a problem with the DHT sensor is correct me if I am wrong, is that the DHT sensor does not like to be “read” to often. How will I do this? Or maybe the answer to my question is in the registerThresholdedSensor code ;).
                                      • HilltanH Hilltan
                                        @TheoL
                                        case CHILD_ID_TEMP:
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        wrote on last edited by TheoL
                                        #50
                                        @Hilltan I assume that you've downloaded my ThresholdUtil library from my github.
                                        The three values are:
                                        • theshHold: The value of threshold is indicates how much the new value needs to differ from the last send value before it triggers a resend.
                                        • readingInterval: The amount of seconds the library waits before it request a new value for this sensor
                                        • forcedTransmissionInterval: The amount of measurements without retransmissions, before a retransmission is triggered. In other words if the values of a sensor don't extend the threshold, a retransmissionis triggered of this given amount of readings.
                                        I just checked my github and there's a none MySensors example handling a DHT22 and a Lux sensors. You can find it here
                                        I initialize the threshold util as follows
                                        #include "ThresholdUtil.h"
                                        #include "DHT.h"
                                        DHT dht;
                                        #define DHT 0
                                        #define CHILD_ID_TEMP 0
                                        #define CHILD_ID_HUMIDITY 1
                                        #define CHILD_ID_LIGHT_SENSOR 2
                                        #define DHT22_PIN 14
                                          Serial.begin( 115200 );
                                          registerThresholdedSensor( CHILD_ID_TEMP, DHT, TEMPERATURE_SENSOR, 0.5, 30, 20 ); // every 30 seconds report at least every 10 minutes
                                          registerThresholdedSensor( CHILD_ID_HUMIDITY, DHT, HUMIDTY_SENSOR, 1.0, 60, 10 ); // every 60 seconds
                                          dht.setup( DHT22_PIN ); // data pin 2
                                          delay( dht.getMinimumSamplingPeriod() );
                                          checkThresholdedSensors( checkThrsedSensor, reportSensorValue ); // Necessary call for intializing ThresholdUtil
                                        This means that I read the temp value every 30 seconds and report the temperature at least every 10 minutes or if the temperature lowers a half degree. But it would be better to change the half degree into 1 degree.
                                        The humidity gets read every minute and will report at least every 10 minutes as well. Or when the humidity drops or raises 1 %. But I think I would use 2 percent in production.
                                        To make sure the DHT is not being read to often. I remember the humidity when I read the temperature from the DHT. So when the ThresholdUtil requests the humidity state I return the humidity we last read.
                                        float dhtHumidity;
                                        void checkThrsedSensor( uint8_t aSensorId, ThreshHoldedSensorType aType, float *value ) {
                                          if ( aSensorId == DHT  ) {
                                            if ( aType == TEMPERATURE_SENSOR ) {
                                              dhtHumidity = dht.getHumidity();
                                              *value = dht.getTemperature();
                                            else {
                                              *value = dhtHumidity;
                                          if ( aSensorId == LUX_SENSOR && aType == LIGHTLEVEL_SENSOR ) {
                                            *value = random( 30, 40 ); // not sure why but I apparently just fake the light level sensor
                                        The remainder of the sketch contains a callback handler for reporting the sensor values e.g. to MySensors. But I've noticed that I need to update that example on github
                                        void reportSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
                                          Serial.print( millis() ); Serial.print( ": new sensor value " );
                                         Serial.print( value );
                                        Serial.print( child_id == CHILD_ID_TEMP ? " C" : " %" );
                                         Serial.print( " for child " );
                                         Serial.println( child_id == CHILD_ID_TEMP ? "temp" : ( child_id == CHILD_ID_HUMIDITY ? "hum" : "light" ) );
                                        And in the loop we continuously call the checkThresholdedSensors method, that well handle all the timing part for you. So that the check only gets called when needed and the report only when a sensor value needs to be reported.
                                        Hope this helps you a bit. I'm currently to occupied to update the sketch for you.
                                        • HilltanH
                                          HilltanH
                                          Hilltan
                                          Thanks @TheoL, I will give it a try.
