  2. Announcements
  • Christian SimonsenC Christian Simonsen
    @marceloaqno said:
    cd MySensors
    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my
    Thanks for letting me know, didn't know that not running it from the specific folder would have an impact.
    I reconfigured it as you recommended. and restarted the gateway, with the result below.
    pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d
    mysGateway: Starting gateway...
    mysGateway: Protocol version - 2.0.1-beta
    mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
    mysGateway: TSF:LRT:OK
    mysGateway: TSM:INIT
    mysGateway: TSM:INIT:TSP OK
    mysGateway: TSM:INIT:GW MODE
    mysGateway: TSM:READY
    mysGateway: MCO:REG:NOT NEEDED
    mysGateway: MCO:BGN:STP
    mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    mysGateway: !TSF:MSG:LEN,0!=7
    mysGateway: !TSF:MSG:LEN,14!=7
    What is the best way to test if the gateway work? What sketch should I use on the arduino? and how do I see in Terminal that the mysGateway receive the transfer successfully?
    jerseyguy1996J
    jerseyguy1996J
    jerseyguy1996
    @Christian-Simonsen
    You can pretty much test out using any of the arduino examples here:
    https://github.com/mysensors/MySensors/tree/development/examples
    Each one will present itself to the gateway when it starts up and you will see the presentation in the debug log. Make sure to run:
    https://github.com/mysensors/MySensors/tree/development/examples/ClearEepromConfig
    on the arduino first to make sure it starts with a fresh eeprom. After you select an Arduino sketch to test it with (seriously it doesn't matter which one you try) make sure to look at the sketch and add:
    #define MY_NODE_ID 4
    For MY_NODE_ID you can select any number. Just make sure that each new sensor node that you create has a different node number so like start out at MY_NODE_ID 1 and when you make another sensor node you can #define MY_NODE_ID 2 and so on.
    Next load it up to the Arduino, open the serial monitor, and see what happens. If you watch the serial monitor on the arduino you will see it present itself to the gateway and then you can confirm it in the debug log on the raspberry pi.
    I think it is pretty normal to have the problems you are having. I uninstalled and reinstalled the gateway 3 times on the Raspberry Pi before I finally got it all figured out. Once you get it running it is a glorious thing.
      @marceloaqno said:
      cd MySensors
      marceloaqno
      Code Contributor
      wrote on last edited by marceloaqno
      #80
      @Christian-Simonsen
      looks like a power issue with the nrf24 module.
      Christian SimonsenC 1 Reply Last reply
      • b0rmannB b0rmann
        very interesting data...
        journalctl -u mysgateway --since 13:15 | grep MSG:READ
        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=3,c=1,t=23,pt=2,l=2,sg=0:97
        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.6
        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
        Oct 21 13:16:30 pi mysGateway[30406]: TSF:MSG:READ,3-3-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
        Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
        Oct 21 13:16:31 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=4,c=1,t=23,pt=2,l=2,sg=0:6
        Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
        Oct 21 13:17:17 pi mysGateway[30406]: TSF:MSG:READ,2-2-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
        Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=251,c=1,t=0,pt=7,l=5,sg=0:24.5
        Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,3-10-0,s=0,c=1,t=0,pt=7,l=5,sg=0:12.7
        Oct 21 13:17:18 pi mysGateway[30406]: TSF:MSG:READ,2-10-0,s=167,c=1,t=0,pt=7,l=5,sg=0:24.6
        Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=12,c=1,t=0,pt=7,l=5,sg=0:34
        Oct 21 13:17:19 pi mysGateway[30406]: TSF:MSG:READ,10-10-0,s=14,c=1,t=0,pt=7,l=5,sg=0:24
        node 2
        sensor 167 - dht18b20 indoor
        sensor 251 - dht18b20 indoor
        node 3
        sensor 0 - dht18b20 outdoor
        sensor 3 - light (0..100)
        sensor 4 - light (0..100)
        questions:
        why node 2 and node 3 send messages directly and via node 10?
        24.6 - is actual value from 2/251, but gateway receive this value from 3/0 How is it possible?
        marceloaqno
        Code Contributor
        @b0rmann Can you provide a full debug log of all involved nodes?
        • Patrik SöderströmP
          Patrik SöderströmP
          Patrik Söderström
          Can I attach one or more DallasTemp sensors on the Raspberry Pi gateway?
          • M marceloaqno
            @Christian-Simonsen
            Christian SimonsenC
            Christian SimonsenC
            Christian Simonsen
            @marceloaqno said:
            @Christian-Simonsen
            Ok,
            I've tested with the Voltmeter and the NRF24L01 module do get a steady 3.26 V. Both the gateway module and the Arduino sensor node...
            Im now building a few extra sensor nodes, so I can test without the Raspberry pi. Hopefully I can atleast get them talking based on Arduinos first. Before testing the Raspberry Pi.
            alexsh1A dopeeyeD 2 Replies Last reply
            • Patrik SöderströmP Patrik Söderström
              I haven't seen anyone doing anything similar so it might require some work. But almost anything is possible given enough work :)
              Patrik SöderströmP 1 Reply Last reply
              • jerseyguy1996J
                jerseyguy1996J
                jerseyguy1996
                Has anyone else had an issue with getting a sensor node to reconnect after a lost connection? I can see it attempting to reconnect but even though it is back within range of the gateway it won't reestablish the connection. If I reset the node it re-establishes the connection without any problem. This is the cycle that it gets stuck in:
                TSM:FPAR
                TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=3)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                TSP:CHKUPL:FAIL (hops=255)
                !TSM:UPL:FAIL
                TSM:FPAR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=3)
                TSM:UPL
                !TSM:UPL:FAIL
                TSM:FPAR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR
                !TSP:SEND:TNR```
                  @marceloaqno said:
                  @Christian-Simonsen
                  Ok,
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @Christian-Simonsen multimeter will not detect issues with the power feed (noise or unstable). It just says that you voltage under zero load is 3.3V.
                  • carlylerC
                    carlylerC
                    carlyler
                    Appears things are changing, please update wiki:
                    Warning: --my-radio is deprecated, please use --my-transport
                      Patrik SöderströmP
                      Patrik SöderströmP
                      Patrik Söderström
                      @mfalkvidd Alright :) The thing is that I have my Raspberry Pi as a Gateway today near my server rack and would like to measure the temperatur. Maybe I just get a Nano to do the work for me. Just would have been great to use the Raspberry.
                        @Patrik-Söderström You can probably connect a temperature sensor to the gpio pins and have your controller read the sensor (without using MySensors)
                        • carlylerC carlyler
                          marceloaqno
                          Code Contributor
                          @carlyler Thanks for pointing that out.
                          • jerseyguy1996J jerseyguy1996
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=3)
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=3)
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR
                            !TSP:SEND:TNR```
                            marceloaqno
                            Code Contributor
                            @jerseyguy1996 Are you using a decoupling capacitor?
                            jerseyguy1996J R 2 Replies Last reply
                            • M marceloaqno
                              jerseyguy1996J
                              jerseyguy1996J
                              jerseyguy1996
                              wrote on last edited by jerseyguy1996
                              #92
                              @marceloaqno Yes its 220 uF. It was all I had handy. I read somewhere that this may be a problem specific to the arduino nano. I may give it a try with the pro mini. Although I'm not sure what that may have to do with it.
                              Edit: I tried the same sketch on an arduino pro mini and it worked fine. When I simulated a loss of connection by walking out of range of the gateway it immediately reestablished the connection when I got back within range. The only difference is that the pro mini is running at 8 mhz whereas the nano runs at 16 mhz. Not sure how that affects things.
                              • Velo17V
                                Velo17V
                                Velo17
                                Hello everyone. Is there a way to reduce the number of Heartbeat messages the gateway produces by itself? Using MYSController to analyze the data traffic, I see every 10 seconds a Heartbeat - would like to reduce this once everything is working as expected to maybe every 5 or 10 minutes...
                                  @Velo17
                                  Just sleep longer. It sends one heartbeat every time the node wakes up.
                                    @marceloaqno said:
                                    @Christian-Simonsen
                                    Ok,
                                    dopeeyeD
                                    dopeeyeD
                                    dopeeye
                                    @Christian-Simonsen
                                    I have exactly the same error
                                    Have you been able to resolve that problem yet? I have tried multiple radios with different capacitors and powersources grounded to the Raspberry Pi.
                                    thanks
                                    • dopeeyeD dopeeye
                                      @Christian-Simonsen
                                      thanks
                                      Christian SimonsenC
                                      Christian SimonsenC
                                      Christian Simonsen
                                      @dopeeye
                                      Sadly not. I ended up creating an serial gateway (arduino with NRF24L01 and a USB connector) and connected this to the Raspberry Pi, rather than connecting the NRF24L01 directly to the GPIO pins. This worked perfectly straight away.
                                      dopeeyeD 1 Reply Last reply
                                        @dopeeye
                                        dopeeyeD
                                        dopeeyeD
                                        dopeeye
                                        @Christian-Simonsen
                                        Too stubborn to give up, yet.
                                        If i find a resolution I will let you know
                                        carlylerC 1 Reply Last reply
                                        • GrahamG
                                          GrahamG
                                          Graham
                                          I would like to try this, but my pins19-23 are already used by other hardware. Has anyone tried using the SPI1 Pins?
