  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.0k Views 53 Watching
  • bjacobtB bjacobt
    @tonnerre33, I'm trying to build arduio that can run on 2 AA batteries. I'm using MySensors for library and building arduino circuit based on this https://openhomeautomation.net/arduino-battery/
    @bjacobt https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level describes how the battery voltage is calculated and the example sketch has code for doing the calculation. Looks like you've missed reading this part:
    bjacobtB 1 Reply Last reply
    • tonnerre33T tonnerre33
      Can you post the logs of your node and the skech used ?
      bjacobtB
      bjacobtB
      bjacobt
      @tonnerre33
      Here are the logs from Arduino Serial console
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=101)
      TSM:FPAR
      TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSP:MSG:PAR OK (ID=0, dist=1)
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=101)
      TSM:UPL
      TSP:PING:SEND (dest=0)
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
      TSP:MSG:PONG RECV (hops=1)
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
      TSP:MSG:READ 0-0-101 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:Battery Meter
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
      Request registration...
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
      TSP:MSG:READ 0-0-101 s=255,c=3,t=27,pt=1,l=1,sg=0:1
      Node registration=1
      Init complete, id=101, parent=0, distance=1, registration=1
      330
      Battery Voltage: 1.11 V
      Battery percent: 33 %
      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:33
      The sketch used is this:
      #define MY_NODE_ID  101
      unsigned long SLEEP_TIME = 100000;  // sleep time between reads (seconds * 1000 milliseconds)
      int oldBatteryPcnt = 0;
         analogReference(INTERNAL1V1);
         analogReference(INTERNAL);
         sendSketchInfo("Battery Meter", "1.0");
         // get the battery Voltage
         #ifdef MY_DEBUG
         Serial.println(sensorValue);
         #ifdef MY_DEBUG
         Serial.print(batteryV);
         Serial.println(" V");
         Serial.print(batteryPcnt);
         Serial.println(" %");
           // Power up radio after sleep
           oldBatteryPcnt = batteryPcnt;
         sleep(SLEEP_TIME);
      What I see on the gateway is:
      mysGateway: TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      mysGateway: TSF:MSG:BC
      mysGateway: TSF:MSG:FPAR REQ,ID=101
      mysGateway: TSF:PNG:SEND,TO=0
      mysGateway: TSF:CKU:OK
      mysGateway: TSF:MSG:GWL OK
      mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
      mysGateway: TSF:MSG:PINGED,ID=101,HP=1
      mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      mysGateway: !TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/6
      mysGateway: TSF:CKU:OK,FCTRL
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/11
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/12
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
      mysGateway: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
      mysGateway: TSF:MSG:READ,101-101-0,s=255,c=3,t=0,pt=1,l=1,sg=0:33
      mysGateway: Sending message on topic: mysensors-out/101/255/3/0/0```
      Thank for your help!
      Jacob
        bjacobtB
        bjacobtB
        bjacobt
        hi @mfalkvidd,
        Do you mind clarifying a bit, I've done sensorValue * 0.003363075
        Gives me 330, so
        330 * 0.003363075 = 1.10981475 volts
        Thank You!
        Jacob
        • bjacobtB bjacobt
          hi @mfalkvidd,
          Gives me 330, so
          Thank You!
          Jacob
          @bjacobt hmm. Yes, you are correct. The calculation seem a bit strange.
          Using this calculator I entered
          output 1.10981475 V
          R1 1000000
          R2 470000
          Which gives a battery voltage of 3.471V
          Looks like the calculations in the sketch are wrong? Or at least confusing :) I'm pretty lost.
          • tonnerre33T
            tonnerre33T
            tonnerre33
            #21
            must give you 1023 and not 330.
            For me it's a problem of value resistance or analogReference.
            Try to add this
              #ifdef MY_DEBUG
             Serial.print("Value A0 before force reference: ");
             Serial.print(sensorValue);
            delay(10000);
              #ifdef MY_DEBUG
             Serial.print("Value A0 after force reference: ");
            Just after this existing code :
               #ifdef MY_DEBUG
            And plz send me the logs of the node ;)
              Try to add this
                #ifdef MY_DEBUG
              delay(10000);
                #ifdef MY_DEBUG
                 #ifdef MY_DEBUG
              bjacobtB
              bjacobtB
              bjacobt
              @tonnerre33 Its still the same
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
              Node registration=1
              330
              Value A0 before force reference: 327
              Value A0 after force reference: 329
              Battery percent: 32 %
              TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:32
                 #ifdef MY_DEBUG
                #ifdef MY_DEBUG
              delay(10000);
                #ifdef MY_DEBUG
                 #ifdef MY_DEBUG
                 sleep(SLEEP_TIME);
              • tonnerre33T
                tonnerre33T
                tonnerre33
                #23
                Ok it's not a problem with the analogReference, you can delete this part of code.
                Did you control your resistance value and did you do this schema ?
                • bjacobtB
                  bjacobtB
                  bjacobt
                  wrote on last edited by bjacobt
                  #24
                  I'm sorry what do you mean by "control your resistance value"
                  this is my circuit,
                  1M resistor to +V rail, 470K resistor to GND and middle point to A0.
                  0_1478097209731_IMG_1543.JPG ,
                  • tonnerre33T
                    tonnerre33T
                    tonnerre33
                    Ok try to remove the jumper between V+ and AREF
                      bjacobtB
                      bjacobtB
                      bjacobt
                      @tonnerre33 That was it!
                      I'm getting Battery Voltage: 3.10 V
                      Battery percent: 92 %
                      Thank you so much :)
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Node registration=1
                      922
                      Value A0 before force reference: 924
                      Value A0 after force reference: 923
                      TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:92
                      • Meshx86M
                        Meshx86M
                        Meshx86
                        can Li 18650 3.7 batteries be used as they are rechargeable ? knowing the max voltage at full might reach 4.1-4.2v ? maybe keeping the voltage regulator ?
                        • Meshx86M Meshx86
                          @Meshx86 yes they can be used but as you've already identified the nrf (and maybe other components) will need to be protected from the high voltage when the battery is full.
                          The self-discharge rate of li-ion is higher than alkaline batteries which might affect how long the node can run before it needs charging.
                          • parachutesjP
                            parachutesjP
                            parachutesj
                            I just built the circuit which is explained in the thread with a Pro Mini 3.3 8 mHz
                            So far so good, I can read the voltage of the battery etc but my problem is, it consumes about 1.2 mA while in sleep, this is about factor 10 of the findings from the thread.
                            I just copied the code 1:1
                            Any glue what could be wrong or what get others with that setup? The Arduino is not modified at all.
                            SJ
                            N 1 Reply Last reply
                            • parachutesjP parachutesj
                              SJ
                              N
                              N
                              Nicklas Starkel
                              @parachutesj you have to modify the pro mini. Remove the power led according to instructions!
                              parachutesjP 1 Reply Last reply
                              • N Nicklas Starkel
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @Nicklas-Starkel thank you. If one could read...
                                I read the description again and thought that it should be 120uA stock and when removing LED and regulator it will even go down further but thinking about it, how should at base 120 uA and removing LED save additional 1.5mA???? LOL, sorry was a long day.
                                My Fluke reads 0.044 mA in sleep now (without LED). Sweet!
                                • N
                                  N
                                  Nicklas Starkel
                                  Another battery related question that I really do not understand.
                                  Are there different versions on how to read battery consumption?
                                  I see some sketches uses:
                                  long readVcc() {
                                    long result;
                                    noInterrupts ();
                                    // start the conversion
                                    ADCSRA |= _BV (ADSC) | _BV (ADIE);
                                    set_sleep_mode (SLEEP_MODE_ADC);    // sleep during sample
                                    interrupts ();
                                    sleep_mode ();
                                    // reading should be done, but better make sure
                                    // maybe the timer interrupt fired
                                    result = ADCL;
                                    result |= ADCH<<8;
                                    result = 1126400L / result; // Back-calculate AVcc in mV```
                                  However some (like the original one in this thread) uses:
                                  Is it due to different libraries or maybe it is the same but just programming wise different?
                                  • G
                                    G
                                    gloob
                                    If you are using the first sketch you dont have to use a seperate pin to measure the input voltage. There are also no resistors.
                                    You can run this on a bare ATmega with minimal hardware.
                                    • G gloob
                                      N
                                      N
                                      Nicklas Starkel
                                      @gloob thanks!
                                      One would think running with no resistors and not using a separate PIN would be better.
                                      @hek or @mfalkvidd , any comments as to why the original sketch is preferred over the other 'way' in this article?
                                      hekH 1 Reply Last reply
                                      • N Nicklas Starkel
                                        @gloob thanks!
                                        @Nicklas-Starkel
                                        https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
                                          @Nicklas-Starkel
                                          N
                                          N
                                          Nicklas Starkel
                                          @hek , I've read that post several times :)
                                          Since it was so outdated (2 years) I naturally assumed the 'battery powering article' was a newer way to do it (especially since mys2.0).
                                          Also, the post you linked to is attributed if you use no voltage regulator.
                                          And in the article this is also one of the things you are recommended to remove, hence making it even more confusing as to why the article describes another way than the post.
