  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 81.8k Views 44 Watching
  • skywatchS skywatch
    @mfalkvidd
    Thanks for the (very) fast reply!
    I have arduino in my greenhouse and in winter when it can be constantly wet and cold it is a real pain to take the laptop out to make any changes. This would be a good solution that would allow me and my laptop to stay warm and dry! - - - But how do I stop any one else programming it remotely? Is there some security to stop random programs being installed (it is controlling mains electricity and I need to be sure it is a safe option.
    tbowmoT
    tbowmoT
    tbowmo
    @skywatch
    You can use signing to authenticate a firmware upload. Then the attacker first need to get your pre shared keys to reprogram via ota
    • AndurilA
      AndurilA
      Anduril
      @skywatch just to be complete: using signing as @tbowmo suggested only works with dualoptiboot bootloader.
      When using MYSBootloader it will, as far as I know, accept any firmware when booting. To attack the node the attacker would have to reboot your node (power cycle,...) and then send his own firmware. So this is possible, but needs quite a good amount of control of your systems.
      tbowmoT 1 Reply Last reply
      • AndurilA Anduril
        tbowmoT
        tbowmoT
        tbowmo
        @Anduril
        @tekka have been looking at making a secure Ota boot loader, if I remember right. I thought that it was released already.
        But if an intruder is able to get yo your node to do a reset in order to have the mysbootloader kick in, he could just as well put a new firmware in by attaching a programmer directly to the node.
        • b0rmannB
          b0rmannB
          b0rmann
          Is it possible OTA from linux without MYSController?
          • skywatchS
            skywatchS
            skywatch
            Thank you all for the responses. If someone gets physical access then the game is over anyway. I just want to protect from some bored malicious person getting remote access and causing problems or even a fire.
            If it is secure from 'others' hacking it remotely I might give it a try.
            • AndurilA
              AndurilA
              Anduril
              When initiating a ota firmware update MYSController sends a reboot message to the node. Does anyone knows if that is protected by signing (if enabled)? If so, it would be quite safe excluding the physical access.
              • chrilleC
                chrilleC
                chrille
                Same question as @b0rmann - is it possible to do OTA from a non-Windows environment (Mac OSX or Linux)? A simple implementation in python or perl, that could talk to the gateway, and do OTA from the command line, would be a really nice to have. I would prefer the dualoptiboot solution, since it'll work with RFM69 nodes as well (at least that's my understanding)
                • E
                  E
                  emc2
                  It may be a silly question, but what is the point of setting the fuses before burning the bootloader (using Dualoptiboot)?
                  After burning the bootloader fuses are changed to E:06, H:D2, L:E2 anyway as set in board.txt
                  MysensorsMicro.bootloader.unlock_bits=0x3F
                  MysensorsMicro.bootloader.lock_bits=0x0F
                  MysensorsMicro.bootloader.low_fuses=0xE2
                  MysensorsMicro.bootloader.high_fuses=0xD2
                  MysensorsMicro.bootloader.extended_fuses=0x06
                  Should we burn them after to revert to E:06, H:DA, L:E2 ? (and loosing EESAVE which seems bad)
                  • tonnerre33T
                    tonnerre33T
                    tonnerre33
                    hello all,
                    i have installed MYSBootloaderV13pre on my arduino mini pro 3.3V and this work fine.
                    But i encountered some issues with my jeedom version (the node.js crash) that why i want to replace this bootloader (temporarily) but i can't.
                    Do you know why when i burn a different bootloader, MYSBootloaderV13pre is still present ?
                    Thx in advance for your answers
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      This might be a stupid question but would it be possible to add a AT25DF512C-SSHN-B to a regular Pro mini by connecting it to a custom PCB like a jModule with a AT25DF512C-SSHN-B ?
                        #26
                        i don't see any problem if you connect correctly the spi bus. it depends what's a jmodule??
                        in case i did this, perhaps smaller..
                        https://www.openhardware.io/view/18/OTA-and-Authentication-Evaluation-Board
                        • T
                          tlustoch
                          There is an ambiguity in documetation of MYSBootloader:
                          1. On https://www.mysensors.org/download/sensor_api_20#configuration there is a Note: "You can still have OTA FW updates without external flash but it requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE"
                          2. Above on https://www.mysensors.org/about/ota#enabling-ota-in-your-sketch there is written: "To enable OTA in your sketch, you need to add #define MY_OTA_FIRMWARE_FEATURE"
                            So, in the case of MYSBootloader (no external flash), what is correct (I suppose 2)?
                          Two additional questions:
                          Where is located MYSBootloader for MySensors 2.0?
                          Is it usable with 8MHz internal clock config?
                          Thanks for answer(s)
                          • T tlustoch
                            tonnerre33T
                            tonnerre33T
                            tonnerre33
                            @tlustoch You need to enable MY_OTA_FIRMWARE_FEATURE only if you use DualOptiBoot.
                            With MYSBootloader, you don't need ;)
                            I use MYSBootloader 1.3 pre-release with mysensors 2.0. You can find it here : https://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta
                            And yes it usable with 8 MHZ internal clock config if you burn the bootloader with 8Mhz internal clock setting.
                            • L
                              L
                              LastSamurai
                              Short question from me: my mysensors network is set up with domoticz as a controller on a raspberry pi. I need to upgrade all my nodes to Version 2 of mysensors soon and want to enable wireless programming while I am at it. As far as I understand I do need to use MYSController to update a node, which seems to be a windows only program. Any way I can still use that with my linux based (raspi) network?
                              • TakeroT
                                TakeroT
                                Takero
                                wrote on last edited by Takero
                                #30
                                For OTA Update under Rpi i used this: http://www.virtualhere.com/
                                • just install it on the Pi, stop the controler software
                                wget http://www.virtualhere.com/sites/default/files/usbserver/vhusbdarmpi2
                                vhusbdarmpi2 -> for Pi2 only (see homepage for other platforms)
                                sudo chmod +x ./vhusbdarmpi2
                                • start the virtualhere server
                                sudo ./vhusbdarmpi2
                                • install the client on your Windows System
                                • Mount the Com-Port
                                • start MYSControler
                                • do what you want to do
                                • stop client
                                now you have to reboot your rpi, stop virtualhere server its not enoth, cant mount device again. After restart everythinks works well.
                                Greetings
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  I can't figure out this step:
                                  Go to Arduino Ide, in Board Manager, choose SensebenderMicro if you want to use DualOptiboot bootloader OTA. Or choose Arduino Mini pro MYSBootloader
                                  I cant find any sensbender board when searching the boards manager, I also tried downloading the 2.0 directly but cant find any boards there either. How should I do this?
                                  hekH 1 Reply Last reply
                                    @Cliff-Karlsson
                                    https://github.com/mysensors/ArduinoBoards
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      Thanks, but now I get this error in Arduino IDE when burning the bootloader:
                                      avrdude: warning: cannot set sck period. please check for usbasp firmware update.
                                      ***failed;
                                      avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                                      This behaviour is deprecated and will result in an error in future version
                                      You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                                      Is this still ok?
                                      • Cliff KarlssonC
                                        Cliff KarlssonC
                                        Cliff Karlsson
                                        And this happens when I try to upoad a sketch to the board:
                                        Sketch uses 16,796 bytes (54%) of program storage space. Maximum is 30,720 bytes.
                                        Global variables use 739 bytes (36%) of dynamic memory, leaving 1,309 bytes for local variables. Maximum is 2,048 bytes.
                                        avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x90
                                        avrdude: stk500_cmd(): protocol error
                                        avr_read(): error reading address 0x0137
                                        read operation not supported for memory "flash"
                                        avrdude: failed to read all of flash memory, rc=-2
                                        the selected serial port avrdude: failed to read all of flash memory, rc=-2
                                        • A
                                          Alex B Goode
                                          Fellows, let me ask you about the procedure of switching controllers during OTA.
                                          My sensors are connected to a serial gateway, which is operated by a controller.
                                          In my case the controller is Domoticz server hosted by Raspberry Pi2.
                                          So if I want to initiate updating one of my nodes over the air then I need to... stop my current controller on my Raspberry Pi2 and... start a new gateway on a Windows machine with MYSControler, wait when all nodes will re-discover the new gateway and connect, and then use MYSControler to do all updates I need?
                                          TakeroT 1 Reply Last reply
