  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 227.8k Views 53 Watching
  • N Nicklas Starkel
    @gloob thanks!
    One would think running with no resistors and not using a separate PIN would be better.
    @hek or @mfalkvidd , any comments as to why the original sketch is preferred over the other 'way' in this article?
    @Nicklas-Starkel
    https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
    N 1 Reply Last reply
      @Nicklas-Starkel
      N
      N
      Nicklas Starkel
      @hek , I've read that post several times :)
      Since it was so outdated (2 years) I naturally assumed the 'battery powering article' was a newer way to do it (especially since mys2.0).
      Also, the post you linked to is attributed if you use no voltage regulator.
      And in the article this is also one of the things you are recommended to remove, hence making it even more confusing as to why the article describes another way than the post.
      • Meshx86M
        Meshx86M
        Meshx86
        wrote on last edited by Meshx86
        #37
        i just want to get this once and for all, so others coming by gets it directly instead of going through all the 2 threads posts, please correct me if i am wrong:
        1- using the voltage divider is needed if there is a voltage regulator / booster where where VBatt != Vcc.
        2- using the voltage regulator is not needed if the voltage regulator is removed / no booster is used (powering directly from 2 x AA batteries) where VBatt == Vcc.
        *I've noticed the 2nd method requires inputting battrie's DMM measured values vs arduino ones for correction, is this a down side if you need to change the battery later on ? or is it just programmed once ? and does the 1st method rquirs these corrections too ?
        • Meshx86M Meshx86
          GertSandersG
          GertSandersG
          GertSanders
          @Meshx86
          actually, you need a voltage divider if the voltage to be measured is above the maximum allowed by the processor at the speed you are running it.
          If Vcc is 5V, then any voltage above 5V should be measured via a voltage divider.
          If Vcc is 3.3V same principle, but you could get away with measuring 5V directly (would not kill the processor), but your values may be off.
          Meshx86M 1 Reply Last reply
          • GertSandersG GertSanders
            @Meshx86
            Meshx86M
            Meshx86M
            Meshx86
            #39
            @GertSanders following the instructions of this post suggest using Alkaline batteries (apparently Li-ion aren't a good idea for sensor nodes ?! plus they are expensive), the optimal solution would be using 2 x AA batteries as some ans this post suggested.
            I believe there is no way 2 x AA batteries in series would measure anywhere near 3.3v, the max i measured with brand new batteries was 3.2v.
            my major concern is:
            would i still need to the do the voltage corrections when using the voltage divider ? if so, does that need to be reprogrammed every time you replace the battery ?
            sorry to bring this again @Yveaux @axillent
            • Meshx86M Meshx86
              GertSandersG
              GertSandersG
              GertSanders
              @Meshx86
              No problem to ask. I use the intern measurement method, which uses the internal 1.1V reference of the atmega328, so even if the Vcc value changes from 3.2V -> 2.6V, the reference will always be 1.1V, and the internal method allows you to calculate the actual measured battery voltage based on a difference with the reference, even with a declining value on Vcc (if powered by the same batteries).
                @Meshx86
                Meshx86M
                Meshx86M
                Meshx86
                @GertSanders sorry mate, am more of a software guy..
                according to the lib i've seen and @Yveaux's example for the internal method, at the begining you need to define a corrective value :
                Vcc vcc(VccCorrection);
                is this necessary for an accurate reading ? and is the corrective value need to be just entered once (like a calibration per arduino) or need to be reconfigured every time you replace a battery ?
                • N
                  N
                  Nicklas Starkel
                  Good article/site on why Alkaline is the best way to go for Mysensors nodes :)
                  http://batteryuniversity.com/learn/article/elevating_self_discharge
                  AWIA 1 Reply Last reply
                  • Meshx86M Meshx86
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @Meshx86
                    The corrective value is needed every time you change a battery, AND if you need high accuracy.
                    On my battery based nodes I do not have a need for absolute accuracy, I just need to see the trend of the Vcc value.
                    Changing the battery happens every 12-24 months (depends on the use), so I'm not very interested in absolute accuracy. If you need real accurate measuring, I would suggest a real Analog-To_Digital chip.
                      @Meshx86
                      Meshx86M
                      Meshx86M
                      Meshx86
                      @GertSanders thanks , i think accuracy isn't a deal breaker, i believe everyone's concern is to just know when the batteries need to be replaced (hopefully that can be done without specifying the voltage correction).
                      • Meshx86M Meshx86
                        @Meshx86 ok, being quoted so many times I can also add my 5 cents :smile:
                        The correction factor is optional. You can use it to improve the measured voltage, as the internal voltage reference is only accurate up to so many percentage (have to look up the number). It is unique to the arduino used.
                        This factor should however not depend on the batteries, possibly on environmental factors (e.g. Temperature)
                        • YveauxY Yveaux
                          Meshx86M
                          Meshx86M
                          Meshx86
                          @Yveaux one last, i promise :P
                          if max battery voltage is actually 3.2v, does that mean that the battery percentage would show 100% for quite sometime before it starts dropping below 3.0v (assuming vmax is set to 3.0) ? or would it increase the inaccuracy gap ?
                          • Meshx86M Meshx86
                            @Meshx86 the function Read_Perc() takes a boolean as 3rd parameter. Default it's true, which means the result is clipped to 0..100% range.
                            So, if maximum is set to 3v, and you are currently above it, it will report 100% until you drop below 3v.
                            • N Nicklas Starkel
                              AWIA
                              AWIA
                              AWI
                              @Nicklas-Starkel The article mostly talks about rechargeable batteries. I prefer non rechargeable Lithium batteries (like coin cells) for their energy density and very low self discharge.
                              My major concern with (cheap) alkaline batteries is their leakage of aggressive chemicals. I had to trash my first nodes because of this :unamused:
                              N tonnerre33T 2 Replies Last reply
                              • AWIA AWI
                                N
                                N
                                Nicklas Starkel
                                @AWI in the first part it states:
                                "Primary cells such as lithium-metal and alkaline retain the stored energy best, and can be kept in storage for several years."
                                So you are correct and between Alkaline and Lithium-metal maybe the latter would be best. :)
                                I have no experience with coin cells and will do some testing with them as soon as I can.
                                Since this is the battery article, would you please tell me what you use and how you use it. What you expected and if the batteries lived up to your expectations. Would be cool to know as you've had more experience then me (and many like me)!
                                • AWIA AWI
                                  tonnerre33T
                                  tonnerre33T
                                  tonnerre33
                                  @AWI I'm agree with you but coin cells have less capacity. The difference of the self discharge between coin cells and alkaline is not important (1% vs 2%), but the capacity and size are.
                                  Here is a link with the Battery self-discharge rates :
                                  http://www.gammon.com.au/power
                                  • N Nicklas Starkel
                                    AWIA
                                    AWIA
                                    AWI
                                    @Nicklas-Starkel I mostly use a 'large' version lithium cell i.e. Cr123. These were used large in compact camera's and have a huge capacity and very little self discharge. My best example is the sensor in the fridge which measure temp and humidity every 10 secs and sends with nrf24l01 (MySensors of course). This one runs for almost two years now and has a stable 3.02V since the second month.
                                    The coin cells need special care a these have a high 'internal resistance'. You need to be careful with designing the sketch so that the load is as short and light as possible.
                                    There are some of my postings on this site which elaborate on the subject. (I'm on a mobile phone right now...)
                                    • AWIA AWI
                                      N
                                      N
                                      Nicklas Starkel
                                      @AWI OMG there is so many options when you look at it!
                                      I think it all boils down to design (size) or money.
                                      Normal AA roughly 0.3EUR/pc are quite large but OK power but cheap
                                      CR123 roughly 2.5EUR/pc are quite small and OK power but expensive
                                      Coin cell roughly 1EUR/pc and they are the smallest but not packing a good punch while being semi cheap/expensive.
                                      Obviously I have to build one node with each and put them in flowerpots around the flat to see in in action :)
                                      And to top it off, I know there is a company in USA that has created a new battery that will double 'Ah' in same size batteries. They should launch this month i think, but think they will go for cellphone makers in the beginning.
                                      parachutesjP 1 Reply Last reply
                                      • N Nicklas Starkel
                                        parachutesjP
                                        parachutesjP
                                        parachutesj
                                        I am not getting it...
                                        I have a 3.3V Pro Mini, it is connected to my table power supply and want it to be powered by a coin cell later. To test the VCC lib, I set
                                        const float VccExpected   = 3.21;
                                        What do I need to put here?
                                        const float VccCorrection = 3.21/3.21;
                                        It always returns BatteryPercentage of 2 or 3% seems the function is not calculating right. Anyhow I saw there is another function to call Read_Volts()
                                        float volts = (float)vcc.Read_Volts();
                                        int myPerc = volts *100 / VccExpected;
                                        So "myPerc" returns a value of 98% which seems feasible, also when reducing Voltage it drops.
                                        But still, not getting the values with the build in function read_Perc()
                                        • Moebius LutchingM
                                          Moebius LutchingM
                                          Moebius Lutching
                                          I'm building my home automation with a few Whisper Nodes (https://talk2.wisen.com.au/product-talk2-whisper-node-avr/) and I just got them working with the MySensor code. I'm running most of my projects with two AA but I just setup one with a CR2032 transmitting my attic temperature every 5 minutes to see how it goes. One thing I discovered is that the board comes two "built-in" resistor divider to monitor the battery and power supply voltage, which is pretty handy... also they have added a Mosfet on the battery voltage divider, I guess to eliminate the constant current leak consumed by the voltage divider, am I right?! (https://bitbucket.org/talk2/whisper-node-avr/overview#markdown-header-voltage-monitor)
