  3. Vera
  4. Sensors don´t update
11 Posts 6 Posters 4.3k Views 1 Watching
    sneaksneak
    I have installed all the 1.4 files in my Vera lite.
    Made an arduino nano serial gateway an it seems to be working. plugin version 1.4 - Lib version 1.4 It says.
    Made one water meter sensor and one Light sensor.
    Both is included and everythis is ok but I dont get any sensor data.
    If I restart the sensors i get a new time for last update, but after that it dont update again. No data and no more last update.
    What am I missing?
      Turn on debugging and see what happens in the sensor.
      • I
        I
        integlikewhoa
        I have only had that twice. One time was a low battery and other was a range/wifi issue.
        • m26872M
          m26872M
          m26872
          Are your nodes on battery? I experienced something similar when using step-up-regulators to feed the radio unit. I've used both 3.3V and 5V from mysensors store and concluded that the radio prefer direct battery supply, regardless of capacitor.
            sneaksneak
            This is what I get in serial monitor from the light sensor.
            I dont know what to look for.
            sensor started, id 1
            send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
            read: 0-0-1 s=255,c=3,t=6,pt=0,l=2:M
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Light Sensor
            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
            send: 1-1-0-0 s=0,c=0,t=16,pt=0,l=3,st=ok:1.4
            The sensors are powered from a usb phone charger 2,1A so it cant be a power problem.
            RJ_MakeR 1 Reply Last reply
              Initial transmits seems to get through. But I can't see any light sensor data. Anything else coming except the zeroes? Guess it will only send in updated values .. so if light sensor only gives zeroes nothing will be transmitted.
                sneaksneak
                No, there is nothing else except the zeroes.
                Bad light sensor mabye?
                  yep. Try moving it or use a flashlight when testing.
                  • S sneaksneak
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    It's been my experience now, to never, ever ever say it cannot be a power problem. :-)
                    Can you add some debug code to the sketch to see what's going on in there?
                    RJ_Make
                      sneaksneak
                      Ok. When used a flashlight it response with a new lux? value.
                      I was thinking of using this sensor on the laundrymachine.
                      My machine has a led that is blinking when the laundry is ready. Can I use this or should i use the power meter puls led sketch instead?
                      Thank you for the help, and thank you for an intresting project.
                      • korttomaK
                        korttomaK
                        korttoma
                        What kind of a light sensor are you using? Maybe it is just not sensitive enough to detect the LED light. If you use one of them LM393 type you could try to use the "DO" and hock it up to a binary input instead. Then you should be able to adjust the sensitivity with the photometer.
                        • Tomas
