  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.8k Views 15 Watching
  • Michal MormonM Michal Mormon
    My domoticz found S_SCENE_CONTROLLER sensor but there is not any devices for such a hardware. Do you know how can I control scene with it?
    Maciej Kulawik
    @Michal-Mormon
    S_SCENE_CONTROLLER can send messages V_SCENE_ON and V_SCENE_OFF. If you send those messages for the first time, domoticz will create new switch with the name 'scene'.
    Michal MormonM 1 Reply Last reply
    • M Maciej Kulawik
      @Michal-Mormon
      Michal MormonM
      Michal MormonM
      Michal Mormon
      @Maciej-Kulawik
      I found it as 'Scene' switch but this example send only V_SCENE_ON the first time (the switch is still ON later)
        @Maciej-Kulawik
        Maciej Kulawik
        @Michal-Mormon
        Yes, exactly! It looks like without scene_off sent from scene controller in domoticz it will be one-time action (since if this scene switch is switched on you cannot switch it on again). You can try to setup automatic switching it off in domoticz.
        • Michal MormonM
          Michal MormonM
          Michal Mormon
          I added 2 lines and works perfect with Domoticz:
          MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON);
          MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //added line
          gw.send(scene.set(keyInt));
          gw.send(scene2.set(keyInt)); //added line
          Michel - ItM 1 Reply Last reply
            Michel - ItM
            Michel - ItM
            Michel - It
            @Michal-Mormon awesome!
            • DrJeffD
              DrJeffD
              DrJeff
              @petewill Have you updated this code to 2.0 yet? What is different?
              hekH petewillP 2 Replies Last reply
              • DrJeffD DrJeff
                @DrJeff
                https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                DrJeffD 1 Reply Last reply
                  @DrJeff
                  DrJeffD
                  DrJeffD
                  DrJeff
                  @hek
                  Yes I read but was soooo lazy! I just wanted it already done :grimacing:
                  I just update one of my old sensors it was a simple single relay. My others are way more complicated! I will give this a try.
                  • DrJeffD DrJeff
                    petewillP
                    petewillP
                    petewill
                    Not yet, but I'm slowly working on it. :) The link hek gave is very helpful if you want to try it yourself. It's a good way to learn about the new features in 2.0.
                    • dvr123D
                      dvr123D
                      dvr123
                      @petewill Any news about the 2.0 code? I am in the process of making scene controllers in the different rooms but can't get it to work.
                      petewillP 1 Reply Last reply
                      • dvr123D dvr123
                        petewillP
                        petewillP
                        petewill
                        @dvr123 No, not yet :grimacing:
                        My thermostat project has taken priority over everything because I need one in my house. I have a prototype working but I need to finish it. It is taking much longer than expected and I also haven't had much time lately. Sorry.
                        • Matt PittsM
                          Matt PittsM
                          Matt Pitts
                          Hi Guys,
                          I've been trying to compile this sketch without any success. I keep getting the following error when compiling
                          #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                          Can anyone help? thanks
                          • Matt PittsM Matt Pitts
                            Hi Guys,
                            petewillP
                            petewillP
                            petewill
                            @Matt-Pitts I still haven't had time to convert/test the sketch for version 2.0. If you want to take a shot at it there is info here: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                            I will get to it eventually I just have other projects that are consuming my time right now. Sorry.
                            • Łukasz KostrzewaŁ
                              Łukasz KostrzewaŁ
                              Łukasz Kostrzewa
                              • dvr123D
                                dvr123D
                                dvr123
                                Why is Lukas' post deleted? I have got it in the mail and it seems to compile correctly.
                                The only thing is that Domoticz only recognizes the button on the first click, after that Domoticz isn't receiving anything.
                                  Not sure why @Łukasz-Kostrzewa deleted it. As an administrator, I can still see the post.
                                  • Łukasz KostrzewaŁ
                                    Łukasz KostrzewaŁ
                                    Łukasz Kostrzewa
                                    Hi
                                    I delated my post because it pasted wrong. I try to paste it correctly but don't know how:( (hek - maybe You as an administrator can paste it corectly?)
                                    dvr123 have right that this code recognize the buton only on the first click:(
                                    Mayby someone knows how to modify the code to work like normal buton (not the scene controller)?
                                    Best regards
                                    • dvr123D
                                      dvr123D
                                      dvr123
                                      I am okey with the scene button, but it has to work more than one time :smile:
                                        @Łukasz-Kostrzewa, paste code within 3 backtick characters, like this:
                                        Insert Code Here
                                        • Łukasz KostrzewaŁ
                                          Łukasz KostrzewaŁ
                                          Łukasz Kostrzewa
                                          You could do that but it is not a great solution.
                                          Add to Domoticz all 8 switches (4 when pressed and 4 when hold).
                                          In first switch (pressed switch) add Slave device (first hold switch). Do it for all 4 switches.
                                          To 5,6,7,8 switches add Slave Device (1,2,3,4 switch).
                                          It works like that:
                                          When You press First number on keyboard it change state to ON and 5 to OFF
                                          When You Hold first number on keybord it change state of 5 switch to ON and first to OFF.
                                          Next You have to make some events to trigger some scenes or lights
                                          I have hope I managed to explain what I mean :)
                                          Best regards
