  3. How To: Make a Simple/Cheap Scene Controller (with video)
62 Posts 19 Posters 48.9k Views 15 Watching
  • DrJeffD DrJeff
    @petewill Have you updated this code to 2.0 yet? What is different?
    @DrJeff
    https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
    DrJeffD 1 Reply Last reply
      @DrJeff
      DrJeffD
      DrJeffD
      DrJeff
      @hek
      Yes I read but was soooo lazy! I just wanted it already done :grimacing:
      I just update one of my old sensors it was a simple single relay. My others are way more complicated! I will give this a try.
      • DrJeffD DrJeff
        petewillP
        petewillP
        petewill
        Not yet, but I'm slowly working on it. :) The link hek gave is very helpful if you want to try it yourself. It's a good way to learn about the new features in 2.0.
        • dvr123D
          dvr123D
          dvr123
          @petewill Any news about the 2.0 code? I am in the process of making scene controllers in the different rooms but can't get it to work.
          petewillP 1 Reply Last reply
          • dvr123D dvr123
            petewillP
            petewillP
            petewill
            @dvr123 No, not yet :grimacing:
            My thermostat project has taken priority over everything because I need one in my house. I have a prototype working but I need to finish it. It is taking much longer than expected and I also haven't had much time lately. Sorry.
            • Matt PittsM
              Matt PittsM
              Matt Pitts
              Hi Guys,
              I've been trying to compile this sketch without any success. I keep getting the following error when compiling
              #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
              Can anyone help? thanks
              • Matt PittsM Matt Pitts
                Hi Guys,
                petewillP
                petewillP
                petewill
                @Matt-Pitts I still haven't had time to convert/test the sketch for version 2.0. If you want to take a shot at it there is info here: https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                I will get to it eventually I just have other projects that are consuming my time right now. Sorry.
                • Łukasz KostrzewaŁ
                  Łukasz KostrzewaŁ
                  Łukasz Kostrzewa
                  • dvr123D
                    dvr123D
                    dvr123
                    Why is Lukas' post deleted? I have got it in the mail and it seems to compile correctly.
                    The only thing is that Domoticz only recognizes the button on the first click, after that Domoticz isn't receiving anything.
                      Not sure why @Łukasz-Kostrzewa deleted it. As an administrator, I can still see the post.
                      • Łukasz KostrzewaŁ
                        Łukasz KostrzewaŁ
                        Łukasz Kostrzewa
                        Hi
                        I delated my post because it pasted wrong. I try to paste it correctly but don't know how:( (hek - maybe You as an administrator can paste it corectly?)
                        dvr123 have right that this code recognize the buton only on the first click:(
                        Mayby someone knows how to modify the code to work like normal buton (not the scene controller)?
                        Best regards
                        • dvr123D
                          dvr123D
                          dvr123
                          I am okey with the scene button, but it has to work more than one time :smile:
                            @Łukasz-Kostrzewa, paste code within 3 backtick characters, like this:
                            Insert Code Here
                            • Łukasz KostrzewaŁ
                              Łukasz KostrzewaŁ
                              Łukasz Kostrzewa
                              You could do that but it is not a great solution.
                              Add to Domoticz all 8 switches (4 when pressed and 4 when hold).
                              In first switch (pressed switch) add Slave device (first hold switch). Do it for all 4 switches.
                              To 5,6,7,8 switches add Slave Device (1,2,3,4 switch).
                              It works like that:
                              When You press First number on keyboard it change state to ON and 5 to OFF
                              When You Hold first number on keybord it change state of 5 switch to ON and first to OFF.
                              Next You have to make some events to trigger some scenes or lights
                              I have hope I managed to explain what I mean :)
                              Best regards
                              • Łukasz KostrzewaŁ
                                Łukasz KostrzewaŁ
                                Łukasz Kostrzewa
                                wrote on last edited by Łukasz Kostrzewa
                                #48
                                The 2.0 version code:
                                #include <Keypad.h>
                                #define NODE_ID 14 // or set to AUTO if you want gw to assign a NODE_ID for you.
                                #define SN "Scene Controller"
                                #define SV "1.0"
                                #define KEYPAD_CHILD_ID 95
                                MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON);
                                MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF);
                                const byte ROWS = 4; //four rows
                                const byte COLS = 1; //three columns
                                char keys[ROWS][COLS] = {
                                  {'1'},
                                  {'2'},
                                  {'3'},
                                  {'4'}
                                byte rowPins[ROWS] = {6, 7, 4, 5}; //connect to the row pinouts of the keypad
                                byte colPins[COLS] = {8}; //connect to the column pinouts of the keypad
                                Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
                                byte lastState;
                                  sendSketchInfo(SN, SV);
                                  present(KEYPAD_CHILD_ID, S_SCENE_CONTROLLER);
                                  keypad.addEventListener(keypadEvent);
                                  char key = keypad.getKey();
                                void keypadEvent(KeypadEvent key) {
                                  switch (keypad.getState()) {
                                    case PRESSED:
                                      lastState = 1;
                                    case HOLD:
                                      lastState = 2;
                                    case RELEASED:
                                      int keyInt = key - '0'; //Quick way to convert Char to Int so it can be sent to controller
                                      if (lastState == 2) {
                                        keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
                                      send(scene.set(keyInt));
                                • dvr123D
                                  dvr123D
                                  dvr123
                                  That's actually much easier! But how do we manage to get it working more than one time? Because I can add the button but after that I can't control it. I can't see the button presses in the Domoticz log either.
                                  • Łukasz KostrzewaŁ
                                    Łukasz KostrzewaŁ
                                    Łukasz Kostrzewa
                                    #50
                                    Hi
                                    After
                                    Add
                                    send(scene2.set(keyInt));
                                    Write this code to arduino (now You can OFF all the switches) Next delete code You added and write it to Arduino once again but now in Domoticz make modifications I writed couple post higher. When You do that You will be able to control 4 scenes and another 4 will bo halpefull to OFF the first4 (when You hold the buttons)
                                    • rechin304R
                                      rechin304R
                                      rechin304
                                      Complete code version 2 with short press ON long press OFF.
                                      #include <Keypad.h>
                                      #define NODE_ID AUTO // or set to AUTO if you want gw to assign a NODE_ID for you.
                                      #define SV "2.0"
                                      MyMessage scene(KEYPAD_CHILD_ID, V_SCENE_ON); //scene ON
                                      MyMessage scene2(KEYPAD_CHILD_ID, V_SCENE_OFF); //scene OFF
                                      const byte COLS = 1; //one column
                                        {'1'},
                                        {'2'},
                                        {'3'},
                                        {'4'}
                                      byte lastState;
                                          case PRESSED:
                                            lastState = 1;
                                          case HOLD:
                                            lastState = 2;
                                          case RELEASED:
                                              //keyInt = keyInt + 4; //If button is held, add 4.  If using more than 4 buttons this number will need to be changed
                                            //break;
                                      • Łukasz KostrzewaŁ
                                        Łukasz KostrzewaŁ
                                        Łukasz Kostrzewa
                                        Hi rechin304
                                        Thank You for Your code...It's working great!!!
                                        Best regards
                                        rechin304R 1 Reply Last reply
                                        • Łukasz KostrzewaŁ Łukasz Kostrzewa
                                          Hi rechin304
                                          Best regards
                                          rechin304R
                                          rechin304R
                                          rechin304
                                          @Łukasz-Kostrzewa you are welcome, all thanks goes to @petewill for initial code.
