  3. Vera
  4. Pffff lib 2.0 ethernet module not working
17 Posts 3 Posters 4.5k Views 3 Watching
  • riochickenR Offline
    riochickenR Offline
    riochicken
    Hi guys,
    I guess I should never have updated my gateway and library to 2.0, the gateway is not functioning anymore although it says in Vera it's connected, but it does not show the lib version, I even pulled out a new Nano to make sure it was not defective, I must oversee something somewhere but I ran out of ideas, I even reuploaded the files to my vera but no luck, last resort is to use the old files and retry... I do remember from the old version you had to enable softspi for a w5100 module in the myconfig.h module but that one is not included anymore in the new w5100ethernet ino... When I enable it in the w5100 ino the device does not work anymore, which seems only logical since other pins are used...
    Anybody any ideas?
    Thanks in advance!!
    Richard
    B 1 Reply Last reply
    • riochickenR riochicken
      Hi guys,
      Anybody any ideas?
      Thanks in advance!!
      Richard
      B Offline
      B Offline
      blacey
      @riochicken I'm not sure these issues are the root cause for your problem, but a couple Ethernet issues have been resolved since the release 2.0 in July. You may want to try the development version to see if you have better luck.
      • H Offline
        H Offline
        The new sketch automatically enables soft-spi for the rf24 radio. So the wiring should be identical to the older version of the gateway.
        Are you able to connect to it using nc or some other terminal program?
        What does the serial log say?
        riochickenR 2 Replies Last reply
        • H hek
          riochickenR Offline
          riochickenR Offline
          riochicken
          @hek: I tried the developers library as well, but that do any good! After compiling and uploading I couldnt ping at all anymore, after putting back the 2.0 library and compiling I was able to ping it and connect to it via a telnet session on port 5003, the serial output is:
          IP: 192.168.1.91
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSM:RADIO:OK
          0;255;3;0;9;TSM:GW MODE
          0;255;3;0;9;TSM:READY
          So everything seems to be working, until I look at my Vera, the mysensors pictogram is showing a connected to 192.168.1.91 5003 but when you go to settings to include a device, it show the below screenshot. After a while after clicking start it shows the error, cannot send command - communications error....
          0_1481218571190_upload-226f85a6-d97d-4147-9b22-ef76626bc7d5
          • H hek
            riochickenR Offline
            riochickenR Offline
            riochicken
            @hek I've just used the latest development version but now I cannot ping the GW at all... :(
            • H Offline
              H Offline
              Very strange indeed. You are running the UI7 branch of the vera plugin? https://github.com/mysensors/Vera/tree/UI7
              The only thing I can think of is that you have some network problem or powering issue. Are you powering the gateway identically when connecting to it from your computer vs vera?
              riochickenR 1 Reply Last reply
              • H hek
                riochickenR Offline
                riochickenR Offline
                riochicken
                wrote on last edited by riochicken
                @hek I feel kinda stupid at the moment, I did import the library in the arduino software but did not activate it apparently.. I am now able to ping the gateway with the latest development library but still no luck with the inclusion... I am getting a little frustrated here.. at first (I stepped back to an UNO) I tried it on my local USB port, and because of your comment, I tried it on a separate USB power supply but still no luck... Ow and Yes I am using the UI7 branch, even removed it from my Vera and uploaded it again...
                • H Offline
                  H Offline
                  Is the inclusion mode feature enabled in your gateway?
                  • H hek
                    riochickenR Offline
                    riochickenR Offline
                    riochicken
                    @hek It worked before so I guess Yes... I do get the error: WARNING: Spurious .tools folder in 'MySensors' library when using the development version, seen before? It does upload to the Arduino Uno but it is not pingable...
                    • H Offline
                      H Offline
                      You enable it in the sketch (look through the defines) before compiling/uploading.
                      • H hek
                        riochickenR Offline
                        riochickenR Offline
                        riochicken
                        @hek Could it be that that is causing my gateway not to work? And maybe a newby question but I have no clue how I can enable it...
                        PS: Thank you for your time to help me out...
                        • H Offline
                          H Offline
                          Hmm. no, probably not (looking at the screenshot).
                          If you look at the advanced tab in the gateway device (vera) does it have a "CommFailure" field? What happens if you set it to "0".
                          • H hek
                            riochickenR Offline
                            riochickenR Offline
                            riochicken
                            @hek Yes it has a CommFailure filed and it is already set to 0..
                            0_1481404664094_upload-40a3135d-99ab-411a-a2fb-bf2c00eed77f
                            • H Offline
                              H Offline
                              Ok, guess you'd better start analysing the log file on Vera. So search for "ssh vera log file" on how to get access to it.
                              • H hek
                                riochickenR Offline
                                riochickenR Offline
                                riochicken
                                @hek ok, will do and will post it as soon as I know something more.. Thanks for your help so far...
                                • H hek
                                  riochickenR Offline
                                  riochickenR Offline
                                  riochicken
                                  @hek The serial gateway works fine, I'll stick to the serial gateway for as long as it takes... thank you for your help!
                                  • H Offline
                                    H Offline
                                    Ok, great! Hopefully the ethernet problems will be sorted out
                                    12.1k
