  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • C4VetteC
    C4VetteC
    C4Vette
    wrote on last edited by C4Vette
    Question about a minor detail:
    Wouldn't a motionsenser trip be missed during:
    delay(dht.getMinimumSamplingPeriod()); ?
    For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
    • C4VetteC C4Vette
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
      The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
      since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
      you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
      C4VetteC 1 Reply Last reply
        C4VetteC
        C4VetteC
        C4Vette
        @BulldogLowell
        Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
        At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
        Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
        • D
          Dean
          Nice set up!
          • K Konrad Walsh
            I am wanted to share my 3-in-1 sensor in case its of use to anyone
            Its really just a combination of what's already available
            I used the following hardware:
            Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
            1 x Motion Sensor LINK
            1 x DHT22 LINK
            Connections is as all other guides except:
            Motion Sensor digital to Pin D3
            and the DHT to Pin D4
            Here is my code
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define CHILD_ID_MOT 2   // Id of the sensor child
            DHT dht;
            float lastTemp;
            float lastHum;
            boolean metric = true;
            MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
              gw.begin();
              gw.sendSketchInfo("Humidity/Motion", "1.0");
              gw.present(CHILD_ID_MOT, S_MOTION);
              // Read digital motion value
              Serial.println(tripped);
              gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                Serial.print("T: ");
              if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("H: ");
                  Serial.println(humidity);
              gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
            If anyone wants more info please ask.. I will put up pictures or diagrams if needed
            mvader
            I'm having a problem with this build.
            i'm using the same hardware.
            I get nothing in the serial output screen.
            i am able to compile and load the code.
            when i measure on the 3.3 rail i get 3.8 (only when the radio is hooked up, i get 3.3 when nothing is hooked to the board)
            when i measure on the 5v rail, i get 4.7v when the motion and temp sensor are hooked up.
            I suspect my issues may be voltage related. although i'm not sure why i'm getting nothing on the serial monitor.
            since you said you didn't need any steppers, do you have any suggestions?
            thanks
            • K Konrad Walsh
              1 x DHT22 LINK
              Here is my code
              DHT dht;
              float lastTemp;
              float lastHum;
                gw.begin();
                  if (!metric) {
                    lastHum = humidity;
              Anthony Straw
              @Konrad-Walsh my nano and pro mini on the way! double each! cant wait!! fed up all confused so have ard r3 n mega n nano n promini all tick tick!
              • D
                djolafritte
                Works like a charm...
                Thanks for sharing :)
                • D
                  Dylano
                  dear all.
                  What battery u use?
                  And what is the battery time?
                  Domoticz, with a lot of working hardware, include mysensors :-)
                  OpenPLI, RuneAudio, Solarmeter, etc......
                  Not a great builder of software and hardware, more a user...
                  Only i try to do my best :-(
                  • V
                    V
                    viableoption
                    Looks pretty sweet. How is it working comparing to existing products with the same features?
                    • Łukasz KostrzewaŁ
                      Łukasz KostrzewaŁ
                      Łukasz Kostrzewa
                      Hi Konrad
                      Thx for great code. It works like charm but...
                      I have a question... It is possible to add to Your code one more (Door/Window) sensor?
                      Mayby You can post that code on this forum?
                      Best regards
                      • Łukasz KostrzewaŁ
                        Łukasz KostrzewaŁ
                        Łukasz Kostrzewa
                        wrote on last edited by Łukasz Kostrzewa
                        #29
                        Hi to all
                        I changed a little Konrad sketch and add to 3in1 Humidity Temp and Motion one more sensor (Door\Window)
                        Here is my code:
                        #define CHILD_ID_DOOR 3
                        #define BUTTON_PIN_DOOR 2
                        Bounce debouncer = Bounce();
                        int oldValue=-1;
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
                        gw.begin();
                        pinMode(BUTTON_PIN_DOOR,INPUT);
                        digitalWrite(BUTTON_PIN_DOOR,HIGH);
                        debouncer.attach(BUTTON_PIN_DOOR);
                        debouncer.interval(5);
                        gw.sendSketchInfo("4in1", "1.0");
                        gw.present(CHILD_ID_DOOR, S_DOOR);
                        if (!metric) {
                        lastHum = humidity;
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue) {
                        // Send in the new value
                        gw.send(msgDoor.set(value==HIGH ? 1 : 0));
                        oldValue = value;
                        //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                        Now it is 4in1 :)
                        • Łukasz KostrzewaŁ
                          Łukasz KostrzewaŁ
                          Łukasz Kostrzewa
                          • kurniawan77K
                            kurniawan77K
                            kurniawan77
                            wrote on last edited by kurniawan77
                            #31
                            Has the 3in1 sketch been updated to 2.0 yet? I need some help with it, im not tot keen with coding...
                            R 1 Reply Last reply
                            • kurniawan77K kurniawan77
                              R
                              R
                              r-nox
                              @kurniawan77
                              This is HUM TEMP and PIR
                              This is what I'm using and it runs in mysensors 2.0
                              None battery powered. NO sleep mode and dirty code but it runs well enough for me right now.
                              If you add or fix anything please post it for everyone.
                              #define CHILD_ID_MOT 2 //me
                              #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                              boolean metric = false;
                              unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
                              unsigned long previousMillis=0; // millis() returns an unsigned long.
                              MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED); //me
                               // metric = getConfig().isMetric;
                                sendSketchInfo("3-1 Sensor", "1.0");
                                present(CHILD_ID_MOT, V_TRIPPED); //me
                              // only run loop if time has passed.
                              unsigned long currentMillis = millis(); // grab current time
                               // check if "interval" time has passed
                               if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                                    #ifdef MY_DEBUG
                                     Serial.print("Motion: ");
                                  if (!metric) {
                                  #ifdef MY_DEBUG
                                    lastHum = humidity;
                                    #ifdef MY_DEBUG
                                 // save the "current" time
                                 previousMillis = millis();
                                //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                              • ikkeTI
                                ikkeTI
                                ikkeT
                                wrote on last edited by ikkeT
                                #33
                                My sample is here, unfortunately I didn't see this thread before starting it :)
                                It works for temp, humidity, door and motion, and interrupts for door and motion, otherwise sleeps the intervals:
                                https://github.com/ikke-t/sensebender
                                There is also pro-mini to code to monitor only door and motion.
                                This is also for 2.0 MySensors.
                                • McPostalM
                                  McPostalM
                                  McPostal
                                  wrote on last edited by McPostal
                                  #34
                                  I combined Motion and Air Humidity and Sleep works. This is my first one and I'm pretty sure I have some unnecessary code in it.
                                   * Motion: Version 1.0 - Henrik Ekblad
                                   * Humidity: Version 1.0: Henrik EKblad
                                   * Combination of Motion Sensor example and Air Humidity example
                                   * https://www.mysensors.org/build/humidity
                                  // Enable debug prints
                                  float lastTemp;
                                  float lastHum;
                                  uint8_t nNoUpdatesTemp;
                                  uint8_t nNoUpdatesHum;
                                  unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
                                  #define MOTION_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                  #define DHT_INPUT_SENSOR 4     // The digital input of attached DHT sensor
                                  #define SENSOR_TEMP_OFFSET 0
                                  static const uint64_t UPDATE_INTERVAL = 60000;
                                  #define CHILD_ID_HUMID 0        // ID of the Humidity child
                                  #define CHILD_ID_TEMP 1         // ID of the Tempurature child
                                  #define CHILD_ID_MOTION1 2   // Id of the Motion sensor child
                                  // Initialize motion message
                                  MyMessage msgMotion(CHILD_ID_MOTION1, V_TRIPPED);
                                  MyMessage msgHum(CHILD_ID_HUMID, V_HUM);
                                  DHT dht;
                                    sendSketchInfo("Motion Temp Humidity", "1.0");
                                    present(CHILD_ID_MOTION1, S_MOTION);
                                    present(CHILD_ID_TEMP, V_TEMP);
                                    present(CHILD_ID_HUMID, V_HUM);
                                  	pinMode(MOTION_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                                    dht.setup(DHT_INPUT_SENSOR); // set data pin of DHT sensor
                                  	bool tripped = digitalRead(MOTION_INPUT_SENSOR) == HIGH;
                                  	send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
                                    #ifdef MY_DEBUG
                                  // DHT ****************************************************************************
                                    dht.readSensor(true);
                                      // Reset no updates counter
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesTemp++;
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesHum++;
                                  	// Sleep until interrupt comes in on motion sensor. Send update after (SLEEP_TIME) milliseconds has passed.
                                  	sleep(digitalPinToInterrupt(MOTION_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                                    A Former User
                                    I did some work today getting this temp / humidity / motion combo sensor running. The main issue I ran into was that though the temp and humidity did not report their values to the GW unless there was a change in values or the max no update trigger was reached, the motion sensor would report it's state value each cycle. @McPostal you also should be seeing this in your code. While this is not an issue if you are powering with a AC adaptor, I am planning on using batteries down the road for these sensors so I do not want it to broadcast unless required.
                                    I added some code to resolve this. I am still testing this out but in theory this code should allows the Motion sensor to sleep and only report on a state change or when the max no update trigger is reached.
                                     * Version 1.0: Henrik EKblad
                                     * sensor using a DHT11/DHT-22.
                                    //#define MY_RS485
                                    #define DHT_DATA_PIN 4
                                    #define MOTION_DATA_PIN 3
                                    #define CHILD_ID_MOTION 2
                                    float lastTemp;
                                    float lastHum;
                                    bool lastMotion = false;
                                    uint8_t nNoUpdatesMotion;
                                    bool metric = true;
                                    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                                    DHT dht;
                                      sendSketchInfo("Temp Humidity Motion", "1.1");
                                      present(CHILD_ID_MOTION, S_MOTION);
                                      pinMode(MOTION_DATA_PIN, INPUT);
                                      sleep(5000);
                                      presentation();
                                      bool tripped = digitalRead(MOTION_DATA_PIN) == HIGH;
                                      if (tripped || nNoUpdatesMotion == FORCE_UPDATE_N_READS) {
                                        lastMotion = tripped;
                                        nNoUpdatesMotion = 0;
                                      else if (lastMotion) {
                                      else {
                                        nNoUpdatesMotion++;
                                        if (!metric) {
                                        nNoUpdatesTemp = 0;
                                        #ifdef MY_DEBUG
                                        nNoUpdatesTemp++;
                                        lastHum = humidity;
                                        nNoUpdatesHum = 0;
                                        #ifdef MY_DEBUG
                                        nNoUpdatesHum++;
                                      sleep(digitalPinToInterrupt(MOTION_DATA_PIN), CHANGE, UPDATE_INTERVAL);
                                    Morkin.
                                    • McPostalM
                                      McPostalM
                                      McPostal
                                      Nice! I realized the motion was being updated every cycle after I posted my code. I also left out references to metric temperature readings. I fixed the motion part in my code but didn't post it yet because I had already added a second motion sensor. What I did different was not forcing the motion update. I want the time stamp to reflect the last time someone was in the room.
                                      • stockenS
                                        stockenS
                                        stocken
                                        I took your updated code for 2.0 and tried to add a relay.
                                        The code looks like this:
                                        #define CHILD_ID_HUM 10
                                        #define CHILD_ID_TEMP 11
                                        #define CHILD_ID_MOT 12 //motion sensor
                                        #define RELAY_1  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                        #define CHILD_ID 5
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                        void before()
                                        		pinMode(pin, OUTPUT);
                                          sendSketchInfo("4-1 Sensor", "1.0");
                                        	present(sensor, S_BINARY);
                                              #ifdef MY_DEBUG
                                            if (!metric) {
                                            #ifdef MY_DEBUG
                                              lastHum = humidity;
                                              #ifdef MY_DEBUG
                                        	if (message.type==V_STATUS) {
                                        		// Change relay state
                                        		// Store state in eeprom
                                        However, when i look in domoticz the relay isnt presented as a child.
                                        Plus, the motion sensor is called "S_LIGHT_LEVEL" and not "S_MOTION" as it does in my other device (that only have temp, hum motion and not a relay in the sketch).
                                        temp/hum sensor and motion sensor works as intended in domoticz.
                                        My first though is that the motion and relay somehow is a bit mixed up by the sketch, but im kinda new to this so im not sure.
                                        Would really appreciate if someone can look at the sketch and see if there is any obvious problem :)
                                        McPostalM 1 Reply Last reply
                                        • stockenS stocken
                                          #define CHILD_ID 5
                                          DHT dht;
                                          float lastTemp;
                                          float lastHum;
                                          void before()
                                                #ifdef MY_DEBUG
                                              if (!metric) {
                                              #ifdef MY_DEBUG
                                                lastHum = humidity;
                                                #ifdef MY_DEBUG
                                          McPostalM
                                          McPostalM
                                          McPostal
                                          #38
                                          @stocken
                                          Under "void presentation()" , present(CHILD_ID_MOT, V_TRIPPED); //me should be
                                          present(CHILD_ID_MOT, S_MOTION); //me
                                          that should fix the light level problem.
                                          I haven't done a relay yet. If no one else responds I look at it later tonight. I also have a relay but haven't had time to try and implement it yet.
