  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • sundberg84S
    sundberg84S
    #25
    Yes - smaller PCB.
    Creepage is handled with:
    1. Greater distance between components.
    2. Holes in PCB between components/parts that are close to each other.
    Creepage distance is calculated here: http://creepage.com/
    • Sefi NinioS
      Sefi NinioS
      Sefi Ninio
      Even though it's untested, would you mind publishing the Gerber and bom files?
      • sundberg84S sundberg84
        @Sefi-Ninio - Yea I should. Im working on Rev 4 and there is more creepage both between primary (220) and secondary (5) and also internally in primary. Everything is ordered but nothing recieved yet, but let me give you a small peak:
        GertSandersG
        GertSandersG
        GertSanders
        @sundberg84
        Very nice board !
        • sundberg84S
          sundberg84S
          • Sefi NinioS
            Sefi NinioS
            Sefi Ninio
            SMD is easier with solder paste and hot air solder
            • sundberg84S
              sundberg84S
              #30
              This PCB has been updated to Rev 4.1 with the following changes:
              (Note that this thread contains the non SMD version)
              • Complete redesign of traces to improve size and stability.
              • Nrf24l01+ now on the bottom side to make more room (with hope not RF disturbace from HLK or AC traces).
              • Added silkmask with AC-DC seperation (Rev 4.1 > 5mm)
              • AC clearance 2.5mm minimum
              • Changed one AC trace from botton to top to increace creepage and changed milling
              • MysX 2.3 + Analog IO
              • Safety recommendations: This PCB meets the criteria of pollution level II (2,5mm (Basic) AC seperation and 5mm (Reinforced) AC-DC sepertion) and can be used "where only non-conductive contamination occurs. However, occasional temporary conductivity must be expected as a result of moisture condensation." Always use a sealed case to avoid contamination. Always read disclaimer.txt before using this PCB.
              Images on https://www.openhardware.io/view/13/In-Wall-ACDC-Pcb-for-MySensors has been updated.
              Please wait for PCB house to update to new gerber files before ordering (It should say M.Rev 2 (Manufacturer rev 2) for latest revision when selecting PCB house)
              Im currently testing this rev...
              If you want to be 100% sure, download and prev. revision.
              • carthiqueC
                carthiqueC
                carthique
                Can someone please suggest replacement parts for the 110v variant of this board.
                Karthik
                • carthiqueC carthique
                  Karthik
                  sundberg84S
                  sundberg84S
                  @carthique - You need a 110 v varistor maybe something like: http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true. Fuses and other components is the same.
                  • ashwayA
                    ashwayA
                    ashway
                    @sundberg84, when I go to the order form, the revision there is M.Rev3. Which version of PCB does that manufacturer revision correspond to - 3.1 or 4.1???
                    • ashwayA ashway
                      sundberg84S
                      sundberg84S
                      @ashway - this is correct/latest version. The manufacturer rev 3 equals the latest 4.1.
                        shabba
                        Excuse the possibly silly question but the buy options is PCBs only? Or does it come with the housing too?
                        • S shabba
                          sundberg84S
                          sundberg84S
                          @shabba - PCB only.
                          I recommend using 3dhubs.com and find a local 3d printer for the case.
                          Files (.stl) attached in the project.
                          J 1 Reply Last reply
                            shabba
                            @sundberg84 thanks - I had a look in the design files and I think I covered the comments but could not find a .stl file.
                            • S shabba
                              sundberg84S
                              sundberg84S
                              @shabba - sorry you are right.
                              If i remember right I removed it because I wasnt 100% sure it would be ok going from 4.0 to 4.1 on the pcb.
                              Let me have a look and post it asap.
                              • bmokenaB
                                bmokenaB
                                bmokena
                                Hi sundberg84,
                                I bought 10 of these PCBs. So can I use this PCB, add a relay and fuse and use it inside the wall to control light switches? or should I go rather go for the other PCB "In Wall AC/DC Pcb (with Relay) for MySensors (SMD)" ?
                                Bob
                                • bmokenaB bmokena
                                  Hi sundberg84,
                                  Bob
                                  sundberg84S
                                  sundberg84S
                                  @bmokena - if it fits, that should be ok. This PCB is made a more generic pcb so you can add any sensor/accuator to it including a relay. Use the MysX i/o and you can controll your relay through D3 for example.
                                    @shabba - PCB only.
                                    J
                                    J
                                    johmei
                                    @sundberg84
                                    Hi, do you have any local Swedish printing services to recommend?
                                    Ps. Got the PCBs from Pcbway yesterday and man was I surprised how small they were. Looks great and hope to get some nodes up and running soon, once all components get here.
                                    • J johmei
                                      @sundberg84
                                      sundberg84S
                                      sundberg84S
                                      @johmei - sorry, I wish i had any good recommendations for local PCB service.
                                      The only research I have done leads me to that they are VERY expensive compared to these 10x10 chinese.
                                      Good luck with your build! Images are always appreciated! ;)
                                      • J
                                        J
                                        johmei
                                        @sundberg84 - Thanks, but I was thinking about 3D printing services for boxes, cases and mounts in very small series (maybe even singles)?!
                                        Regarding images we'll see if I manage to get any AC stuff going anytime soon. I have a lot of respect for AC and probably want to get to know the Arduino platform a bit more first. Got my first couple of regular DC nodes running yesterday and they have been running really well for 12 hours now (impressed of the small nrf24+ radio range). So many ideas to explore. =)
                                        Actually ordered a set of your newbie PCBs a few days after my In wall AC PCB order so there will be a lot your autograph around my house..
                                        • J johmei
                                          sundberg84S
                                          sundberg84S
                                          @johmei - haha, I hope they will help you some in your quest for HA. About 3d printing I use 3dhubs.com and have tried different once and been satisfied. Go for one at your location if you want to pick up. I use one in Kalmar with shipping I can recommend.
