  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
    MLs
    DHT sketch version 2.1.0 no data i IDE seiel
    And if i use DHT example sketch then I get data temp / hum
    Did not have permission to post in the forum
    • F
      F
      flopp
      wrote on last edited by flopp
      #47
      @hek @mfalkvidd I read that you discussed about PIN 2 and 3.
      Code say PIN 2, Wiring things up say PIN 2 and picture shows PIN 3.
      It can't use PIN 2 or can it, PIN 2 is used by the radio, or am I to tired :)?
      meanmrgreenM 1 Reply Last reply
      • F flopp
        meanmrgreenM
        meanmrgreenM
        meanmrgreen
        @flopp
        thats the irq pin in the radio post.
        Not used by the radio
        F 1 Reply Last reply
        • meanmrgreenM meanmrgreen
          @flopp
          F
          F
          flopp
          #49
          @meanmrgreen said:
          @flopp
          I must have missed something or forgot. Is PIN 2 only used on Gateways?
          Is it different between MyS version 1.x and 2.x?
            Tried to follow the history on the humidity file back in time on github.
            At some point (2.0 release) the example was switched from HumiditySensor.ino (using pin 3) to DhtTemperatureAndHumiditySensor.ino (pin 2) created by @mozzbozz.
            Not sure why the pin was switched, but you can run without the radio/IRQ-pin connection as long as not activating the MY_RX_MESSAGE_BUFFER_FEATURE.
              F
              F
              flopp
              @hek
              All other examples are using PIN 3. Wouldn't it be easier to use PIN 3 for all examples? Maybe we shall wait and see if mozzbozz know why he changed to PIN 2.
                wrote on last edited by hek
                #52
                Ok, updated the example on github and instructions on the page back to pin 3.
                • skywatchS
                  skywatchS
                  skywatch
                  Hurrah! :)
                  Now I can sleep at night again ;)
                  Good job!
                    Haha, yeah, good to hear you will get a good nights sleep again.
                    • skywatchS skywatch
                      Hurrah! :)
                      Good job!
                      F
                      F
                      flopp
                      @skywatch said:
                      Hurrah! :)
                      Good job!
                      haha, me too :)
                      • Pavel LarkinP
                        Pavel LarkinP
                        Pavel Larkin
                        wrote on last edited by gohan
                        #56
                        Hello. Maybe someone could help :) hopefully..
                        I have arduino1 with 1 DHT22, which is over arduinoGW connected to RSPi with latest domoticz.
                        when i connect stuff up, after some time i see some strange childids, not related to this arduino1 in no way.
                        Lots of unknown!, with V_TEMP values, with V_HUM values, even V_FORECAST, V_PRESSURE and etc. which arduino1 should not send (or no other arduino on my area).
                        Illustration:
                        <img href="http://www.lstudio.lt/wp-content/uploads/dht22problem.png">
                        my code is quite simple (for ex only temperature is shown)
                        #define CHILD_DESCR "TEMP3"
                        #undef CHILD_ID
                        #define CHILD_ID 31
                        present(CHILD_ID, S_TEMP, CHILD_DESCR);
                        delay(250) ;
                        loop:
                          temp3=dht3.readTemperature();
                        if (temp3 >= 120) {temp3 = lasttemp3;}
                        if (temp3 <= -50) {temp3 = lasttemp3;}
                        MyMessage msg31(CHILD_ID,V_TEMP);
                        send(msg31.set(temp3,1));
                        so.. that is basically all
                        • Pavel LarkinP Pavel Larkin
                          Illustration:
                          #undef CHILD_ID
                          #define CHILD_ID 31
                          delay(250) ;
                          loop:
                          F
                          F
                          flopp
                          #57
                          @Pavel-Larkin
                          I have also seen this, I noticed it last week. Some of my Nodes have those Unknown-child, but it is working correctly anyway.
                          DZ 3.5877, MyS 1.5.1, RPi 2
                          • GimlurG
                            GimlurG
                            Gimlur
                            i have a problem with this sketch.
                            After downloading DTH.h froom Mysensors Examples, i have this error :
                            DhtTemperatureAndHumiditySensor:85: error: 'getConfig' was not declared in this scope
                            Any Idea of my mistake ?...
                              It isn't your mistake, it's ours. The examples hasn't been updated correctly to reflect the most recent change in the api.
                              It should say getControllerConfig().isMetric
                              • johnecyJ
                                johnecyJ
                                johnecy
                                I have the dht22 sensor hooked up and working on a pro mini on pin 3 I get a normal temp reading but the humidity always stays at 1.0 does not read.
                                • johnecyJ johnecy
                                  @johnecy https://forum.mysensors.org/topic/5978/temperature-and-humidity-dht22
                                  • D
                                    donhuan78p
                                    Hello everybody,
                                    hope, someone could help a newby :-)
                                    I've installed the MQTT - GW and would use the Air/Humidity - sensor. But it doesn't work properly.
                                    The Connection to the Gateway seems to be okay. But I get no Air/Humidity - Information.
                                    The sensor does not measure anything.
                                    I've tried to change the data - pin, I've tried the DHT11 and DHT22 - sensor. No choice.
                                    I'm getting mad :-)
                                    Thanks a lot.
                                      Have you tried the basic arduino sketch that prints data to serial port?
                                      • D
                                        donhuan78p
                                        thanks a lot for your answer.
                                        Yes, I did. It produced the Messages as excepted.
                                          So you'd better post your code so we can take a look at what is wrong with it.
