  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • laster13L
    laster13L
    laster13
    @tonnerre33
    I will be really interested to buy you all the components you would no longer need. NRF, pcb, fuse thermal ... If you agree, can you tell me a list of what you offer thanks
    • C
      C
      chickey
      If anyone in the UK is after boards/parts i have spares.
      • Rodolfo VieiraR
        Rodolfo VieiraR
        Rodolfo Vieira
        hello, anyone use this project with home assistant?
        • proddyP
          proddyP
          proddy
          Thanks for this. One question about the SSR. Does it matter if its a zero crossing relay or not if just switching lamps with fixed amps? That the difference between the G3MB-202P and G3MB-202PL. I'm not sure which to get.
          Nca78N 1 Reply Last reply
          • proddyP proddy
            @Paul-Derbyshire if you're buying on aliexpress at less than 3$ a relay, you're buying chinese clones like most of us here. I doubt they bothered implementing the zero-crossing function on the chinese clones...
            • HaMH
              HaMH
              HaM
              I love this project. This is almost exactly what I wanted to do by myself (but I have no knowledge in PCB design). As this project shouldn't require much power, have you ever though about using a dropping capacitor PSU (http://www.circuitsgallery.com/2012/07/transformer-less-ac-to-dc-capacitor-power-supply-circuit2.html) instead of the HLK-PM01 ?
              If this is a working solution, it would make your project even cheaper.
              An other question on the DS18B20. Wont the proximity with the relays (heat generators) will disturb the temperature reading ?
              • HaMH HaM
                wrote on last edited by Nca78
                #157
                Hello !
                Transformerless design means there is not isolation between main voltage and low voltage parts. You can get electrocuted with 110/220V when touching the low voltage side. It means it can be used only in the case of a sealed box.
                For the temperature sensor the main source of heat is the hlk that heats up a lot. It's purpose is not to sense the temperature in the room, but to monitor the temperature inside the sensor and make sure there is not problem with the hlk overheating.
                HaMH 1 Reply Last reply
                • Nca78N Nca78
                  Hello !
                  HaMH
                  HaMH
                  HaM
                  @Nca78 Thanks for the advice.
                    A Former User
                    Would it be possible tot change the relays to one (or two) triacs, keeping it's current features and also allowing it to dim lights?
                    • rhapenR
                      rhapenR
                      rhapen
                      anyone found the Slow Blow Fuse (250v 0.2A) on aliexpress? if yes please link.
                      • rhapenR
                        rhapenR
                        rhapen
                        found 250V 0.25A o aliexpress - i believe this will be good enough - http://tiny.cc/h4fpiy
                        • Sacha TelgenhofS Sacha Telgenhof
                          Hi @aproxx , very nice module! Just one question: after studying the board I still not quite understand how an existing light switch needs to be connected. There are 3 connecters, one for AC and two relays. Where do I connect the light switch to?
                          Cheers! Sacha
                          rhapenR
                          rhapenR
                          rhapen
                          @Sacha-Telgenhof : It also took me bit of time. It is the PINs on the board 7 GND 4 for two switches 7 and 4 are the digital inputs on arduino.
                          • Jose SimoesJ
                            Jose SimoesJ
                            Jose Simoes
                            hey @Aproxx, nice project, do you think a current sensor could be added to the PCB to monitor electrical consumption. the idea of adding triact to the circuit by @overlordt seems to work theoretically.
                            • SensibleHeatS
                              SensibleHeatS
                              SensibleHeat
                              My parts are on the way and I"m looking forward to trying this one out. Thanks for sharing this project!!
                                stray
                                If you create a new version, could you connect the other 2 5V and GND holes next to D6 so these can easily be used as power output?
                                  https://www.openhardware.io/view/77/AC-DC-double-solid-state-relay-module
                                  Marco Lo Grasso
                                  wrote on last edited by Marco Lo Grasso
                                  #166
                                  I can't understand (scrub here) how to wire the regular light switch to the board.
                                  Supposing I want to use only one relay, I have to wire the switch to the 7 PIN and GND right?
                                  • M Marco Lo Grasso
                                    tonnerre33T
                                    tonnerre33T
                                    tonnerre33
                                    #167
                                    @Marco-Lo-Grasso said in 💬 AC-DC double solid state relay module:
                                    Yes you have to do this, but i don't know if the sketch is working fine with the light switch ;) I haven't tested this feature yet.
                                    Caution, the light switch don't be connected to the 230V !
                                    • J
                                      J
                                      Joe Barneson
                                      Any suggestions for front panels on the light switches? I've connected mine to normal switches to control the relays, but I'd really like a 4-8 soft button front panel that I could also wire into GPIO's on an ESP for "scene" control outside of the local relays. Auy suggestions or experience would be great
                                      • Nca78N
                                        Hello, I'm not sure exactly of what you want to to, but you could use software i2c on those two pins and connect and i2c keypad. You can search mpr121 keypad on google or aliexpress.
                                        But be careful you should add an isolating cover on top of it if you connect to this board as the crepage/cleatance between main voltage and 5V/3.3V is not sufficient in some part of the board and it could end up with low voltage circuit at main voltage...
                                        • J
                                          J
                                          Joe Barneson
                                          good to know clearence isn't there ... something i could correct though
                                          An i2c and capacity touch could work great.. but i can't find any cleanly designed front panel that I could use in place of my light switches.
