  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • Richard_SkeR
    Richard_SkeR
    Richard_Ske
    Hi All,
    This is my first post on this site!!
    Yes this is a really good project but for the UK controlling a light inside of a wall switch you would need to do the following.
    Re-wire the ceiling rose as in the UK there is a live feed from the rose that is switched by the switch and then returns to the rose to the "switched live" See http://www.diydoctor.org.uk/project_images/lights_and_switches/ceilingroseb2.jpg
    Put an extra cable up to the ceiling rose with the return cable from the board that goes to the switched live and add an extra terminal in the ceiling rose to link the neutral to the other side of the lamp fitting.
    If the back box is metal, it would need to be changed to a plastic box , I wouldn't myself want to mount the board in an earthed metal box!!
    As other contributors have noted there isn't any fusing on the live and neutral feeds if the SSR were to fail short because of a short circuit in the lamp or ceiling rose then there could be a large current going through board that could potentially cause a fire, safety is always the first thought with any mains electrical circuit.
    I could see this board being used in a plastic box inline to a table lamp etc. but it would need a lot of work to re-wire your house if you intended to use it behind a wall switch.
    • laster13L laster13
      I am trying to test a montage which I am not sure about and besides when I plug the pcb on the socket the lamp remains on. I invite you to read my post on the Domoticz forum.
      http://easydomoticz.com/forum/viewtopic.php?f=20&t=2680&p=25219#p25219
      I am sorry for my english, I use the traducer of google
      tonnerre33T
      tonnerre33T
      tonnerre33
      @laster13 Yes your schema is correct.
      The sketch has been modified by Nca78, you can try it first.
      The problem does not come from the unused switch, because i use this node without switch.
      • E
        E
        Eawo
        I'm going to do these for my light switches but what should I use for in wall on off switch without relay?
        • HilltanH
          HilltanH
          Hilltan
          The link to to DirtyPCBs is broken, got a new one?
          • HilltanH Hilltan
            tonnerre33T
            tonnerre33T
            tonnerre33
            @Hilltan Hello, i think this link will be ok : http://dirtypcbs.com/store/details/885/mysensors-v3-3-2-light-switch
            For information, a few members have too many PCB of this node that's why if you are living in Vietnam or asia, Nca78 can send you PCB and if you are in france, i can send too (contact by pm for terms).
            I use this node since 20 days ago, and it's working well ;)
            • johnym30J
              johnym30J
              johnym30
              Hi everyone.
              I can not find anywhere Slow Blow Fuse (250v 0.2A). Does anyone has an available link??
              Thanks in advance.
              • johnym30J
                johnym30J
                johnym30
                Never mind, got them. thank you!!!
                • laster13L
                  laster13L
                  laster13
                  @tonnerre33
                  I will be really interested to buy you all the components you would no longer need. NRF, pcb, fuse thermal ... If you agree, can you tell me a list of what you offer thanks
                  • C
                    C
                    chickey
                    If anyone in the UK is after boards/parts i have spares.
                    • Rodolfo VieiraR
                      Rodolfo VieiraR
                      Rodolfo Vieira
                      hello, anyone use this project with home assistant?
                      • proddyP
                        proddyP
                        proddy
                        Thanks for this. One question about the SSR. Does it matter if its a zero crossing relay or not if just switching lamps with fixed amps? That the difference between the G3MB-202P and G3MB-202PL. I'm not sure which to get.
                        Nca78N 1 Reply Last reply
                        • proddyP proddy
                          @Paul-Derbyshire if you're buying on aliexpress at less than 3$ a relay, you're buying chinese clones like most of us here. I doubt they bothered implementing the zero-crossing function on the chinese clones...
                          • HaMH
                            HaMH
                            HaM
                            I love this project. This is almost exactly what I wanted to do by myself (but I have no knowledge in PCB design). As this project shouldn't require much power, have you ever though about using a dropping capacitor PSU (http://www.circuitsgallery.com/2012/07/transformer-less-ac-to-dc-capacitor-power-supply-circuit2.html) instead of the HLK-PM01 ?
                            If this is a working solution, it would make your project even cheaper.
                            An other question on the DS18B20. Wont the proximity with the relays (heat generators) will disturb the temperature reading ?
                            • HaMH HaM
                              wrote on last edited by Nca78
                              #157
                              Hello !
                              Transformerless design means there is not isolation between main voltage and low voltage parts. You can get electrocuted with 110/220V when touching the low voltage side. It means it can be used only in the case of a sealed box.
                              For the temperature sensor the main source of heat is the hlk that heats up a lot. It's purpose is not to sense the temperature in the room, but to monitor the temperature inside the sensor and make sure there is not problem with the hlk overheating.
                              HaMH 1 Reply Last reply
                              • Nca78N Nca78
                                Hello !
                                HaMH
                                HaMH
                                HaM
                                @Nca78 Thanks for the advice.
                                  A Former User
                                  Would it be possible tot change the relays to one (or two) triacs, keeping it's current features and also allowing it to dim lights?
                                  • rhapenR
                                    rhapenR
                                    rhapen
                                    anyone found the Slow Blow Fuse (250v 0.2A) on aliexpress? if yes please link.
                                    • rhapenR
                                      rhapenR
                                      rhapen
                                      found 250V 0.25A o aliexpress - i believe this will be good enough - http://tiny.cc/h4fpiy
                                      • Sacha TelgenhofS Sacha Telgenhof
                                        Hi @aproxx , very nice module! Just one question: after studying the board I still not quite understand how an existing light switch needs to be connected. There are 3 connecters, one for AC and two relays. Where do I connect the light switch to?
                                        Cheers! Sacha
                                        rhapenR
                                        rhapenR
                                        rhapen
                                        @Sacha-Telgenhof : It also took me bit of time. It is the PINs on the board 7 GND 4 for two switches 7 and 4 are the digital inputs on arduino.
                                        • Jose SimoesJ
                                          Jose SimoesJ
                                          Jose Simoes
                                          hey @Aproxx, nice project, do you think a current sensor could be added to the PCB to monitor electrical consumption. the idea of adding triact to the circuit by @overlordt seems to work theoretically.
