  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 39.2k Views 3 Watching
  • RJ_MakeR RJ_Make
    @epierre
    What do you mean the gas sensor overloaded the radio?
    epierreE
    epierreE
    epierre
    @ServiceXp just that I have a Mega sketch with 7 sensors reporting too frequently one one side, and on the other the weservice call was too slow, making me think of no transmission, but it was delayed in fact...
    z-wave - Vera -> Domoticz
    • epierreE
      epierreE
      epierre
      Some experiments:
      • I left it on a window border, it varied by one ohm on the night.
      • radio close is ok with the basic antenna.
      • i'll try to see to put it further outside, at the moment there are more than 10°C difference along with wet cars on the morning. I fear the rain drop may not be enough sensible...
      There is an alternative to the expensive davis one: LEAF WETNESS SENSOR
      I'll modify the sketch to report a percentage, as other humidity sensors would do.
      Some interresting discussion:
      • 200 KOmhs = very dry leaf
      • 20 KOmhs = slew fog
      • 5 KOhms = heavy rain
      About oxydation, dfrobot has one ground probe with this explanation:
      Immersion Gold which protects the nickel from oxidation. Electroless nickel immersion gold (ENIG) has several advantages over more conventional (and cheaper) surface platings such as HASL (solder)
      • epierreE
        epierreE
        epierre
        some returns:
        • from Sept 11th to 15th, the batteries (3*1.5V) went from 4.5V to 3.2 as mesured today, it stopped emitting on sept 15th
        • the leaf sensor shows heavy signs of oxydation without any rain during the period... this is a real problem with all those copies around... that is not a very viable solution...
        I've seen another product from Spain at Liebllium that I guess I will test for I haven't found any other item...
        YveauxY 2 Replies Last reply
        • epierreE epierre
          some returns:
          You're definitely not the first to report this.... I've read many negative reviews of these cheap sensors.
          epierreE 1 Reply Last reply
          • YveauxY Yveaux
            epierreE
            epierreE
            epierre
            @Yveaux but finding good one seems to be .... very difficult... I've spoken of immersive gold... will try to see if those are better....
            • epierreE epierre
              some returns:
              @epierre any idea why your sensor lasted this short?
              How often did it report its value to the gateway? Was it sleeping in between? Any other sensors connected?
              • YveauxY Yveaux
                epierreE
                epierreE
                epierre
                @Yveaux several ideas:
                • it reported every 10000
                • it has no other sensor (this was my first try on batteries...)
                • I had an AMS1117 in entry but I didn't needed it
                • I haven't hacked the 3.3V core with the websites @a-lurker ideas
                I'm waiting for the batteries from my other post because using so fast batteries is not environment friendly...
                Has there been simulation of energy usage for those arduini ? e.g. for a spark core it isadvertized at 500mW
                • epierreE
                  epierreE
                  epierre
                  I've finally received from cooking hacks the leaf wetness sensor board that should be better than the one from china...
                  It is the one from hobby boards:
                  I guess I can recycle the lectronic from the cheap one on this one ?
                    It doesn't look much different that the china-ones. Is it gold-plated or something?
                    • epierreE
                      epierreE
                      epierre
                      yes it is, from the hobby board site it is $2, but it is a quarter the china's size.
                      sorry I missed your point, it is gold plated, immersion gold.
                      • epierreE
                        epierreE
                        epierre
                        Ok, so I made some adjustments from my last try:
                        • hobbyboard immersion gold sensor
                        • I kept the comparator from the other sensor to facilitate work with the arduino
                        • I've added a 18650 LiOn battery (5000mAh) to have an extended life cycle
                        Here is the sketch:
                        https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
                        What I can say, is that it is very sensitive. It is now outside live in the cold.
                        This could be used for a leak sensor easily.
                        • epierreE
                          epierreE
                          epierre
                          so my 5000mAh lasted outside... 4 days... btw I didn't remove all leds from the comparator that could be an improvement and the outside weather is quite cold.
                          I had a reading every 30 secs, way to quick surely...
                          @hek is there a way to power the radio only when necessary ? I guess the gw.sleep could be a gw.sleep and a gw.wakeup and manage the delay outside ?
                          hekH 1 Reply Last reply
                          • epierreE epierre
                            wrote on last edited by hek
                            @epierre
                            gw.sleep() sleeps the radio as well. What do you mean by power down radio? Like cutting power using digital pin?
                              @epierre
                              epierreE
                              epierreE
                              epierre
                              @hek said:
                              @epierre
                              yes, now you combine sleep for the radio and delay, what I mean is to have loop() run without radio, and if a transmission is needed to have a command that power it.
                              If you have a long dry period, a device on battery will consume a lot of power having the radion on and off, if it is always off until a sensor finds something, that would save more power, no ?
                              • RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                Wake only on interrupt?
                                RJ_Make
                                • epierreE
                                  epierreE
                                  epierre
                                  In my idea, a value above 0 would mean sending the info, an interrupt could be generated this way ?
                                  • elisavetgrigE
                                    elisavetgrigE
                                    elisavetgrig
                                    Hey,
                                    I am a newbie (in the forum) and in the arduino/sensors development. I bought the Leaf Wetness from cooking-hacks.com. Can I connected it to my Arduino via Analog input? Is it easy?
                                    SparkmanS 1 Reply Last reply
                                    • elisavetgrigE elisavetgrig
                                      Hey,
                                      SparkmanS
                                      SparkmanS
                                      Sparkman
                                      @elisavetgrig Welcome to the forum. The answer is yes to both questions. Given that the sensor is a resistive element, you need to build a voltage divider. Google "voltage divider" Arduino and you'll find lots of examples.
                                      Al
                                      • FotoFieberF
                                        FotoFieberF
                                        FotoFieber
                                        Measuring the current with DC doesn't seem to be the ideal solution:
                                        thread
                                        • FotoFieberF FotoFieber
                                          thread
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          @FotoFieber That thread is regarding soil moisture measurements which is different than leaf wetness. For soil, capacitive is the best way to go IMHO.
                                          Al
